Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 13.11.2012, 18:32   #166
zorge799
Авто: Jeep Grand Cherokee WK2
По умолчанию Re: Замена антифриза
Кто это проверял? Переконцентрация так же снижает темп.замерзания, как и обводнение Поэтому в качестве долива (не при уходе от технической неисправности, а именно естественная усушка) рекомендуется использовать только дисц. воду.
Истинная правда!!!!
Старый 13.11.2012, 19:53   #167
divers143364
Аватар для divers143364
это смотря в какой пропорции сервисмены РАЗБАВИЛИ концентрат ... Зная наших ОД он может оказаться и 25% и 35% , Да и на канистре с концентратом допускаеться разбавление хоть до 60% . а учитывая что антифриз СМАЗЫВАЮЩАЯ жидкость для помпы и термостата а не вода хоть и дистилированная то пользы от АНТИФРИЗА уверен больше чем от ВОДЫ .
Старый 13.11.2012, 20:43   #168
zorge799
Сообщение от divers143364 Посмотреть сообщение
Ну подозревать можно кого угодно и в чем угодно... Попытаюсь объяснить, почему в ИСПРАВНУЮ систему охлаждения добавляют дистиллированную воду. Да просто потому, что основа антифриза - этиленгликоль, по сути - СПИРТ, а он всегда испаряется первым. Поэтому концентрация "спирта" в ИСПРАВНОЙ системе охлаждения все время растет, а переизбыток этого самого "спирта" и приводит, как бы это ни показалось странным, к повышению (в смысле от минус 40 до минус 35) температуры замерзания смеси. И еще: в исправной системе охлаждения (при нормальных, нетекущих сальниках) охлаждающая жидкость НИЧЕГО не смазывает!!! Иначе она бы называлась не ОЖ, а СОЖ, как в металлорежущих станках, и имела бы в своем составе масло!
Старый 13.11.2012, 21:17   #169
Timka
Аватар для Timka
Авто: Финик QX50
zorge799, ты не прав. практически по всем пунктам
Старый 14.11.2012, 00:33   #170
divers143364
Сообщение от zorge799 Посмотреть сообщение
вот почитай как раз СОЖ http://avtomarketkar-go.ru/info/antifreez-expl и вот http://www.cool-stream.ru/coolstream/10differs и вот http://www.avto3.com/operation/antifreeze.html
Старый 14.11.2012, 20:32   #171
zorge799
Ну прочел, про смазывающие свойства написано только в третьей ссылке да и то ерунда - при исправном сальнике помпы ни капли ОЖ не просачивается на подшипник, а смазывание оного происходит только за счет заложенной в него смазки. То, что ОЖ за счет присадок должна "смазывать" сальник тоже полная ерунда, ОЖ в идеале должна препятствовать его температурному старению. Кстати, общая мысль данных статей - идеальная ОЖ - это дистиллированная вода, вот только она имеет свойство замерзать....
---------- Добавлено в 20:32 ---------- Предыдущее сообщение было написано в 20:32 ----------
Например?
Старый 14.11.2012, 22:53   #172
Vlad13
Аватар для Vlad13
Сообщение от Dmetriy74 Посмотреть сообщение
...Синего цвета вообще-то тосол....
Категорически не соглашусь.
Тосол конечно тоже может быть синим, но, например, сегодня мной был приобретен концентрат антифриза G11 Ravenol и он оказался синим.
Vlad13 вне форума   Вверх Ответить с цитированием
Старый 15.11.2012, 02:29   #173
divers143364
Например?
вообщето там во всех трех статьях описывается что смазаваются подвижные элементы системы охлаждения, помпа , термостат ...повнимательнее почитай.
---------- Добавлено в 03:07 ---------- Предыдущее сообщение было написано в 02:29 ----------
ну и вот еще про СОЖ http://www.vincast.ru/news/2
Старый 15.11.2012, 20:50   #174
pilot31
Ответы на то что нужно доливать если упал уровень (ОЖ), что нельзя доливать (вода) и что лить на случай если температура ниже -30 (у меня и у многих кого читал уровень в расширительном бачке с самого начала эксплуатации находился чуть выше отметки Low и так остался на нем, наверняка это на случай долива концентрата антифриза в случае очень низких температур): http://europaa.info/guide/service/coolant/
pilot31 вне форума   Вверх Ответить с цитированием
Старый 21.11.2012, 16:55   #175
pilot31
Сомнения закрались по поводу антифриза, а именно то что рекомендуют лить Мобил G11, этот стандарт то европейский а у нас авто японское и стандарты там японские а именно JIS K2234 и как по мне то нужно смотреть именно на это а не на G11. И как я понял прочитав несколько источников японские антифризы долгоживущие (именно такой у нас залит) и изготовлены по карбосиликатной технологии. Просто срок замены наступил вот и сомнения что лить. Посмотрел ОЖ Motul Inugel Optimal вроде все в норме и стандарту JIS K2234 удовлетворяет, рекомендация Mitsubishi есть и в подборе по авто она идет, но она оранжевая, а родная зеленая. Я че кипишую, сольется при частичной замене не все и как это смешение повлияет не понятно, хотя понятно только что он станет желтым.
---------- Добавлено в 18:12 ---------- Предыдущее сообщение было написано в 15:55 ----------
Сообщение от pilot31 Посмотреть сообщение
Дабы больше не морочить себе голову заказал оригинал DIA QUEEN SUPER LONG LIFE COOLANT
Старый 23.11.2012, 11:29   #176
***ШТИРЛИЦ***
Аватар для ***ШТИРЛИЦ***
В выходные собирался поменять антифриз, но так до конца и не понял как правильно? На горячую или на холодную? Сливать из двигателя или нет?
И почему такая избирательность в выборе...стандарты, допуски? Антифриз он и в Африке антифриз (если состав одинаковый). Или я ошибаюсь?
Старый 23.11.2012, 14:45   #177
pilot31
Так можно и тосол залить , я тоже так думал какая разница, но почитав несколько источников понял что все непросто, единого мирового стандарта на антифриз до сих пор нет, отсюда вся и путаница. И как то не хочется чтобы появились хлопья в системе.
http://hondamotor.ru/board/index.php?showtopic=98563
Старый 23.11.2012, 17:53   #178
***ШТИРЛИЦ***
Хлопья могут будь от смешивания двух разных антифризов! (G11 и G12)
---------- Добавлено в 20:37 ---------- Предыдущее сообщение было написано в 17:53 ----------
Ну частично пожалуй соглашусь!
Не все йогурты одинаково полезны (с)
http://www.cool-stream.ru/mify/#9 тоже для информации, вдруг кто то как и я будет в сомнениях)
Старый 25.11.2012, 03:16   #179
pilot31
У нас скорее всего залит японский аналог WV G12+ т.к. эти антифризы в европе стали рекомендовать для автомобилей с 2001 года выпуска да и по срокам службы 4-5 лет. А если все так то в смешении с G11 или G12 нет ничего плохого, а лучше сразу лить G12+. Но это только предположение (япошек этих не понять, что они подразумевают под аналогичным) поэтому рисковать пока не буду, залью то, что написано в руководстве.
Старый 25.11.2012, 09:14   #180
SpyFox
Себе менял недавно - взял немного старой ОЖ из Бачка расширения и в морозильник... оно мля замерзло!! дела - менять нужно было и быстро.
Итак я взял 10 литров G11 антифриза. Делал так на холодном моторе слил около 3 литров ОЖ с радиатора (слева как смотреть на машину есть краник в радиаторе, но для того что бы добраться до него нужно отвинтить 4 болта и несколько клепок на зашите пластиковой у бампера) Сливать удобно при помощи шланга 30-40 см длиной диаметром около 1см. - как раз на пипку крана отл надевается.
Итак 3 литра слили, залили через крышку радиатора новой ОЖ до верху. Завели, прогрели до рабочей (открылся термостат - старое и новое смешалось).. ), прогазовали чуток.
Оять слили 3 литра (внимание горячо - но т.к. я делал с шлангом то проблем не было никаких), опять залали новый, опять прогрели, опять слили , опять залили и ... вся ОЖ новая закончилась.
Вывод около 70% ОЖ в двигателе новая, думаю достаточно.
SpyFox вне форума   Вверх Ответить с цитированием
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 06:08. Часовой пояс GMT +3.
