Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 27.04.2017, 18:22   #331
Potable
Аватар для Potable
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Победил я инсталляцию в авто ГУ. Так-то вроде ничего сложного, основные заморочки по установке камеры ЗХ (в якобы штатное место над номером), установке антенн ТВ-тюнера + разгадывание ребусов от прошлого вмешательства по вырезанию усила рокфорд. Пара вопросов таки нарисовалась:
1. имеющийся усил обслуживает саб и фронты, задние на прямую от ГУ, соответственно имеется дисбаланс (зад играет тише), который не могу устранить регулировкой поля в эквалайзере. Смещаю в сторону зада, всё просто тухнет и всё, ХЗ как исправить?
2. Явно прослушивается звук двигателя. Нет, громкости добавить - заглушает... Первое, что напрашивается, конечно фильтр по питанию. Кто как борется?
Добавлено через 3 часа 17 минут
Добавлю: диск действительно зажовывает.
Старый 27.04.2017, 23:24   #332
Нецид
Аватар для Нецид
Сообщение от Levashov Посмотреть сообщение
16.5 это стандарт динамиков и все они считаются мидбасами
А где можно подробно прочитать про динамики Рокфорд? Интересует диапазон частот и т.п Мощность у них 75 и 80 Вт? Прошу прощения за оффтоп.
Нецид вне форума   Вверх Ответить с цитированием
Старый 28.04.2017, 01:01   #333
Айтишник
Авто: Outlander XL 2.4 MT
Сообщение от lyaxndr Посмотреть сообщение
Все очень просто, ГУ узнает про ночной режим через провод IL. Он розового цвета, выходит из основного разъема ГУ.
По умолчанию он соединен с проводом, идущим из машины , на котором появляется 12В при включении ближнего света.
Я отказался от идеи подключения умного автоматического режима переключения противотуманки(взамен ДХО)-ближний свет и по моей просьбе уважаемый Дмитрий(Ежик Пых) вернул евросвет.
Соответственно, экран ГУ находился все время в ночном режиме.
Режем этот розовый провод(он в фишке ГУ - №4).
Изолируем конец, который идет дальше в торпеду, а тот, который шел в ГУ соединяем с оранжевым проводом(с серебристыми полосками), идущем к разъему нижней панели под ГУ(где аварийка, подушки).
На этом проводе появляется 12В при включении подсветки кнопок-крутилок на торпеде. Что нам и нужно.
Я нарастил розовый провод и подпаялся к оранжевому, не разрезая его.
Все заработало как надо.
До этого пользовал MTC Tool прогу, но она затемняет экран только по GPS времени, соответственно, туннели-грозовые черные тучи она не видит.
Фото выкладываю
Спасибо. Заработало. Только у меня провод нашелся не оранжевый, а желтый с красными полосками. Теперь ночной режим работает как надо.
При установке ГУ штатный блюпуп можно демонтировать?
Читал ранее на форуме, что при отключении этого блока в мозги запишется ошибка. Я у себя этот блок оставил включенным.
Айтишник вне форума   Вверх Ответить с цитированием
Старый 28.04.2017, 10:15   #334
ДмитрийГлаз
Аватар для ДмитрийГлаз
Сообщение от Айтишник Посмотреть сообщение
Наоборот многие отключают, т.к подсаживает аккумулятор. Я давно его отключил, ошибок нет. Даже если и есть то на приборке она не отображается.
Старый 28.04.2017, 10:16   #335
Potable
Аватар для Potable
Сообщение от ДмитрийГлаз Посмотреть сообщение
Просто разъем сдернуть и демонтировать или ещё что то?
Старый 28.04.2017, 10:19   #336
ДмитрийГлаз
Я просто разъём сдернул. Зачем ему в пустую работать.
Старый 28.04.2017, 11:36   #337
Potable
Аватар для Potable
@ДмитрийГлаз, гул двигателя прослушивается?
Старый 28.04.2017, 11:40   #338
ДмитрийГлаз
нет. Никаких доработок не делал. Подключил сам разъём в разъём. Авто с рокфордом . единственный косяк это если музыку слушаешь и потом заводишь то звук пропадает. Приходится её перезапускать.(это секунды), и не напрягает
Старый 28.04.2017, 17:40   #339
Potable
Аватар для Potable
@ДмитрийГлаз, а у меня пропадает только пока стартер крутит. Только завелась - дальше поет
Старый 29.04.2017, 14:59   #340
Jo-Jo
Сообщение от errrr Посмотреть сообщение
А как подключали регистратор?!
В смысле питание ?
Jo-Jo вне форума   Вверх Ответить с цитированием
Старый 30.04.2017, 16:25   #341
systemvrn
Ребята подскажите как правильно подключить камеру заднего вида. Я приобрел себе оригинальную камеру с проводкой и подключил в фишку в заднем правом крыле. Куда теперь тюльпан желтый подключать от магнитолы?
systemvrn вне форума   Вверх Ответить с цитированием
Старый 30.04.2017, 19:44   #342
KoS
Аватар для KoS
Всем привет! Взял голову HA2034-V600 на 6 андройде. При подключении возник вопрос по двум проводам. Черный земля, но магнитола и без него работает. А второй провод для чего? Распиновки нет, инструкции нет.
Старый 30.04.2017, 20:51   #343
Potable
Аватар для Potable
@KoS, черный землить, кей2 не нужен, если канбас конечно подключили.
Старый 01.05.2017, 19:32   #344
KoS
Аватар для KoS
Первые впечатления.
О плюсах писать смысла нет, андройд есть андройд. Хотел бы задать пару вопросов и расписать минусы которые обнаружил в первый же день:
- не регулируется уровень сабвуфера (впрочем тут уже это писали), в настройках возможность есть, но это отдельные тюльпаны, которые у меня просто болтаются.
- не регулируется уровень перед/зад (это только у меня так???)
- в момент запуска двигателя горят значки аирбэга, так вот рядом с ними какие то полоски горят, видимо там на других версиях бывают дополнительные разъемы, мини узб или еще что, короче они не закрашены с внутренней стороны. Кто в курсе тот поймет )
- два раза словил глюк, просто пропал звук. Один раз открыл штатный браузер, зашел на ютуб, включил видюшку, развернул на полный экран, весь ролик до конца шел со звуком, после того как ролик закончился, я свернул полноэкранный режим и звук больше не появлялся, даже в радио. Помогло выключение магнитолы. Второй раз при езде задним ходом звук пропал и так же не появился. Помогло выключение магнитолы.
- Навител не видит карту памяти, на которой все карты от производителя ГУ. Пришлось просто скопировать карту РФ с микроСД карты на ГУ.
Вобщем меня сильно напрягла ситуация со звуком. Попытался проверить обновление, показала что последняя версия уже установлена. Буду наблюдать.
Добавлено через 11 часов 23 минуты
Забыл добавить ГУ HA2034-V600. Прошивка v2.41_1 от 20.03.2017
Старый 02.05.2017, 08:59   #345
ДмитрийГлаз
Первые впечатления.
Первые два пункта и у меня так же.На третий не обращал внимания.Звук пропадает ( и то не всегда) при заводе.Если нажать MUTE и завести то не пропадает.При движении задом или еще при каких то условиях кроме завода, звук не пропадал.При езде задом я настроил на приглушение звука,может в этом вся фишка.
Текущее время: 09:43. Часовой пояс GMT +3.
