Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 28.06.2016, 11:38   #2
amel
Аватар для amel
По умолчанию 2DIN головное устройство HA2034 на Android
Поставил вчера Hotaudio HA2034 на Android 5.1.1. Из косяков - не работают кнопки на руле по CAN, но это легко решаемо, нужно соединить напрямую сигнальный провод от кнопок к KEY1 или KEY2 напрямую, в обход CAN. Рокфорд работает, звук хороший, за это больше всего боялся. Wifi встроенный, свистков не нужно. Камера заднего вида включается тоже по CAN. Пока конечно рано советовать ее, поезжу недельку, напишу отзыв, но пока все нравится, особенно экран, скорость работы, тач, полноценный хаб на 4 USB.
Покупал тут http://ru.aliexpress.com/item/8-Quad...8.0.108.xC8pLb
Доставка 6 дней! Курьер доставил домой.
Также заказал регистратор со встроенным Wifi http://ru.aliexpress.com/item/TCOL-N...08.0.56.xC8pLb
Пока не приехал.
Фото под спойлером
Небольшое видео, программ еще не ставил, все как из коробки https://youtu.be/Q6zqMk9_6pA]
Старый 28.06.2016, 16:27   #3
mmcrvr
Аватар для mmcrvr
По умолчанию Re: Общие вопросы по нештатной музыке на XL: отчеты, советы, обмен опытом...
Неплохой выбор. Как качество пластика? Встала ровно? Судя по фото, подогнано неплохо.
mmcrvr вне форума   Вверх Ответить с цитированием
Старый 28.06.2016, 16:54   #4
amel
Аватар для amel
Сообщение от mmcrvr Посмотреть сообщение
Встала идеально, по фактуре точно такая же, щелей нет.
Добавлено через 21 час 51 минуту
Кнопки на руле работают, включая три блютуз без доработок, я просто не разобрался. Можно назначить любое действие по короткому и длинному нажатию.
Старый 30.06.2016, 11:34   #5
mmcrvr
Аватар для mmcrvr
Заказал тоже такой аппарат. Вышел в 21000 р. Интересно, на таможне не нахлабучат еще что-нибудь?
Старый 30.06.2016, 11:41   #6
Вячеслав в 31
Аватар для Вячеслав в 31
Есть пара вопросов:
1.Перед-зад-саб регулируются отдельно?
2.Очки полароид экран в рабочем положении не затемняют?
Старый 30.06.2016, 12:45   #7
amel
Аватар для amel
@mmcrvr, не должны, у меня за пол дня таможню прошла.
@Вячеслав в 31, перед зад регулируется, вроде, сегодня еще раз проверю, саб отдельно нет.
Добавлено через 21 час 39 минут
@Вячеслав в 31, в автомате баланса - звук из всех колонок, при переводе баланса на зад - тишина. Очков таких у меня нет.
Добавлено через 21 час 43 минуты
Какого цвета провод в разъеме С-106 отвечает за питание штатной антенны? Розовый?
Старый 01.07.2016, 11:10   #8
Вячеслав в 31
Спасибо, т.е., в этом направлении изменений нет ( у меня было ГУ в таком корпусе на ВинСЕ).
Старый 01.07.2016, 13:02   #9
amel
Аватар для amel
Сообщение от Вячеслав в 31 Посмотреть сообщение
@Вячеслав в 31, насколько я знаю регулировка баланса перед-зад идет по CAN, видимо блок CAN-BUS идущий в комплекте не допиленный, от магнитолы не зависит. Выход пока один, подключать задние колонки непосредственно к магнитоле, а не к усилителю.
Последний раз редактировалось amel; 01.07.2016 в 13:32.
Старый 01.07.2016, 15:59   #10
Вячеслав в 31
Просто, у меня шевельнулось было желание снова купить ГУ (прошлое издохло), да быстро легло на место.
Старый 01.07.2016, 17:46   #11
megaaxel
Аватар для megaaxel
Не по CAN, там своя шина.
Старый 01.07.2016, 19:53   #12
sadik_5
Аватар для sadik_5
Ребят, подскажите, пожалуйста. Имеется универсальная 2 дин. И рамка под 2 дин. Креплю магнитолу на штатные уши. Они сильно низко оказывается. Рамка не налезит. Это чего, долго и упорно рассверливать штатные уши, подгоняя под рамку?
sadik_5 вне форума   Вверх Ответить с цитированием
Старый 02.07.2016, 00:21   #13
megaaxel
Аватар для megaaxel
Я на Лансере под нужным углом на саморезы садил эти уши к корзине магнитолы.
Старый 07.07.2016, 22:59   #14
amel
Аватар для amel
Поюзав магнитолу несколько дней, поделюсь впечатлениями:
+ радио ловит лучше штатной + расширенный диапозон;
+ звук на уровне штатной, после настройки эквалайзера (Рокфорд);
+ кнопки на руле могут управлять сторонними плеерами, типа Power Amp;
+ хороший экран и тач, нареканий нет;
+ не тормозит, у меня SGS4 тормознее;
+ поставил CarLauncher - красота и удобно;
+ mirror link, wifi встроенный, GPS не подводил;
+ 4 USB и 2 micro sd (полноценные).
+ хорошая поддержка производителя и активный форум на 4пда.
- нет фидера перед-зад, нет отдельной настройки саба, касается рокфорда (косяк всех китайских ГУ, а именно CAN Decoder);
- не возможно переключить папки с музыкой с флешки при включенном wifi, с micro sd все ок.
- Nand flash (16 гигов) китайцы сделали отдельно, лечится кастомной прошивкой, которая перераспределяет разделы, но мне, для приложений, пока хватает и 2-х гигов.
- модуль wifi ловит хреново, на телефоне лучше. Под балконом не ловит мою сетку, тел ловит 1-2 палки. На телефоне сделал запуск точки доступа по автоматическому подключению к блютуз магнитолы, теперь все на автомате.
Вывод: за 20 т.р. очень все хорошо, денег своих она стоит. Я не жалею, хотя когда покупал, думал поюзаю месяц и продам))
Последний раз редактировалось amel; 07.07.2016 в 23:06.
Старый 09.07.2016, 08:39   #15
mmcrvr
Аватар для mmcrvr
А как ветка называется?
Текущее время: 15:46. Часовой пояс GMT +3.
