Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 03.08.2018, 11:40   #586
borisov383
Аватар для borisov383
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Сообщение от tvik Посмотреть сообщение
Приобрел HA2034-V840
Не видит USB штатный в подлокотнике
Неродная магнитола его и не увидит, т.к. с завода USB-кабель (тот, что в подлокотнике) идет из оригинального блока bluetooth/usb, который в свою очередь работает совместно только с родными магнитолами.
borisov383 вне форума   Вверх Ответить с цитированием
Старый 03.08.2018, 14:18   #587
tvik
Аватар для tvik
Авто: Стремительный домкрат
@borisov383, связался с продавцом MTKNAVI Store.
hi. friend. the USB adaptor is not included in the package . if you need it , it need to pay 6 USD .
because some of outlander does not have this arm rest USB port, so we do not include it in the price of the android unit
best regards
tvik вне форума   Вверх Ответить с цитированием
Старый 03.08.2018, 14:26   #588
Potable
Аватар для Potable
Эт нужно еще понять, о каком адаптопе речть. У магнитолы есть уже несколько юсб сосок. Что мешает одну из них использовать для установленного в подлакотнике разъема?
Старый 03.08.2018, 14:48   #589
tvik
Аватар для tvik
Спросил у них ссылку на товар, пока молчит
Старый 05.08.2018, 16:30   #590
tvik
Аватар для tvik
Провод GND обязательно на массу кидать? Без него вроде всё работает ...
Старый 06.08.2018, 18:42   #591
Potable
Аватар для Potable
Массы много не бывает. ИМХО
Старый 24.08.2018, 13:00   #592
VISk
На днях НА2034 жестко завис и не выключался пока не скинул клему с аккумулятора. При последующем включении он сам сделал заводское восстановление и все настройки слетели. Теперь не могу настроить кнопки руля. Запускаю програмку "кнопки руля", а там только пустой экран и две надписи "сброс" и "запомнить". В разделе "заводских настроек" выбрана кан-шина - #57 outlander, вроде правильно.
Как настроить кнопки руля - не могу сообразить ? Подскажите кде копнуть...
VISk вне форума   Вверх Ответить с цитированием
Старый 25.08.2018, 05:29   #593
VISk
Уже попробовал по порядку всё, что делал раньше. И заново убирал и устанавливал кан-шину, конечно каждый раз перегружал устройство. И опять делал рекавери. Тщетно. Видимо только перешивать..
Старый 27.08.2018, 21:47   #594
Potable
Аватар для Potable
А там разве сначала не нужно нажать кнопку на руле что бы на пустом экране появилось чего? Не помню просто уже..
Старый 28.08.2018, 14:51   #595
amel
Аватар для amel
Сообщение от VISk Посмотреть сообщение
Кнопки на руле резистивные, кан-шина для их работы не нужна.
Старый 29.08.2018, 06:36   #596
VISk
Нажимаю кнопки, но ни чего вообще не происходит. Захожу в настройки кнопок, но там нету картинок с кнопками. Щас по порядку - что было:
- после автоматического восстановления Андроида всё сбросилось и кнопки перестали работать,
-стал настраивать: выбрал язык, шину, время и т.п., а когда зашел в раздел кнопок на руле то нужно было нажимать кнопку на экране , а затем кнопку на руле.
- А я машинально нажал сверху кнопку "сброс" и окошки с кнопками на экране пропали. И вот теперь не могу вернуть их....
Может кто знает какой файлик конфигурации удалить, чтоб всё опять сбросилось ?
Пробовал вернуть заводские - не помогло , пробовал прошить с галкой вайп дата - не помогло. Нет кнопок и всё. Подскажите что можно ещё попробовать ?
Старый 29.08.2018, 06:49   #597
VISk
Может не в тему , простите, но тут поднимался вопрос о видеорегистраторе... Когда искал видео-регистратор, то пришла в голову шальная мысль - а что если вместо него использовать китайскую камеру типа Go-Pro. Мне как то подарили и используется она пару раз в году. Что имеем ЗА:
1 - качество отличное и днём и ночью, реальный FullHD, они даже 4К есть.
2 - обзор 170 грд., датчик удара, лок записи, долгая батарейка и всё такое.
3 - включается автоматически при подаче питания, ни каких манипуляций.
4 - маленькая, легкая, есть экран, автономная, работает с большими флешками.
В общем очень неплохой видео-регистратор и к тому же бюджетный. А ещё универсальность - его можно всегда снять в поездке и использовать по назначению. Из минусов - я нашёл только один - нет и не предусмотрено крепления под кронштейн. Но эту проблему я легко решил без всяких переделок и шаманства. Использовал зажим от селфипалки. Это самое ОНО. Прикручивается на кронштейн как родной и держит превосходно. И при этом всегда можно быстро снять и использовать вне авто. Да и сама селфипалка не пострадала - лежит в бардачке. Когда нужно, то можно легко всё восстановить и использовать по назначению.
Как то так...
Старый 29.08.2018, 12:45   #598
Potable
Аватар для Potable
@VISk, Вы же сами и ответили:МОЖНО!…))) где-то даже попадалось про использование го-про как видеорегистратора. Сам чуть было не склонился к этой мысли, но отвлекся и купил другой.
Датчик удара только имхо отключить нужно, забьется фдешка нестираемыми файлами оч быстро
Старый 29.08.2018, 20:08   #599
VISk
Дк я как раз её и использую и очень доволен. Потому и рекомендую, а там в тексте был риторический вопрос...
Старый 04.09.2018, 09:25   #600
VISk
Нашел решение своей проблемы с кнопками на руле. Не поленился подключить родное ГУ и убедился , что и там кнопки не работают. Фатальное совпадение - сбой в работе андроида ГУ и перелом подрулевого шлейфа. Хотя может это и как то взаимосвязано... Шлейф под замену.
Текущее время: 11:43. Часовой пояс GMT +3.
