Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 11.10.2014, 10:12   #346
УНМ
По умолчанию Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
Сообщение от amel Посмотреть сообщение
Покупал полгода назад, странно что пропал
http://msk.pulscen.ru/products/40148...ta_5l_11468779
не реклама
у него другой парт стал 4014835755857
УНМ вне форума   Вверх Ответить с цитированием
Старый 11.10.2014, 21:06   #347
amel
Аватар для amel
Ravenol отличная замена оригиналу, сам такой залил. Спасибо за новый партнамбер.
Старый 12.10.2014, 12:52   #348
-КОТ-
Авто: XL 3.0 Glance Edition
Да не делает равенол сам ОЖ. По описанию по ссылке обычный гибридный антифриз (по классификации WAG G11), если цена ОК, можно лить.
Старый 19.01.2015, 22:48   #349
Goga45
Аватар для Goga45
По умолчанию Re: Замена антифриза
Сообщение от Timka Посмотреть сообщение
А термостат в верхней трубке или в нижней?
В верхней конечно...
Goga45 вне форума   Вверх Ответить с цитированием
Старый 18.02.2015, 12:47   #350
Corsa1r
Смущение Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
Подбираю антифриз к автомобилю, наткнулся на фото в гугле по коду MZ320292
Написано нельзя использоваться для авто с 2011г.в., потому что идут алюминиевые блоки цилиндров. Вот такие дела.
Corsa1r вне форума   Вверх Ответить с цитированием
Старый 18.02.2015, 18:34   #351
DrSleep
Аватар для DrSleep
Сообщение от Corsa1r Посмотреть сообщение
Не "потому что алюминиевые", а потому что состав сплава изменили с 2011 модельного года. В алюминиевые блоки по 2010 модельный год разрешено.
DrSleep вне форума   Вверх Ответить с цитированием
Старый 27.02.2015, 13:56   #352
Corsa1r
Сообщение от DrSleep Посмотреть сообщение
какой тогда антифриз использовать? авто 2011г.в
Старый 27.02.2015, 14:01   #353
Колян 86
Аватар для Колян 86
Авто: Peugeot 4007 2.4 MT
Corsa1r, Любой синий/зеленый G11
Старый 27.02.2015, 14:22   #354
Corsa1r
Сообщение от Колян 86 Посмотреть сообщение
спасибо!
а какой объем заправочный?
Добавлено через 9 минут
Такой подойдет?
Наименование: EXTRA
Цвет: Сине-зеленый
OEM: BMW N60069.0, MAN 324, MB 325.0, MTU MTL 5048, Opel B0400240, SAAB 6901599, VW TL-774C (G11)
Последний раз редактировалось Corsa1r; 27.02.2015 в 14:32.
Старый 27.02.2015, 14:41   #355
DrSleep
Аватар для DrSleep
спасибо!
Такой подойдет?
Corsa1r, подойдет, это G11
объёмы:
7.5 L <двиг 2,4>
9.5 L <двиг 3,0>
в шапке\теме всё это есть, не ленитесь читать, чтобы не засорять тему повторяющимися вопросами.
Добавлено через 16 минут
Corsa1r, ваша машина 2009-ого модельного года
Добавлено через 1 час 51 минуту
Только сейчас заметил, что думал об одном, а написал другое : не "состав сплава", а состав жидкости, конечно же, изменили.
Жидкость Mitsubishi Super long life Coolant PREMIUM в новые машины заливается. И судя по мурзилке OUTLANDER III- это безсиликатный антифриз.
Старый 14.03.2015, 12:39   #356
PVN
Всем привет! Данная тема помогла с выбором. Пару недель назад сделал ТО 60, залил Ravenol HJC (партнамбер есть в этой теме). Сделан он по HOAT технологии, так что проблем быть не должно (допуски есть почти на всех японокорейцев). Замена возможна через 5 лет или 250000 пробега. Брал концентрат 5 литров, разбавил 4 литрами воды. Полагаю температура замерзания получилась где-то -45 градусов.
Всем удачи!
PVN вне форума   Вверх Ответить с цитированием
Старый 15.03.2015, 20:33   #357
Corsa1r
Кто менял жидкость сам, откручивали ли вы патрубок под днищем? Или достаточно из радиатора слить и из блока двс?
Старый 15.03.2015, 20:50   #358
TaxAdviser
кран на радиаторе справа. Потом через пробку "наддували" сжатым воздухом. Заливал присадку ликвиМоли для промывки. ездил с ней час. Потом промывал два раза водой. После промывки залил сначала концентрат (половина от 9.5 литров общего объема системы). Потом долил воды. гарантировано получаем 50/50 концентрацию (после двух промывок вода всё одно остается в системе).
TaxAdviser вне форума   Вверх Ответить с цитированием
Старый 15.03.2015, 20:58   #359
kris73
Авто: Outlander XL 2.4 MT
Лучшее качество за разумную цену, имхо.
Залил CoolStream Premium 40 (100% аналог Havoline XLC+ и FUCHS MAINTAIN FRICOFIN G12 PLUS) по спецификации
VW G12+. (на 5 лет или 250 000 км пробега)
Полная совместимость с алюминием. Сижу на нём 5 лет. Заливаю во все свои авто после слива непонятной жижи от предыдущего владельца. Претензий нет.
p.s. Скажу по секрету. Цвет не имеет никакого значения. Важны допуски, одобрения, технические характеристики. Цвет - это просто краситель.
kris73 вне форума   Вверх Ответить с цитированием
Старый 15.03.2015, 22:47   #360
TaxAdviser
Сообщение от kris73 Посмотреть сообщение
не совсем. допуск G12 и G 12+ будет красным.
также есть G 12+ фиолетовый. но НЕ будет G 12 синий.
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 20:53. Часовой пояс GMT +3.
