Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 26.11.2017, 05:57   #496
Potable
Аватар для Potable
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Сообщение от AS21 Посмотреть сообщение
Можете его партномер?
Фото?
Что он может?
С каким приложением работает?
Ох и задали задачку
Ничего на него не сохранилось, да и не заказать его отдельно. Здесь в описании промелькивает его фото
http://s.aliexpress.com/EvuIniQ7
Что может? Описал уже: переключает ГУ на камеру ХЗ привключении ХЗ, кнопки на руле, управление подсветкой, яркостью экрана от головного света + датчика освещения. Это что я обнаружил, может еще чего
Старый 26.11.2017, 09:16   #497
AS21
Аватар для AS21
Авто: ASX 1.6 2WD MT
В описании написано: Радио Адапатер - это он?
Подключали его как?
- судя по комплекту - неопнятно
Дело в том, что у меня аналогичное устройство, но без этого блока и тоже выполняет все перечисленные Вами функции
Этот блок точно слушает кан шину?
Какое приложение, т.е. Вы в заводскмх настройках выбирали тип канбаса?
Если нет: посмотрите плз в "Заводских настройках" пароль 126 или 000 -> там есть тип (возможно у Вас стоит 57)
AS21 вне форума   Вверх Ответить с цитированием
Старый 26.11.2017, 10:39   #498
ДмитрийГлаз
Аватар для ДмитрийГлаз
Вообще Кан бус идёт в комплекте с головным устройством.У меня их уже два лежит. И на сколько я помню он нужен только тем у кого штатный рокфорд.(без кана просто звука не будет). Я правда не проверял так ли это.ставил всегда с Каном и проблем не было.
Старый 26.11.2017, 10:47   #499
AS21
Аватар для AS21
Тогда понятно:
- твой кан - это не совсем "канбокс" - для работі с кан шиной
Он работает только с рокфордом, и никак не коннектится к кан
А те функции ты подключил через провода:
- backWiew - на него подается +12V - когда замыкается сигнал "ЗХ"
- аналогично и с подсветкой....
- аналогчино с кнопками : Key1 - провод - это кнопки на руле - прямое управление через замер сопротивлентя при обучении (настройке) каждой кнопки
Есть еще Key2 - это допоплнительно, если надо подключить от другой группы кнопок.
Старый 26.11.2017, 10:50   #500
ДмитрийГлаз
@AS21, Именно так. Камера у меня не штатная и проблем при установке не было. Кнопки обучал.
Старый 26.11.2017, 10:58   #501
AS21
Аватар для AS21
Жаль - а я уже подумал, что можно наш штатный канбокс применить, чтобы делать настройки как мин комфорта, как на оригинальной MMCS
Пока я знаю только два пути:
- arduino
- ELM327 (OBDII)
А практически - банально не хватает времени...
Оба теоретически должны работать
Если кто-то найдет решение с нашим родным canBox - плз маякните
Осбенно ЭТО будет интересно владельцам DEKICA D5 - только у них штатно работает блок управления камерами: три вида: спереди + зад + бок -> и только с помощью кан
Думаю ЭТО будет многим интересно
Старый 26.11.2017, 11:26   #502
Potable
Аватар для Potable
@AS21, не совсем так, ка Вы описали. Я установил этот, условно псавдо-, кан в предусмотренный в одной из кос разъем. Больше никакие провода типа КЕЙ или ИЛЛ не подключал. Все заработало само. В заводских настройках указал тип авто 57 (если не ошибаюсь, могу уточнить). Единственное, что пришлось, это задействовать провод АМР для активации усилителя (у меня штаный рокфорд удален, вместо него каким-то колхозным способом вставлен 4-канальный усь, даже не разбирался каким). С функционалом ММЦС не знаком, но если его реализовать в ГУ , было бы интересно посмотреть. На просторах инета не встречал, что бы кто-то реализовал.
В самом конце описания в аксессуарах его обозвали Canbus
Старый 26.11.2017, 11:36   #503
AS21
Аватар для AS21
Правильно - китайцы провода подлкючили к рокфорду сразу
Тоже самое - они ЭТО сделали за Вас
Можете проверить: именно так подписаны эти провода в Ваше переходной китайской проводке
Жаль, но может кто другой?....
Старый 26.11.2017, 12:54   #504
Potable
Аватар для Potable
@AS21, да нет же, провода КЕЙ, ИЛЛ и иже с ними остались болтаться неподключенными.
Если Вы найдете способ реализации функционала ММЦС на ГУ, не поскуплюсь на спасибки, наверное не я один
Старый 27.11.2017, 09:33   #505
AS21
Аватар для AS21
Мне нужно от Вас подтверждение, того что
- дейсвтительно сигнал ЗХ поставляется через китайский кан бас (т.е. провод типа "Revers..." "Break..." - действительно не подключен, а камера задняя включается по сигналу ЗХ, плз
Это ОНО:
https://ru.aliexpress.com/item/Dasai...999.272.Cw0O9C
Если Вы подтвердите ЭТО - то дописать apk - которая сейчас обрабатывает Ваш сигнал - max месяц!!!
Старый 27.11.2017, 13:39   #506
AS21
Аватар для AS21
Какое у Вас авто - какого года?
Старый 27.11.2017, 20:22   #507
yanchik
Аватар для yanchik
@AS21,
У меня именно через этот канбус включается и камера и усел и кнопки на руле.
yanchik вне форума   Вверх Ответить с цитированием
Старый 27.11.2017, 20:24   #508
Potable
Аватар для Potable
@AS21, outlander XL 3.0 2007 года. Да кан похож в копейку. Фоток не нашел, но и подцепляется так же, только серого разъема у себя не помню.
Камеру ЗХ брал абсолютно стороннюю, никакого провода, кроме видео, от неё не тянул и не подключал к ГУ. И, как уже писал, Провод ИЛЛ так же не задействовал, тем не менее подсветка на ГУ включается синхронно с салонной. Проезжая тоннель, был удивлен, что навител дневной скин сменил на ночной, а по выезду - опять на дневной. Объясняю это использованием датчика освещенности через кан.
Старый 27.11.2017, 20:54   #509
AS21
Аватар для AS21
Сообщение от yanchik Посмотреть сообщение
Авто, я так понял до 2012 года выпуска?
Надо проверить кто рулит процессом: кан или напрямую подключенные провода?
1) Что написано на коробочке: Pajero или Outlander 2014
2) Проверить - кан задействован или нет легко:
2.1.) В заводских настройках:
- проверяем какой тип стоит кан (запомнили, обычно 57)
- поставьте тип кан на любой другой
2.2.) Включить ЗХ и проверить работу задней камеры
Проверять желательно со снятым ручником, он может мешать.
Если заработает - это не кан, если камера не включится
2.3. Вернуть обратно:
- в заводских тип кан 57 или тот, что был до этого
плз - проверте и мне мякните
их там два:
1) для авто до 2013 года
2) для авто после 2013 года (скорость кан 250 )
На какой похоже?
Последний раз редактировалось AS21; 27.11.2017 в 21:03.
Старый 27.11.2017, 21:02   #510
AS21
Аватар для AS21
У меня точно также работает - по проводу IIL
И кнопки без проблем по KEY1
Китайцы что угодно могут подключить
А провода у Вас свободные могут быть тоже: не было у них под рукой старой проводки, перепиновалм новую, от авто 2014 года. Как вариант - может иметь место
Текущее время: 06:28. Часовой пояс GMT +3.
