Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 09.07.2016, 14:18   #16
amel
Аватар для amel
По умолчанию Re: Общие вопросы по нештатной музыке на XL: отчеты, советы, обмен опытом...
@mmcrvr, http://4pda.ru/forum/index.php?showtopic=734564
Старый 17.07.2016, 14:50   #17
mmcrvr
Аватар для mmcrvr
Получил Hotaudio HA2034, поставил. Пока все нравится. Звук неплохой (Рокфорд).
Из минусов: в штатном плеере все файлы валятся в одну кучу, минимальная громкость великовата, пока не разобрался как уменьшить.
mmcrvr вне форума   Вверх Ответить с цитированием
Старый 17.07.2016, 23:12   #18
amel
Аватар для amel
Сообщение от mmcrvr Посмотреть сообщение
Звук можно убавить в заводских настройках voice system. В штатном плеере у меня все по папкам разбито. Но есть косяк, при воспроизведении с юсб-флешки и при вкл вай фай не видит папок. Я музыку записал на микро СД, с ней такой проблемы нет.
Свежая прошивка MCU и андроид
https://yadi.sk/d/Q5yAp0ZOtBEHo
https://yadi.sk/d/jO7nlS4gtBEex
Старый 18.07.2016, 10:27   #19
mmcrvr
Аватар для mmcrvr
Спасибо. Сами прошивались? Есть смысл перепрошиться?
Старый 18.07.2016, 11:34   #20
amel
Аватар для amel
@mmcrvr, да, прошил. Был тогда глюк - при включении показывает обои без ярлыков из стокового лаунчера, закономерности не нашел. После прошивки пока все хорошо.
Старый 18.07.2016, 11:49   #21
amel
Аватар для amel
Вчера еще регистратор подключил, можно смотреть записи как и через AV-вход, так и по wifi.
20160717_190307.jpg   20160717_183422.jpg   20160717_183335.jpg   20160717_183346.jpg   20160717_183551.jpg
Старый 17.08.2016, 06:02   #22
Скиталец
Поставил НА 2034. Все отлично, но вот крепление магнитолы только к панели за рамку. Как-то не внушает доверия. Если бы было как на штатной, тушка к панели.
Скиталец вне форума   Вверх Ответить с цитированием
Старый 19.08.2016, 15:17   #23
Pistolero
Поставил вчера Hotaudio HA2034 на Android 5.1.1. Из косяков - не работают кнопки на руле по CAN, но это легко решаемо, нужно соединить напрямую сигнальный провод от кнопок к KEY1 или KEY2 напрямую, в обход CAN. Рокфорд работает, звук хороший, за это больше всего боялся. Wifi встроенный, свистков не нужно. Камера заднего вида включается тоже по CAN. Пока конечно рано советовать ее, поезжу недельку, напишу отзыв, но пока все нравится, особенно экран, скорость работы, тач, полноценный хаб на 4 USB.
Покупал тут http://ru.aliexpress.com/item/8-Quad...8.0.108.xC8pLb
Доставка 6 дней! Курьер доставил домой.
Также заказал регистратор со встроенным Wifi http://ru.aliexpress.com/item/TCOL-N...08.0.56.xC8pLb
Пока не приехал.
Фото под спойлером
Небольшое видео, программ еще не ставил, все как из коробки https://youtu.be/Q6zqMk9_6pA]
Подскажите пожалуйста подойдет ли эта магнитола в замен штатной магнитолы (у меня без Рокфорд)? Разъёмы такие же?
Pistolero вне форума   Вверх Ответить с цитированием
Старый 19.08.2016, 15:25   #24
amel
Аватар для amel
@Pistolero, на Аут подходит без рокфорда. На Пыж значит тоже должна подойти. У меня в комплекте было два переходника, для Кан шины и без.
Старый 19.08.2016, 15:53   #25
Pistolero
Поюзав магнитолу несколько дней, поделюсь впечатлениями:
+ радио ловит лучше штатной + расширенный диапозон;
+ звук на уровне штатной, после настройки эквалайзера (Рокфорд);
+ кнопки на руле могут управлять сторонними плеерами, типа Power Amp;
+ хороший экран и тач, нареканий нет;
+ не тормозит, у меня SGS4 тормознее;
+ поставил CarLauncher - красота и удобно;
+ mirror link, wifi встроенный, GPS не подводил;
+ 4 USB и 2 micro sd (полноценные).
+ хорошая поддержка производителя и активный форум на 4пда.
- нет фидера перед-зад, нет отдельной настройки саба, касается рокфорда (косяк всех китайских ГУ, а именно CAN Decoder);
- не возможно переключить папки с музыкой с флешки при включенном wifi, с micro sd все ок.
- Nand flash (16 гигов) китайцы сделали отдельно, лечится кастомной прошивкой, которая перераспределяет разделы, но мне, для приложений, пока хватает и 2-х гигов.
- модуль wifi ловит хреново, на телефоне лучше. Под балконом не ловит мою сетку, тел ловит 1-2 палки. На телефоне сделал запуск точки доступа по автоматическому подключению к блютуз магнитолы, теперь все на автомате.
Вывод: за 20 т.р. очень все хорошо, денег своих она стоит. Я не жалею, хотя когда покупал, думал поюзаю месяц и продам))
Так ка живу в области (от мкада 60 км) есть проблема приема радиоэфира. На штатной магнитоле с трудом работает 2-3 станции и после покупки новой магнитолы не хотелось бы остаться без них. Есть ли опыт приема радиоэфира на таком удалении? Вы просто писали, что "радио ловит лучше штатной". Хотелось бы уточнить- помех меньше или приёмник у неё мощнее и приём уверенней?
Старый 21.08.2016, 10:18   #26
amel
Аватар для amel
@Pistolero, мне кажется радио по мощнее на китайской, ИМХО. От МКАДа 30 км, ловит более 20 станций.
Старый 21.08.2016, 12:56   #27
Primus86
Пока не приехал.
Фото под спойлером
Остановил было уже свой выбор на Winka s160 но тут увидел эту модель а она напорядок дешевле стоит а характеристики те же заявлены. Посоветуйте плз какая штатная голова лучшая на сегодняшний день на аут 3.0 с рокфордом? Плюс планирую круговой обзор заказывать, какой к нашему авто лучше всех крепится?
Primus86 вне форума   Вверх Ответить с цитированием
Старый 21.08.2016, 14:55   #28
mmcrvr
Аватар для mmcrvr
Сообщение от Скиталец Посмотреть сообщение
После установки магнитолы завелся сверчок. Снял дефлекторы, в движении обнаружил, что тушка прилично болтается, и при удержании ее рукой сверчок замолкает. Решил использовать штатные крепления от родной магнитолы. Закрепил их к панели, затолкал новую магнитолу, фломастером отметил положение (ориентир по глубине: кронштейн прижимается к передней панели магнитолы и параллелен ей. см. фото) Пришлось немного подпилить крепления, чтобы винтики попали на существующие отверстия в новой магнитоле. Закрепил кронштейны к панели только снизу, вверху висят на штырьках (трудновато добраться винтик закрутить, снизу без проблем) Держится все крепко.
Старый 22.08.2016, 12:55   #29
Primus86
Ну ребята подскажите, заказывать пора, эта модель 2034 ничем не хуже сВинки с160? Или если есть возможность переплачивать за Винку? Китайцы ответили что с180 снята с продажи вначале года, так как можель не пользовалась популярностью в продажах
Старый 22.08.2016, 13:05   #30
mmcrvr
Аватар для mmcrvr
Сообщение от Primus86 Посмотреть сообщение
Чтобы ответить, необходимо попользовать обе магнитолы.
У 2034 андроид посвежее, внешний вид ближе к штатной, встает ровно, пластик как родной. Ну и цена. На Винку я долго присматривался, в результате взял 2034.
Текущее время: 19:12. Часовой пояс GMT +3.
