Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 02.07.2014, 15:31   #331
ДмитрийГлаз
Аватар для ДмитрийГлаз
По умолчанию Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
Сообщение от AlexeUSS Посмотреть сообщение
Сегодня с утра обнаружил антифриз на нижнем уровне, пробег 31500
Позвонил ОД, сказали льют готовый зеленого цвета Mitsubishi MZ320291.
У меня тоже когда холодный двиг. то на нижнем,как прогреется на верхнем уровне.Может пробка конечно,но зимой печка хорошо грела.Антифриз залит синий мобил(в любом магазине, полно если понадобиться вдруг на долив)
Старый 02.07.2014, 19:07   #332
zorge799
Авто: Jeep Grand Cherokee WK2
"Просто добавьте воды" (реклама Инвайт), в вашем случае - дистиллированной. Серьезно!
Старый 17.07.2014, 13:34   #333
devildozen
Если залить такой антифриз http://www.hondacarmine.ru/antifreeze-honda ????
Ничего не произойдет???
У меня есть его около 10 литров.
Авто Peugeot 4007 пробег 70000 км, антифриз не меняли еще.
Надо промывать или нет?
devildozen вне форума   Вверх Ответить с цитированием
Старый 22.07.2014, 19:15   #334
devildozen
Ответьте кто-нибудь!!! Очень нужен ответ!!!
Можно заливать этот http://www.hondacarmine.ru/antifreeze-honda антифриз или нет?
Артикул: 08CLAG018L0
Описание:
Оригинальная готовая охлаждающая жидкость Honda Pro. Антифриз Хонда Про полностью готов к работе.
Используется для охлаждения ДВС Honda, защиты от коррозии, работает при температурах не ниже -36 С.
Антифриз Honda Pro, готовая к работе охлаждающая жидкость (ready to use). Не допускается разбавление водой и другими жидкостями. При полной замене необходимо полностью промыть систему для увеличения срока службы охлаждающей жидкости. Поставляется канистрой пять литров.
Если можно, то нужно ли промывать???? Или он совместим с родным, который с завода льют в Peugeot 4007???
Старый 31.07.2014, 19:04   #335
devildozen
Вообщем сегодня поменял 10 литров - залил с помощью установки http://www.youtube.com/watch?v=8vCDc4IRUSc. Без промывки.
Старый 31.07.2014, 23:09   #336
-Insider-
Аватар для -Insider-
Бред, имхо.
Обычным способом не хуже.
-Insider- вне форума   Вверх Ответить с цитированием
Старый 01.08.2014, 00:05   #337
devildozen
Сообщение от -Insider- Посмотреть сообщение
Бред, имхо.
почему?
Старый 01.08.2014, 09:25   #338
-Insider-
devildozen, Во-первых скептически отношусь ко всяко рода промывкам (потому как неизвестно чего больше пользы или вреда). Во-вторых, опять же по моему мнению не так критично если останется в системе чуть старой жидкости.
Ну и в-третьих и самое главное представляется достаточно все это геморно, даже смотреть устал этот ролик, и еще раздражало постоянное повторение этой фирмы)))
Старый 01.08.2014, 20:55   #339
devildozen
ну ролик конечно меня тоже убил))))
Старый 06.08.2014, 16:26   #340
-Insider-
ОД по моему вин сказал что у меня с завода мобил1экстра синий, хотя в мануале жидкость митсу и на вид она зеленая, савсем не пойму...
Позвонил другому ОД сказали совсем иначе - жидкость митсу, но какой код не назвали (говорят не должны называть).
Один раз уже чуть доливал воды год назад, сейчас опять после пекла упало до мин.
может опять водички плеснуть?
Последний раз редактировалось -Insider-; 06.08.2014 в 16:51.
Старый 06.08.2014, 17:00   #341
-КОТ-
Авто: XL 3.0 Glance Edition
Если не пришел срок замены ОЖ то конечно воды, утечек же небыло, просто вода испарилась. Ну и для самоуспокоения плотность измерить.
Старый 10.08.2014, 18:47   #342
Kalalay
Аватар для Kalalay
Всем привет.Уровень охлаждающей жидкости на min,цвет зеленый.Антифриз mobil antifreeze extra (G11) сегодня искал,не нашел.Можно долить дистиллироованной воды до уровня?В Ашане продается вот такой http://s008.radikal.ru/i303/1408/78/2fbbba6352eb.jpg ,кто нибудь использовал ?На зелёной канистре написано, что подходит для Митсубиси и БМВ.
Kalalay вне форума   Вверх Ответить с цитированием
Старый 18.09.2014, 22:13   #343
AndreyDAR
Аватар для AndreyDAR
Авто: Outlander XL 3.0 Max
для информации:
Оригинальная ОЖ в черных канистрах от Рольф - готовая к заливке. Температура замерзания - минус 50С. Мешают с дистилированной водой 4+1 - температура замерзания получается около минус 40С.
MZ320291 - 1 л;
MZ320292 - 4 л.
Последний раз редактировалось AndreyDAR; 18.09.2014 в 22:19.
Старый 08.10.2014, 00:04   #344
zemliak
Ребят а кто-нибудь пользовал зеленый антифриз фирмы Chevron америка,продавец сказал что это единственный производитель антифриза, типа остальные у него берут и свои марки клепают, а то собрался радиатор менять заодно систему промыть, оригинала в продаже нет(санкции наверно), начитался форума и http://www.cool-stream.ru/pravda_ozh и засомневался
zemliak вне форума   Вверх Ответить с цитированием
Старый 08.10.2014, 07:57   #345
-КОТ-
Сообщение от zemliak Посмотреть сообщение
Скорее всего продавец спутал/соврал/ с фирмой BASF и c его Glysantin, хотя может и Шеврон сам производит, но тогда он точно не единственный
п.с. если меняешь радиатор и промываешь всю систему - бери кул стрим премиум, очень зачетный не дорогой карбоксилатный антифриз.
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 19:55. Часовой пояс GMT +3.
