Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 17.02.2014, 20:23   #301
bkmz85
Аватар для bkmz85
Авто: OUT IV 2.4 ULTIMATE & С4 Aircross 2.0 CVT
По умолчанию Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
А мне на ТО при замене залили Febi 22268
bkmz85 вне форума   Вверх Ответить с цитированием
Старый 17.02.2014, 20:24   #302
bkmz85
Аватар для bkmz85
Вот такой:
Старый 18.02.2014, 19:12   #303
martinleo
Аватар для martinleo
Антифриз G11 бывает как синего так и зеленого цвета. Смешивать можно.
Сообщение от Dmetriy74 Посмотреть сообщение
. Синего цвета вообще-то тосол.
martinleo вне форума   Вверх Ответить с цитированием
Старый 05.03.2014, 11:35   #304
Wayfarer
Дразья, привет! Помогите разобраться с дилемой. Имеется 10 литров антифриза (Органического) для строительной техники от производителя, по качеству уверяют что в разы лучше этиленгликолевого(их же производства, ну понятно что сама фирма антифриз не делает, но все же). Хочу после замены грм залить его-вопрос вот в чем, сколько на нем можно ездить? как на лонг лайфах -5лет или же 2-3 года и гудбай?
Wayfarer вне форума   Вверх Ответить с цитированием
Старый 06.03.2014, 11:28   #305
ДмитрийГлаз
Аватар для ДмитрийГлаз
Сообщение от Wayfarer Посмотреть сообщение
Глянь сначала на ценник радиатора,радиатора печки и помпы, а затем реши для себя стоит ли лить туда что нибудь другое.
Старый 06.03.2014, 11:51   #306
bkmz85
Аватар для bkmz85
Wayfarer, мне кажется лучше не рисковать. Не столько антифриз хороший (mobil, febi ...) стоит , чтобы от него отказываться. А хватает его минимум на 45 тыс. км.
Старый 06.03.2014, 21:08   #307
Wayfarer
Я не на столько силен в химии, но карбокислатные антифризы менее агресивны к металу чем этиленгликоль. Да и металлы нашей печки и помпы и.т.д не сильно отличаются от металлов импортных бульдозеров,погрузчиков, экскаваторов и самосвалов. Просто есть кто на карбокислатных антифризах? Мобил, Феби? Зачем когда есть AVIA?
И еще я не так давно в этом клубе, но уже замечаю некую тенденцию-чем дороже машина тем больше люди боятся экспериментов, но без эксперементов нет открытий! В турер в клубе(в котором я до сих пор состою) как то больше люди пробуют. эксперементируют, я никого не осуждаю! Просто мысли вслух.
Но все же всем спасибо за высказанные мнения!
Последний раз редактировалось Wayfarer; 06.03.2014 в 21:14.
Старый 06.03.2014, 22:27   #308
Leo-sun
Аватар для Leo-sun
У меня есть знакомый, он работал трактористом. В свою Оку заливал сэкономленный автол. Эксперимент продолжался до тех пор пока мотор однажды не стуканул. Он долго удивлялся, почему же это произошло? Как такое случилось, ведь автол был замечательный, он сам его наливал со склада из бочки!
Я до сих пор не пойму: он не боялся экспериментов, или просто не понимал, что расходные материалы отличаются свойствами?
Wayfarer, у Вас специальные расходники для импортных бульдозеров, погрузчиков, экскаваторов и самосвалов, дармовые?
Решая, на что потратить свои деньги перед очередным ТО: на расходники, рекомендуемые производителем, или на расходники от бульдозера, я выберу первое.
Добавлено через 6 минут
Вот есть у Вас 10 литров антифриза (Органического) для строительной техники. А этот антифриз совместим с тем, что сейчас залито в системе? Вы уверены, что достаточно промоете систему охлаждения? А когда срок эксплуатации этих 10 литров закончится, то снова искать от бульдозера? За деньги или на халяву? Каждый эксперимент имеет свою цену, что Вы планируете выйграть?
Старый 06.03.2014, 23:02   #309
Wayfarer
Сообщение от Leo-sun Посмотреть сообщение
Начнем с того что я не первый раз вижу машину и техническое ее устройство для меня не секрет, второе-когда закончится эксплуатация этих 10 литров(3-4года) могу и купить, может и опять появится Рекомендованно производителем? моторное масло вы тоже оригинальное льете? А трансмиссионное? Система охлаждения элементароно промывается водой в два три прихода, и еще я не задавал вопрос лить мне его или не лить, я спросил-пользовал ли кто такие антифризы и сколько на них ездил, а про автол как говориться не путайте "..опу с пальцем" вы уверены что у вас оригинальный антифриз?(мобил и.т.д.) а данный антифриз одобрен Мерседесом,Ман,МТУ(если для вас это что то говорит. Если нет то ваш совет некорректен!)
И еще антифриз это не расходник это сервисные жидкости-не путайте. И да они у меня дармовые(5-10литров).
На счет разных эксплутационных свойств жидкостей согласен лишь с моторными маслами и АТФ на счет антифризов,и трансмиссионок в корне не согласен и когда есть возможность залить в редуктор и раздатку масло с температурой замерзания до -57 то я сделаю это(назовите хоть одно рекомендованное производителем масло что имеет такие же характеристики? не класс масла и не вязкость, масла 75W90 при одинаковой вязкости ой как отличаются по харатеристикам.
Последний раз редактировалось Wayfarer; 06.03.2014 в 23:11.
Старый 07.03.2014, 12:58   #310
ДмитрийГлаз
Wayfarer, Да никто не отговаривает. Просто при цене антифриза -морочиться лить туда че попало(опять же промывать).Ну не знаю... и еще подумайте о последующих покупателях(Вы же не будете на ней вечно ездить). По поводу экспериментов-когда мне понадобилось туда что-то долить Я не долго думая влил антифриз Nordik. Вскоре потек радиатор.Потом потек новый радиатор(правда китайский).Потом Я всю жижу махнул на рекомендованый Мобил и вот второй год езжу и даже не доливаю-все в норме.ИМХО
Старый 07.03.2014, 13:18   #311
Ко Тя
Аватар для Ко Тя
Извиняюсь, но туплю сильно.
Официалы мобил сейчас льют, и можно ли смело менять на него без промывки?
http://www.exist.ru/Catalog/Goods/7/174/C1F08EE8
Ко Тя вне форума   Вверх Ответить с цитированием
Старый 07.03.2014, 17:16   #312
Agarushka
Можно.
Старый 05.04.2014, 00:11   #313
Sanek01
Подскажите. нигде не смог найти ответ.
Двигатель 4в12, 2,4л.
Кроме радиатора , где ещё сливное отверстие ( из блока, чтоб слить по максмуму всё)?
Sanek01 вне форума   Вверх Ответить с цитированием
Старый 12.04.2014, 17:49   #314
greenrocket
Авто: Outlander XL 2.4 MT
Сообщение от Klasik Посмотреть сообщение
оригинальный антифриз: MZ381033,
В Exist.ru сейчас есть 1793.11 за 4 литра
greenrocket вне форума   Вверх Ответить с цитированием
Старый 12.04.2014, 18:37   #315
manul
Аватар для manul
Попробуйте залить антифриз который Вам советуют - через год будем ждать отзыв
Последний раз редактировалось megaaxel; 12.04.2014 в 21:23.
manul вне форума   Вверх Ответить с цитированием
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 22:55. Часовой пояс GMT +3.
