Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 25.05.2012, 15:44   #136
Timka
Аватар для Timka
Авто: Финик QX50
По умолчанию Re: Замена антифриза
Это же не тосол, чтоб его так часто менять. Новые лонг-лайф антифризы вполне свободно живут 5 лет.
Старый 25.05.2012, 16:00   #137
Zux
Временно никто
Авто: Lancer GT 2.4
G12 как в VAG сейчас да, наш гликолевый G11 нет, 2-3 года.
Zux вне форума   Вверх Ответить с цитированием
Старый 25.05.2012, 16:37   #138
Timka
Аватар для Timka
Авто: Финик QX50
Какой же он тогда супер лонг лайф? Вроде ж гликолевый - это синий, а у нас зелёный... или я чего-то путаю?
Старый 25.05.2012, 16:47   #139
Dmetriy74
Аватар для Dmetriy74
Авто: Outlander XL 3.0 MIVEC S64
По регламенту 60 тык. Замена. Дальше решает каждый сам. По времени это у меня 2 года. Мне подходит.
Dmetriy74 вне форума   Вверх Ответить с цитированием
Старый 26.05.2012, 13:48   #140
Yaboss
Так получилось что есть у меня 5л красного антифриза Мобил. Хочу заменить, с провывкой водой, но все равно в системе немного останется. Как думаете можно ли их смешивать?
Yaboss вне форума   Вверх Ответить с цитированием
Старый 26.05.2012, 17:00   #141
Dmetriy74
Сообщение от Yaboss Посмотреть сообщение
ППЦ! А как так получилось-то. Мойте не водой, а дистиллятом.
---------- Добавлено в 17:01 ---------- Предыдущее сообщение было написано в 17:00 ----------
Красный после зелёного лили же? Нормально?
Старый 26.05.2012, 17:24   #142
Yaboss
Не так немного поняли!!!! Красный у меня остался от предыдущей машины. Хотел на ней менять да не успел- продал.
Про промывку дистилятом я знаю. Вопрос в другом!!! Как смешивается родной антифриз с красным??
Старый 26.05.2012, 17:33   #143
Dmetriy74
Никак.
Старый 26.05.2012, 18:25   #144
Timka
Аватар для Timka
Авто: Финик QX50
Не фатально. А промыть можно и обычной водой, если до кипения не доводить.
Старый 26.05.2012, 18:36   #145
Dmetriy74
Не фатально, не экстремально...Ты себе красный льешь?
Старый 26.05.2012, 18:42   #146
Timka
Аватар для Timka
Авто: Финик QX50
Да, залил. Ровно половину емкости - остальное был зелёный.
Точнее не я залил, а... но все равно других вариантов не небыло.
Даже проездил так пару тысяч.
но не в том суть, а в том, что если слить все, то проблемы мало вероятны. А если еще и водой промыть - то практически исключены.
Старый 27.05.2012, 12:23   #147
Yaboss
Главное чтобы осадок не появился. Завтра поеду к знакомому который занимается автожидкостями, устрою допрос.
Старый 11.07.2012, 10:58   #148
Kabakoff
По умолчанию Антифриз "Long Life Coolant"
Друзья, прошу помочь.
Заказываю на екзисте расходники для ТО 60, вопрос срочный по антифризу
вот это Антифриз "Long Life Coolant", 4л MZ 311986 подойдет если брать 2 канистры ?
Смутило то, что в интернете на иностранном сайте написано что это уже разбавленный и для использования при температурах выше минус 15 градусов, у нас зимой естественно бывает и -30. Можно ли его брать если нет, то какой нужно.
Заранее благодарю за оперативный ответ.
---------- Добавлено в 12:33 ---------- Предыдущее сообщение было написано в 10:58 ----------
да, изначально в бачке бултыхался зеленый.
Из форума понял что льют и Antifreeze NF, и Mobil extra и чего только не льют.
все же хотелось бы узнать что лить (да , в бачке изначально был залит какой то зеленый, можно ли его мешать с мобил экстра ? который как мы знаем синий или розовый).
Kabakoff вне форума   Вверх Ответить с цитированием
Старый 11.07.2012, 12:47   #149
alex888
Стрелка Re: Антифриз "Long Life Coolant"
Достаточно одной канистры.Это концентрат,разводится 50 на 50 с дистилированой водой, будет до -36 град,на банке есть вся инфа.
alex888 вне форума   Вверх Ответить с цитированием
Старый 10.08.2012, 12:33   #150
su8
Подскажите правильный код Dia queen super long life (концентрат) для смены на 2.4 л из нижних, а то путаница с последними двумя (один long life, другой super)
MZ381032
Mitsubishi DiaQueen Super Longlife Coolant (2 литра) — антифриз для автомобилей Мицубиши
MZ381033
Mitsubishi DiaQueen Super Longlife Coolant (4 литра) — антифриз для автомобилей Мицубиши
0103045
Mitsubishi Longlife Coolant (4 литра) — антифриз для автомобилей Мицубиши
MZ311986
Mitsubishi Longlife Coolant (4 литра) — антифриз готовый для автомобилей Мицубиши зеленого цвета
MZ311986
Mitsubishi DiaQueen Super Longlife Coolant (3,8 литра) — Концентрат антифриза для автомобилей Мицубиши
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 08:06. Часовой пояс GMT +3.
