Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 27.11.2017, 21:28   #511
Potable
Аватар для Potable
По умолчанию Re: 2DIN головное устройство HA2034 на Android
@AS21, на сколько помню, у меня на канбасе ПАДЖЕРО было написано.
Можете зайти на 4рда, там про кан в том числе много написано, у Вас отпадут сомнения, что это его проделки http://4pda.ru/forum/index.php?showt...#entry67508132
Старый 27.11.2017, 21:34   #512
AS21
Аватар для AS21
Авто: ASX 1.6 2WD MT
Я это все читал
Вопос не в том, что там написано, а в том что только для моделей 2014 года было сделано общение с кан
А до этого года - только рокфорд.
Рокфорд не совсем не кан
Сделайте плз проверку, как я прошу
35$ - совсем не хотелось зря тратить, поскольку рокфорда у меня нет
AS21 вне форума   Вверх Ответить с цитированием
Старый 28.11.2017, 14:00   #513
Potable
Аватар для Potable
@AS21, сменил тип канбаса с 57 на 58 (какойто форд). Перегрузил. Камера ЗХ осталась работоспособна, подсветка тож. Вернул обратно. Т.е. от смены кана ничего не меняется. Знаю какой Вы сделаете вывод, вот не факт... Для чистоты эксперимента изъять кан, вот тогда да, но на такой подвиг пока не готов)))
Может есть какая прога, что читает из мозгов по кану?
Последний раз редактировалось Potable; 28.11.2017 в 14:06.
Старый 28.11.2017, 16:40   #514
AS21
Аватар для AS21
Нет - не надо, провода могуть тупо транзитом проходить через блок, а могут и как отдельно комутироваться
Вопрос закрыт: у Вас кан шина наша не задействована
Только для авто 2014 и младше на скрорости кан - 250
Старый 28.11.2017, 18:47   #515
ДмитрийГлаз
Аватар для ДмитрийГлаз
@AS21, А что вообще через Кан должно быть видно? Управление климатом,показание приборов(тахометр, скорость). У меня ничего из этого не видно . Скорость магнитола видит с гпс. А вот температуру на виджете снимал с инета. Так что Кан бас паджеро (у меня старый версии 1.07 ,а другой который шол с НА2034 ещё более новее,но работает так же) только для работы рокфорд и все.Увы.
Старый 28.11.2017, 19:15   #516
AS21
Аватар для AS21
С таким оборудованием, наверное более ничего
Как что-то получится, а цель увидеть скорость, зх, ручник, климат регулировки, настройки комфорта, и даже сигналы парктпонника вобщем все что есть в кан шине
А как этим воспользоваться - второй вопрос
Старый 28.11.2017, 21:05   #517
yanchik
Аватар для yanchik
@AS21,
Авто 2007,
на коробке Outlander 2014
в настроиках ставил хоть паджеро хоть аут, одинаково,даже тоиоту пробовал
камера запитана отдельно, к блоку идет только тюльпан, работает по кану 100 %
Снимал канбус, ничего не работает, ни усел ни камера ни кнопки на руле.
yanchik вне форума   Вверх Ответить с цитированием
Старый 28.11.2017, 22:07   #518
AS21
Аватар для AS21
Все правильно: кан хоть 2014-го но тоже работает как просто устройство для рофорда + через него прямые контакты по сигналам ЗХ и т.д.
Не по кану
Если бы по кану - то настройка 57 - сработала бы
Я не знаю какая частоат у Вас по кан шине. Если 250 - то можно поробовать настроить по кан..
Старый 29.11.2017, 06:52   #519
Aleks89
Сообщение от AS21 Посмотреть сообщение
Не по кану
Если не по кану то как?я могу предположить что включение камеры,света,по кан шине передаются каким то унифицированным сигналом для большинства машин.Больше в голову не чего не идет.Вы утверждаете что в колодке идут прямые сигналы на зх,свет, кнопки -тогда вопрос почему производители магнитол провода back,key не включили в основную колодку без can?
Aleks89 вне форума   Вверх Ответить с цитированием
Старый 29.11.2017, 08:31   #520
AS21
Аватар для AS21
Поймите простую вещь:
- кан имеет свои особенные настройки
-- один из них главный - скорость
-- второй не мене важный тип протокола
Если их не согласовать - Вы из кан - ничего не получите
Если Вы измениил тип кана который заложен исключительно под Ваш кан устойство и ничего не изменилось - то ЭТО означает только одно - кан не задействован
Сообщение от Aleks89 Посмотреть сообщение
Вопрос не ко мне и не к производителю, а к магазину
Мое предположение - что было под рукой - то и прислали, а как они скомутировали? Опять же вопрос к ним
Если Вам приятнее считать, что у Вас работает по кан шине - считайте так
Главное ж РАБОТАЕТ!!!
Старый 29.11.2017, 11:05   #521
Aleks89
Пришла магнитола в выходные буду ставить, провода второго без кан в комплекте нет, будем ставить так
Старый 29.11.2017, 11:06   #522
Potable
Аватар для Potable
@AS21, я доверяю своим рукам, которые не подцепляли сигнал ЗХ к ГУ, и мне проще предположить, что ГУ сама определяет тип своего же комплектного КанБаса, чем поверить, что китайцы не разобравшись, добавили кучу лишних проводков. Возможно настройка "57" нужна для общения со сторонними КанБасами (или вообще не работает, а по аналогии с елм адаптером перебирает протоколы, пока не найдет нужный, который запомнит -здесь хз конечно). Еще оставались сомнения до сообщения ув. ЯНЧИКА, в котором он описал, что без кана не работает ничего (в транзит тоже не верю). Соглашусь с Вами в главном -ГЛАВНОЕ РАБОТАЕТ.
Если Вы хорошо разбираетесь в сан-протоколах, напишите простейший код по запросу через кан, например, забортной температуры. Мы с удовольствием протестируем, может из этого чего и выйдет, да же, народ?
@Aleks89, О.о! Принимайте поздравления! По ссылке мне показалось у Вас другой экран, без крутилок. Наклейка не закрывает часть вентиляционных отверстий? Я переклеивал в др место.
Микрофон, если планируете использовать, сразу ставьте внешний. Внутренний - мучение.
Последний раз редактировалось Potable; 29.11.2017 в 11:13.
Старый 29.11.2017, 11:12   #523
Aleks89
Че то не обратил внимания гляну, спасибо)
Старый 29.11.2017, 11:14   #524
AS21
Аватар для AS21
Гадать на кофейной гуще - не мое
Я работаю на столе с конкретными устройствами, у меня Вашего пока нет и покупать кота в мешке - не вижу смысла
Проверять невозможно: ответ прост: как Вы себе ЭТО представляет? У Вас есть интерфейс для ввода команд ? Есть apk - которая принимает Ваши любые команды и посылает их в конце концов на пин 3 пин 13 (20 пиновый раьем наш, куда коннектится главный китайский провод, по схеме ASX -> C-104)?
Если кто найдет более убедительные аргументы, кроме просто "Работает" - готов обсудить
Старый 29.11.2017, 11:14   #525
Aleks89
По поводу кнопок провод вроде идет в обход кана в основной разьем, а вот какой еще управляющий провод может быть на разьеме для камеры я не понял
Текущее время: 01:35. Часовой пояс GMT +3.
