Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 25.10.2016, 16:15   #91
Нецид
Аватар для Нецид
По умолчанию Re: Общие вопросы по нештатной музыке на XL: отчеты, советы, обмен опытом...
Еще вопрос: как на НА2034 зайти в меню Recovery для прошивки?
кстати, у меня пришла вот с такой прошивкой. Если кому надо могу дать ссылку для скачивания, только я вот не разобрался как скачать с китайского файлообменника.
Нецид вне форума   Вверх Ответить с цитированием
Старый 25.10.2016, 18:48   #92
Нецид
Аватар для Нецид
Сообщение от Нецид Посмотреть сообщение
сам разобрался, уже прошил последней прошивкой от Malyask. Со стоковой прошивкой ГУ загружалось 20сек, а с мод.прошивкой 30+сек...
Старый 26.10.2016, 12:25   #93
sergeysgs
Расскижи пжалста о работе этой проши подробнее через месяцок. Тока именно тут прошу пиши.
Добавлено через 2 часа 47 минут
У меня вопрос в коробке магнитолы есть два провода – AMP-CONT и AMP. Что бы подать питание на антенну надо AmpCont соединить с розовым в колодке?
Добавлено через 2 часа 52 минуты
точнее так: провод ANT просто ведет в неиспольноваввый контакт в потолке, а провод AMP-Cont висит заизолированный.
sergeysgs вне форума   Вверх Ответить с цитированием
Старый 26.10.2016, 15:18   #94
amel
Аватар для amel
@sergeysgs, На ГУ Amp это питание внешнего усилителя, Ant+ питание антенны. В принципе и там и там должно появляться 12В при включении ГУ, можно любой из них соединить с розовым.
Старый 27.10.2016, 21:30   #95
amel
Аватар для amel
Прошил андроид и mcu от 17.10.2016, ссылку выше выкладывал. Версия 1.93.1 оказалась, глюков не заметил, но и нового особо ничего нет. В заводских настройках добавили knob mode, я так и не понял, режим какого регулятора, может громкости. Минимальная громкость теперь нормальная.
Старый 28.10.2016, 12:24   #96
Нецид
Аватар для Нецид
Ребят, а можно как-нибудь подключить НА2034 к бортовому компьютеру?
Старый 28.10.2016, 14:12   #97
amel
Аватар для amel
Пока нет такой возможности, скорее всего и не будет, имею ввиду штатный. Но можно пользоваться Torque + elm327, там и параметров можно вывести на ГУ по более чем на штатном.
https://out-club.ru/board/showthread.php?t=65510
Старый 28.10.2016, 23:20   #98
Нецид
Аватар для Нецид
Сообщение от amel Посмотреть сообщение
Хороший вариант, но вот есть вопрос: аккумулятор эта штука не посадит, если адаптер будет постоянно к разъему подключен? Красная лампочка горит, даже когда ключ в зажигание не вставлен...
Старый 29.10.2016, 09:47   #99
amel
Аватар для amel
@Нецид, не посадит, я три месяца не вытаскивал адаптер.
Старый 31.10.2016, 21:40   #100
sergeysgs
Увидел на али видеорегистраторы с usb проводом, вроде как для нашей головы, мож кто уже пробовал пользовать?
А прошивку откуда брали с 4pda иль сам продвец прислал? Просто я случайно playmarket удалил, вот и думаю мож перешиться ?
Старый 01.11.2016, 08:11   #101
amel
Аватар для amel
@sergeysgs, с 4pda, там ведь люди и выкладывают то что им присылают продавцы, больше прошивки брат негде.
А по-поводу регистратора советую
http://s.aliexpress.com/6jARbyqm
(from AliExpress Android)
Лишний раз нагружать магнитолу записью видео не стоит, лучше пусть пишет регистратор.
Добавлено через 1 час 36 минут
ГУ распознает практически любую USB камеру, у меня две веб-камеры видит. Заказал еще вот эту камеру https://ru.aliexpress.com/item/HD-Ca...660361817.html стоит недорого.
Вот про регистратор, на который выкладывал ссылку выше https://out-club.ru/board/showpost.p...postcount=1680
Последний раз редактировалось amel; 01.11.2016 в 08:17.
Старый 01.11.2016, 11:01   #102
Нецид
Аватар для Нецид
Все равно как-то боязно Дело в том, что на авто я сейчас езжу в среднем 30 минут в сутки, остальное время машина на приколе...
Старый 01.11.2016, 12:29   #103
sergeysgs
Ну мне, например, прошивку сам продавец скинул.
Старый 01.11.2016, 21:21   #104
amel
Аватар для amel
Сообщение от sergeysgs Посмотреть сообщение
Ну так и всем продавцы скидывают, потом добрые люди их на файлообменник выкладывают. Так что если на 4pda прошивка, например, для MCU HA, то это и есть оригинальная прошивка.
Старый 02.11.2016, 09:07   #105
AS21
Аватар для AS21
Авто: ASX 1.6 2WD MT
Посмотри во этот вариант:
https://ru.aliexpress.com/item/CAR-D...608.0.0.2OGekL
Если не хочешь по WiFi соединяться
Только при заказе продавцу обязательно напомни:
- шнурок для прямого подключения к магнитоле, а не через видео вход
- и программу для просмотра на магнитоле изображения (у нас DVR стоит в стоке только для WiFi)
Добавлено через 9 минут
1) есть желание подключить магнитолу к ETACS - как штатная MMCS
- Если у кого есть опыт изучения работы с Tx Rx разьемами в главном разьеме - поделитесь плз.
- Также для тестов Tx Rx - надо любой их канбокс, чтобі работал с этитми выходами Tx Rx - подскажите, кто знает - какие есть варианты
Торк хорош, но он не настраивает систему комфорта, как на штатной, и не снимает ошибки. и в основом дает инфу по двигателю
2) Если у когго есть инфа как и по каким командам работает ядро по КАН - плз. поделитесь, я только начинаю изучать эту тему
3) Ищу устройство, котрое будет принимать три сигнала: ручник, скорость, ЗХ - и выдавать на выход для ЗХ магнитолы +12v. Если кто встречал - дайте плз. ссылку
Добавлено через 10 минут
4) Кто нить победил ADB без отпаивания ножек 27, 28 ?
Последний раз редактировалось AS21; 02.11.2016 в 09:17.
AS21 вне форума   Вверх Ответить с цитированием
Текущее время: 01:47. Часовой пояс GMT +3.
