Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1.warning When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap. 2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>. 3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3> 4.Remove the radiator condenser tank and drain the coolant. 5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area. 6.Connect the cooling water line hose. <4B1> 7.Connect the water feed hose B. <6B3> 8.Securely tighten the radiator drain plug. 9.Reinstall the radiator condenser tank. 10.caution Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
Quantity:
7.5 L <4B1>
9.5 L <6B3>
(including 0.65 L in the radiator condenser tank)
note For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely. 12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line. 13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks. 15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port. 16.Tighten the radiator cap securely. 17.caution Do not overfill the radiator condenser tank.
Подскажите правильный код Dia queen super long life (концентрат) для смены на 2.4 л из нижних, а то путаница с последними двумя (один long life, другой super)
MZ381032
Mitsubishi DiaQueen Super Longlife Coolant (2 литра) — антифриз для автомобилей Мицубиши
MZ381033
Mitsubishi DiaQueen Super Longlife Coolant (4 литра) — антифриз для автомобилей Мицубиши
0103045
Mitsubishi Longlife Coolant (4 литра) — антифриз для автомобилей Мицубиши
MZ311986
Mitsubishi Longlife Coolant (4 литра) — антифриз готовый для автомобилей Мицубиши зеленого цвета
MZ311986
Mitsubishi DiaQueen Super Longlife Coolant (3,8 литра) — Концентрат антифриза для автомобилей Мицубиши
Для нас идеальный вариант DiaQueen Super Longlife Coolant MZ381032 и MZ381033 Made in Japan (именно такой с завода залит и рекомендован руководством по эксплуатации), но если заказывать через инет то идти будет недели 3-4 если не больше.
Я нечего так и не понел как правельно поменять ОЖ на XL 2.4 В инструкции написано на холодную и сливать через радиатор, но как сказано выше сольется не больше половина с бочком, поэтому тоже вопрос как правельно решить?
какого цвета MZ381032
Mitsubishi DiaQueen Super Longlife Coolant (2 литра) — антифриз для автомобилей Мицубиши?
у меня пробег 50 т. жидкость в бочке синяя. Нужно долить...
официалы при смене и доливке используют МОБИЛ ЭКСТРА концентрат СИНИЙ . смело доливай его, хорошее качество и продается везде ,
при доливке не поленись и проверь уровень антифриза в радиаторе а не только в расширительном бачке (на холодную)
Антифриз я еще не менял, значит у меня залит родной заводской? Так вот и хочется понять, что залито? У кого зеленый с завода, у кого синий, непонятно.
Mitsubishi DiaQueen Super Longlife Coolant все же какого цвета?
В руководстве по эксплуатации рекомендован именно он...
Так все же интересно почему с завода у кого синий у кого зеленый антифриз залит?
у меня синий, значит мобил мне в японии налили? Совневаюсь... машина японской сборки.
Те которые собраны в калуге может и ездят на синем мобиле...
У кого как?
У кого как?
Первый раз про синий вообще слышу. В радиатор заглядывали? А что в процессе эксплуатации доливали?
Ну тогда Вам у ОД нужно выяснить, что там залито. Митсу рекомендует лонг лайф куин, а он зеленый. Синего цвета вообще-то тосол. Звоните ОД, в общем. Гляньте все же в радиатор, может бачок так цвет искажает.
здесь на форуме писали что родной 30 градусный и если залить литр концентрата то будет только лучше .
Кто это проверял? Переконцентрация так же снижает темп.замерзания, как и обводнение Поэтому в качестве долива (не при уходе от технической неисправности, а именно естественная усушка) рекомендуется использовать только дисц. воду.
