Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 20.09.2010, 19:31   #91
Ninegr
Аватар для Ninegr
По умолчанию Re: замена антифриза
Ребятки вы че чудите, какой краник, какой хомут!
Довести уровень до МАХ. прогреть до срабатывания вентилятора, ВСЕ!
Извиняюсь сразу не понял про какую пробку, есть там пробка на радиаторе в низу,а на блоке вроде нет!
Ninegr вне форума   Вверх Ответить с цитированием
Старый 29.11.2010, 15:22   #92
polimet
По умолчанию Re: Замена антифриза
Вчера самостоятельно менял антифриз на Ауте ХL 3.0. Делал следующее. Снял защиту и пластиковый низ бампера. Справа внизу на радиаторе краник. Выкрутил наполовину, антифриз сливается тонкой струйкой через опору радиатора строго вниз (грамотно сделано). Вылилось примерно 4 литра (всего в системе 9,5 л). Далее находим пробку на блоке. С фонариком. Становимся снизу перед масляным фильтром. Пробка слива (болт на 14) на 20 см левее масляного фильтра (чтобы было удобнее я снял масляный фильтр). Ключ надо длиной см 25, чтобы сдернуть болт с места, далее лучше скручивать рукой.
polimet вне форума   Вверх Ответить с цитированием
Старый 30.11.2010, 16:15   #93
isolo
По умолчанию Выдавливает антифриз из пробки радиатора
Добрый день всем!
В октябре, заливая водичку в омыватель, обратил внимание на следы антифриза за крышке двигателя и верхе радиатора. Поехал в Рольф. Они посмотрели, сказали раз перегрева нет, давайте все вытрем, может быть лишнее из радиатора просто вылезло, покатайтесь посмотрите.
В воскресенье глянул еще раз - опять следы высохшего антифриза (поменьше) и висит капелька на пробке на радиаторе (на улице было -9 однако). Записался опять к дилеру, гарантия через полмесяца заканчивается
Уровень в норме, антифриз менялся на 60 тыс при ТО, сейчас 72 тыс.
От чего такое может быть?
Заранее спасибо.
isolo вне форума   Вверх Ответить с цитированием
Старый 30.11.2010, 16:32   #94
YesYes
Аватар для YesYes
По умолчанию Re: Выдавливает антифриз из пробки радиатора
Сообщение от isolo Посмотреть сообщение
Например: неисправность пробки радиатора.
Старый 30.11.2010, 16:45   #95
isolo
Пробка герметична, смотрел. Она у меня отличается от той, что на картинке по ссылке - у нее есть носик, как у чайника, с дырочкой. Я смотрел у приятеля на аналогичной машине - у него ГЛУХАЯ круглая пробка. А у меня с носиком Что за фигня не знаю, может модифицированная.
Старый 30.11.2010, 17:09   #96
YesYes
Аватар для YesYes
Это на глазок не определяется.
1.Use the following special tools to check the radiator condenser tank cap valve opening pressure.
Radiator cap tester (MB992193)
A: Radiator cap tester
Radiator cap tester adapter set (MB992190)
A: Radiator cap tester adapter
2.note Be sure that the cap is clean before testing. Rust or other foreign material on the cap seal will cause an improper reading.
Use the special tool (MB992190) to attach the radiator condenser tank cap to the special tool (MB992193).
3.Increase the pressure until the indicator of the gauge stops moving.
Standard value: 93 - 123 kPa
4.If not within the standard value, replace the radiator condenser tank cap.
Для 2,4 и 3,0 по каталогам крышки одинаковые.
Оригинал - Артикул MR 481252 - Крышка радиатора - от 405 руб.
Неоригинал - Артикул J1545002 - Крышка радиатора -от 160 руб. (Производитель Jakoparts (Nipparts)).
Старый 27.02.2011, 12:55   #97
Se7
Авто: Outlander 2.0 DI-D
имел подобное. Микродырка в посуде для антифриза.
Se7 вне форума   Вверх Ответить с цитированием
Старый 15.11.2011, 15:43   #98
natalia2244
По умолчанию Re: Уходит Антифриз.
Подскажите пожалуйста какой нужен антифриз и какой?
natalia2244 вне форума   Вверх Ответить с цитированием
Старый 15.11.2011, 16:43   #99
AndreyDAR
Аватар для AndreyDAR
Авто: Outlander XL 3.0 Max
Доливайте только антифриз, причем или синий или зеленый. Красный нельзя, они с другими характеристиками.
Тормозуху также любую, главное чтобы была маркировка DOT-4.
Оф. дилеры заливают антифриз и торм. жидкость Mobil.
AndreyDAR вне форума   Вверх Ответить с цитированием
Старый 23.11.2011, 18:09   #100
vladika
Аватар для vladika
Авто: Outlander III 2.0 MIVEC Intense+ 4WD
Купил вчера антифриза Мобиловского, блин ну внатуре на цвет хрен угадаешь, открыл крышку радиатора он зеленый прям явно зеленый капнуло на патрубок зелененький такой, купил смотрю вроде тоже зеленый на банке тоже следы были зелененькие. начал лить вроде синий капец ни хрена не поймешь, долить то блин пршлось всего грамм 150 а купить аж литр и еще дестиляровки аж 1,5л. теперь стоит все хрен знает когда пригодиться недеюсь не пригодится))), вообщем завел макс. уровень держит все ОК и хорошо.
---------- Добавлено в 22:10 ---------- Предыдущее сообщение было написано в 22:09 ----------
Сообщение от AndreyDAR Посмотреть сообщение
По поводу ОД они сами не знают что там на заводе льют т.к. они сами говорят а на хрена нам знать мы же не доливаем мы меняем а производителем согласовано то то и то то вот и все.
vladika вне форума   Вверх Ответить с цитированием
Старый 27.11.2011, 21:33   #101
Dbyb
Аватар для Dbyb
У нас дилеры говорят G12, и какой тогда лить G11 или G12
Dbyb вне форума   Вверх Ответить с цитированием
Старый 29.11.2011, 17:20   #102
М А О
Аватар для М А О
Сообщение от Dbyb Посмотреть сообщение
G11
М А О вне форума   Вверх Ответить с цитированием
Старый 02.12.2011, 00:19   #103
CTX
Аватар для CTX
Сегодня прошел ТО60000. Указал мастерам что уходит антифриз. Протечек не обнаружили, но на свечах оказался какой-то налет который говорит о том что двигатель работает в режиме высоких температур (трасса, высокие скорости, высокие обороты) и из-за высоких температур вода из антифриза выкипает.
CTX вне форума   Вверх Ответить с цитированием
Старый 02.12.2011, 21:04   #104
mrDrager
Аватар для mrDrager
Сообщение от CTX Посмотреть сообщение
это фантастика
mrDrager вне форума   Вверх Ответить с цитированием
Старый 03.12.2011, 18:41   #105
Чужеземец
Аватар для Чужеземец
Система на Ауте не герметична, через расширительный бачок испаряется. Думаю ,что это в норме. ИМХО
З.Ы. Вспомните системы др. машин, они герметичны,там испарения почти нет. Как-то так. Поправте если не прав
Чужеземец вне форума   Вверх Ответить с цитированием
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 15:51. Часовой пояс GMT +3.
