The next generation Outlander compact SUV will be part of what autoten told,The car which sale can be booking from early 2013 will not only offer a range of Petrol and Diesel engine but also Plug in hybrid (PHV) version.
Autoten post a Mag-x’s generate render agian.As insider’s sources told that the car will base from PX-MiEV concept that reveal in 2009 .The car will remain the dimension around it predecessor.Expect lenth 4650 mm X width 1800 mm X height 1670 mm.Current car is offer a rear third row of seat but the next gen may be cut the rear seat to make way for battery storage.
The Petrol and Diesel ranges is still offer but the focus is on PHV version. As Mag-x said the system will be similar to the ‘Hybrid4’ system from PSA Peugeot Citroen ( A engine and EV sharing partner of Mitsubishi).Power will be a pack of 114 hp/125 Nm 4 cylinder DOHC petrol mate with two electric permanent-magnet synchronous motor that produced 80 hp.Front motor will be focus on FWD and will have primary at low and middle speed and rear motor will be use when required/Automaticly required AWD or when need more power.Including ride at high speed or when the lithium-ion battery pack’s energy falls to predetermined level.It can travel up to 30 miles or 48 km on electricity alone.
Это он?
