Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 11.10.2016, 20:28   #466
Potable
Аватар для Potable
По умолчанию Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
Если авто успело прокатиться, то я бы поменял, да ещё и промыл.
Старый 12.10.2016, 20:52   #467
nvr63
Вечер добрый.
Подскажите можно ли долить антифриз Mitsubishi Super Long Life Coolant MZ320291 в расширитель, если там залит антифриз MITSUBISHI MZ 311986 Long Life Coolant?
Всем спасибо.
nvr63 вне форума   Вверх Ответить с цитированием
Старый 12.10.2016, 20:57   #468
BLOCK СЕРВИС
Партнер Клуба
Аватар для BLOCK СЕРВИС
Авто: MITSUBISHI
Можно
Старый 24.10.2016, 23:43   #469
Леха Лысый
Авто: Outlander XL JFG 3.0 AT
@BLOCK СЕРВИС,
Здравствуйте, не подскажите, в систему охлаждения аутлендера XL JFG 3.0 2012г.в. можно лить антифриз Mobil Antifreez Extra? Спаисбо.
Леха Лысый вне форума   Вверх Ответить с цитированием
Старый 25.10.2016, 06:31   #470
CyberStorm
@Леха Лысый, официалы и льют Mobil Extra зеленый в машинку.
CyberStorm вне форума   Вверх Ответить с цитированием
Старый 25.10.2016, 10:20   #471
BLOCK СЕРВИС
Партнер Клуба
Авто: MITSUBISHI
Сообщение от Леха Лысый Посмотреть сообщение
@BLOCK СЕРВИС,
Да, конечно можно.
Старый 31.10.2016, 09:59   #472
Stem
Авто: XL 2.0 CVT 4WD Instyle S42
Сообщение от maxdemio Посмотреть сообщение
Расскажу как я сливал антифриз с блока.Делал из ямы снял алюминиевую защиту,и пластиковую,чтобы полностью открылся доступ к блоку. Если смотреть снизу вверх на двигатель-то видно что глушитель крепится к блоку двигателя на специальной подставочке через четыре болта на 14. Открутил эти четыре болта и подставочка снялась и освободила место для того чтоб увидеть пробку на блоке и подлезть к ней с шестигранником.
Все! Больше ничего откручивать и выдумывать не надо.
Здравствуйте! На самом деле подставку не нужно откручивать! Есть доступ сверху из моторного отсека, с права от выпускного коллектора. Только нужно сначала посмотреть снизу где пробка расположена. При откручивании и закручивании пробки, приходится ложиться на двигатель. Главное смотреть куда коленями опираешься, чтобы чего нибудь не отломить)). Обычным шестигранником открутить не получилось. Только с помощью ключа с шарниром, под биту!
Stem вне форума   Вверх Ответить с цитированием
Старый 31.10.2016, 14:20   #473
Dr.KoMet
Аватар для Dr.KoMet
Здравствуйте.
Предпочтительней ли использовать в качестве ОЖ RAVENOL 4014835755550
Антифриз "OTC Organic Technology Coolant Premix" (G12+) для трехлитрового аута 2013 года выпуска?
Во первых она уже готовая для применения и спецификация выше чем у оригинальной MZ320712 (G11).
Или есть другие более достойные варианты.Главное условие что бы жидкость было готовой к применению.
Спасибо.
Dr.KoMet вне форума   Вверх Ответить с цитированием
Старый 07.11.2016, 03:09   #474
SergTI
Доброго времени суток уважаемые одноклубники!
У меня Outlander XL 2011 г.в. (Jet fighter grill) двигатель (4в12) 2,4 .
Пробег подходит к 60 т.км. Озадачился заменой охл. жидкости. Прочитав тему на форуме в голове сложился некий "винигрет".
Особенно смутило:
1. На автомобили до 2011 года выпуска ММС рекомендует использовать антифриз SUPER LONG LIFE COOLANT (MZ320291 - 1л., MZ320292 - 4 л. - это готовый к заливке 60% раствор)
2. На автомобили с 2011 года выпуска включительно ММС рекомендует использовать антифриз SUPER LONG LIFE COOLANT PREMIUM (MZ320712 - 4 л. - это готовый к заливке 60% раствор)
Возможно ли в охл. систему данного авто залить антифриз MZ320292 (канистра 4 л. с зеленой крышкой), предварительно слив старый (цвет в расширительном бачке сине зеленый)?
Последний раз редактировалось SergTI; 07.11.2016 в 03:20.
SergTI вне форума   Вверх Ответить с цитированием
Старый 07.11.2016, 16:03   #475
BLOCK СЕРВИС
Партнер Клуба
Авто: MITSUBISHI
Можно
Старый 07.11.2016, 22:19   #476
SergTI
Сообщение от BLOCK СЕРВИС Посмотреть сообщение
Можно
Большое спасибо за ответ!
Т.е. состав антифриза с артикулом MZ320292 никоим образом не должен повлиять отрицательно на охлаждающую систему авто (н-р двигатель,радиатор)?
Старый 10.11.2016, 20:40   #477
huntsman
Аватар для huntsman
Прошлый раз заливал AGA Z-C. Но что-то в продаже не вижу...
huntsman вне форума   Вверх Ответить с цитированием
Старый 11.11.2016, 00:41   #478
UPS123
Добрейшего всем. Нормально лить любой антифриз, в соответствующей пропорции для региона. Сам лью мобил экстра зеленый концентрат, уже дважды сменил. В пропорции 50/50 т.к. живув МСК, для северных регионов читайте в книге пропорции). Все хорошо. И уважаемые господа, не придумывайте велосипед. В книге все написано про жидкости. В коробку только оригинал!!!! Остальное, что душе угодно, главное чтобы соответствовало параметрам, рекомендуемыми заводом изготовителем. Всем удачи на дорогах!
UPS123 вне форума   Вверх Ответить с цитированием
Старый 15.11.2016, 09:42   #479
ama-ar-gi
Аватар для ama-ar-gi
Парни, пора ли менять антифриз на 5-летнем XL с 50 тыс. км пробега? И что порекомендуете лить? Спасибо.
ama-ar-gi вне форума   Вверх Ответить с цитированием
Старый 15.11.2016, 09:55   #480
Виссарионович
@ama-ar-gi, Тысяч через 50 поменяйте.
Виссарионович вне форума   Вверх Ответить с цитированием
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 05:53. Часовой пояс GMT +3.
