Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 05.10.2016, 10:19   #61
sergeysgs
По умолчанию Re: Общие вопросы по нештатной музыке на XL: отчеты, советы, обмен опытом...
А у меня все тушит и гасит, но до первого завода двигателя.
sergeysgs вне форума   Вверх Ответить с цитированием
Старый 05.10.2016, 10:22   #62
pinzet
Аватар для pinzet
Авто: C-Crosser 2.4 CVT
Надо лезть в заводские настройки в раздел other и внимательно пройтись по меню, возможно там есть нужная "галочка".
Старый 05.10.2016, 11:57   #63
sergeysgs
Да все галочки стоят и все работает ! но магнитола берет сигнал на регулировку яркости не с внутренних лампочек подсветки ( они как раз и управляются с датчика освещенности) , а с фар. Может в жгуте поменять пару проводочков?
Старый 05.10.2016, 12:24   #64
pinzet
Аватар для pinzet
Может по сan шине не правильно отрабатывает? Тогда надо принудительно подать сигнал от подсветки на 4й контакт в колодке гу.
Последний раз редактировалось pinzet; 05.10.2016 в 12:33.
Старый 05.10.2016, 15:06   #65
amel
Аватар для amel
В последней прошивке MCU 1.82 добавили:
- отдельную регулировку подсветки в темное время суток;
- отдельное управление выходом на сабвуфер (не путать с Рокфордом);
- заддержка на выключение при работе стартера, раньше ГУ пыталось уйти в сон;
- данные с CAN шины (климат, состояние дверей т т.д.) для разных авто, с нашими не работает.
Притухание экрана при габаритах настраивается в заводских настройках.
@pinzet, как реализована регулировка баса на саб у твоего адаптера? С кнопок на руле, как в инструкции к адаптеру?
Добавлено через 7 минут
@sergeysgs, у тебя без Рокфорда?
Последний раз редактировалось amel; 05.10.2016 в 15:14.
Старый 05.10.2016, 15:21   #66
pinzet
Аватар для pinzet
@amel, в прошивке 1.81 такие же настройки присутствуют ( только про кан шину не скажу).
Мой адаптер настраивает звук Рокфорда через внутреннее меню с помощью кнопок руля mode и трек вверх. Настройки иденгтичны штатным у ММС. Только не хватает функции автоматического поддержания громкости по скорости автомобиля.
Тип файла: pdf для RockFord CTSMT002.2.pdf (4.37 Мб, 37 просмотров)
Старый 05.10.2016, 15:23   #67
sergeysgs
Да, без рокфорда.
Ссылка на распиновку не работает, но сам поищу. А прошивка думаю ничего не решит. Надо проводки перебирать. Да шиться боюсь. Главное что бы совпало MTCD/MTCB ? и далее смело шьюсь?
Старый 05.10.2016, 15:33   #68
pinzet
Аватар для pinzet
@sergeysgs, в ссылке потерялась последняя буква f
в этой теме https://out-club.ru/board/showthread.php?t=86369
Старый 05.10.2016, 15:49   #69
amel
Аватар для amel
Сообщение от pinzet Посмотреть сообщение
Ошибся, именно 1.81
Старый 06.10.2016, 09:26   #70
Pistolero
Прошил свою HA на прошивку от 31.08.16. В меню баланса режим водителя и задние пассажиры всё Ок. При нажатии звука на переднего пассажира точка пересечения оказывается между передними сиденьями. При нажатии стандартных настроек точка находится по центру машины но смещена немного в право и звук соответственно тоже. Корректирую вручную, но после отключения (ночной стоянки) всё опять смещается по центру немного в право. У всех также и как с этим бороться?
Pistolero вне форума   Вверх Ответить с цитированием
Старый 06.10.2016, 12:28   #71
sergeysgs
У меня норм, все кроме авторегулиррвки подсветки.
Старый 06.10.2016, 14:30   #72
pinzet
Аватар для pinzet
@sergeysgs, предлагаю пару вариантов:
1. проверь настройки
2. или используй программу mtcvolume ( поиском по 4pda)
оба способа работают на моём ГУ.
мои настройки ( от датчика света ) и вариант mtcvolume :
Старый 06.10.2016, 17:55   #73
sergeysgs
О, и это всё продолжает работать после старта движка? У вас евросвет включен?
Старый 06.10.2016, 18:13   #74
pinzet
Аватар для pinzet
Евросвет постоянно.Да, всё это работает. Канбас не подключен, только проводок на ILL подсоединил. Попробуй программно через mtcvolume настройся. Для неё рут не нужен!
ps: эту прогу использую вместо штатной SVC ( система регулировки громкости звука в зависимости от скорости движения )для поддержания комфортного уровня звука.
Последний раз редактировалось pinzet; 06.10.2016 в 18:20.
Старый 07.10.2016, 09:30   #75
pinzet
Аватар для pinzet
Видео работы автояркости. https://youtu.be/fApKYdwymRo
Текущее время: 00:59. Часовой пояс GMT +3.
