Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 17.11.2017, 17:42   #511
lux_067
По умолчанию Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
Подскажите, антифриз mz311986 это готовый антифриз или концентрат?
lux_067 вне форума   Вверх Ответить с цитированием
Старый 17.11.2017, 17:53   #512
Bearing
Сообщение от lux_067 Посмотреть сообщение
концентрат?
пост 150
https://out-club.ru/board/showthread.php?t=4210&page=10
Bearing вне форума   Вверх Ответить с цитированием
Старый 17.11.2017, 18:29   #513
lux_067
в 149 посту написано что это концентрат, а в150 что готовый антифриз....
У меня на банке написано "Long Life Antifreeze Coolant" (3,78 L)
Старый 17.11.2017, 18:33   #514
Bearing
https://www.oem-oil.com/antifriz-kon...e-coolant.html
Старый 17.11.2017, 18:38   #515
lux_067
Огромное СПАСИБО за информацию!!!
Добавлено через 59 секунд
А не подскажите, дистиллированную воду можно любую брать? Например в аптеке купить?
Старый 17.11.2017, 19:30   #516
Potable
Аватар для Potable
@lux_067, да, любую. Главное чтоб не паленую (из под крана)... а то по ящику показывали, что в Мск и до этого додумались.
Старый 09.02.2018, 13:50   #517
Mishka3d
Добрый день.
Подскажите конкретно и понятно. Уровень жидкости на минемуме, открываю пробку радиатора цвет синий.
Надо долить. Что купить? и долить? есть парт номера
Mishka3d вне форума   Вверх Ответить с цитированием
Старый 09.02.2018, 14:25   #518
-КОТ-
Авто: XL 3.0 Glance Edition
Дистиллированной воды.
Старый 09.02.2018, 14:53   #519
Mishka3d
Сообщение от -КОТ- Посмотреть сообщение
Это понятно.
А именно антифриз
Старый 09.02.2018, 15:38   #520
KugaS
Аватар для KugaS
Сообщение от Mishka3d Посмотреть сообщение
Добрый день.
Я бы полностью поменял.
Старый 09.02.2018, 15:42   #521
Mishka3d
Да это понятно. Щас просто долить нада и до тепла кататься. А там можно колдовать самому во дворике при тепле
Старый 09.02.2018, 17:31   #522
Mishka3d
По умолчанию Re: Замена антифриза
Сообщение от divers143364 Посмотреть сообщение
официалы при смене и доливке используют МОБИЛ ЭКСТРА концентрат СИНИЙ . смело доливай его, хорошее качество и продается везде ,
при доливке не поленись и проверь уровень антифриза в радиаторе а не только в расширительном бачке (на холодную)
его просто добавлять? или разбавить нада?
Старый 09.02.2018, 19:08   #523
FeltseR
Аватар для FeltseR
Добрый день.
Мне официалы объяснили, что уровень антифриза на горячую должен быть не выше максимума. На холодном у меня уровень на минимуме или чуть ниже. На горячую по середине.
FeltseR вне форума   Вверх Ответить с цитированием
Старый 10.02.2018, 07:47   #524
-КОТ-
Это понятно.
А именно антифриз
Если не знаешь какая точно залита ОЖ - менять полностью или доливать воды. Цвет ОЖ это всего лишь краситель, состав может быть абсолютно разным. Дольешь ож другого состава и от этого компота может случиться все что угодно.
Если небыло утечек, значит выкипела вода, долить дистиллировки и не парить себе мозг. Даже если вытекла ОЖ, от дополнительного литра воды ваще ничего страшного не случиться.
Старый 10.02.2018, 10:44   #525
Mishka3d
Сообщение от FeltseR Посмотреть сообщение
ХМ интересно. Вчера специально прогрел по полной, погонял немного остановился посмотрел на прогретую по середине стоит. Получается я просто паникую Спасибо
Да спасибо. По лету полностью заменю. а щас понаблюдаю за уровнем
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 06:04. Часовой пояс GMT +3.
