Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 02.11.2016, 09:48   #106
Нецид
Аватар для Нецид
По умолчанию Re: Общие вопросы по нештатной музыке на XL: отчеты, советы, обмен опытом...
Сообщение от Фломастер Посмотреть сообщение
Кстати, звук то и ничего так, надо было настроить под себя. А может и привык уже.
Там еще можно паяльником поработать и будет вообще красота
Нецид вне форума   Вверх Ответить с цитированием
Старый 02.11.2016, 11:45   #107
Фломастер
Авто: Outlander XL JFG 3.0 AT
Сообщение от Нецид Посмотреть сообщение
А можно подробнее. Хотя сейчас стоит уже другое ГУ, все равно интересно.
Фломастер вне форума   Вверх Ответить с цитированием
Старый 02.11.2016, 21:41   #108
Нецид
Аватар для Нецид
Сам не делал, использовал это ГУ всего месяц(подвернулось HA 2034 по очень хорошей цене). Ссылку на форум, где это описано, скинул в ЛС.
Старый 03.11.2016, 14:06   #109
AS21
Аватар для AS21
Авто: ASX 1.6 2WD MT
Мне тоже дай плз. ссылку - может и паяльником пройдусь
AS21 вне форума   Вверх Ответить с цитированием
Старый 03.11.2016, 21:03   #110
amel
Аватар для amel
Вопрос, прямое управление звуком как то может повлиять на звучание, если стоит рокфорд? Звук меня устраивает, но всегда хочется заморочится.
P.S. Учтите, что геморойная настройка после перепайки.
Помогите найти пин от датчика света, не хочу активировать евросвет, т.к. в качестве ДХО дальний в пол накала. Хочу завести напрямую от датчика на контакт ILL ГУ.
Добавлено через 9 минут
В принципе, там проводок кинуть можно, все рядом.
Старый 05.11.2016, 22:13   #111
Нецид
Аватар для Нецид
Сообщение от amel Посмотреть сообщение
Заказал еще вот эту камеру https://ru.aliexpress.com/item/HD-Ca...660361817.html стоит недорого.
А эту камеру можно установить снаружи авто(например, на переднюю рамку гос.знака, ну или еще куда-нибудь) по аналогии с камерой ЗХ?
Старый 07.11.2016, 10:35   #112
Нецид
Аватар для Нецид
Обладатели НА 2034 подскажите есть ли защитная заводская пленка на этом ГУ? Экран не яркий, блики сильные на солнце. Смотришь на экран пленки нет, но если присмотреться, то вроде как и есть и наклеена она вглубь под рамку ГУ...Дело в том, чтобы проверить это, нужно пробовать подцепить чем тонким и главное острым, а это риск подпортить экран, если вдруг там пленки то и нет. Поэтому и хочется уточнить, прежде чем ковырять. Заказывал у того же продавца, что и
@amel,
Старый 07.11.2016, 10:37   #113
amel
Аватар для amel
Пленки на нашем ГУ нет. Друг клеил на своей, правда разбирал, чтобы под рамку наклеить.
Старый 09.11.2016, 06:47   #114
mmcrvr
Аватар для mmcrvr
Стало не хватать памяти для установки приложения на НА 2034. Решил прошиться на прошивку FUSE от Malaysk с объединенной памятью 13 Гб. Пока все устраивает. Кстати с новой прошивкой MCU, которую выкладывал ув. Amel спутники стали ловиться лучше. Машина стоит в гараже, раньше при выезде ловились минут 20.
mmcrvr вне форума   Вверх Ответить с цитированием
Старый 09.11.2016, 18:24   #115
sergeysgs
Прошивку Malaysk накатывали в один заход или по хитрому алгоритму (который и отпугивает)?
sergeysgs вне форума   Вверх Ответить с цитированием
Старый 09.11.2016, 22:18   #116
ANDRYUXA1986
Ребят, заказал НА2034, теперь вопрос: Где установить можно в Москве магнитолу, взамен штатной балалайки? Понимаю, что проще самому, но я в Краснодаре, а тесть с машиной там... буду признателен за совет...
ANDRYUXA1986 вне форума   Вверх Ответить с цитированием
Старый 10.11.2016, 09:16   #117
amel
Аватар для amel
Сообщение от ANDRYUXA1986 Посмотреть сообщение
Да где угодно, ставить ее 10 мин. Антенну GPS в штатное место, на площадку под верхним бардачком. Микрофон желательно в плафон, но я его так и не поставил, через встроенный нормально меня слышат.
Старый 10.11.2016, 10:15   #118
sergeysgs
Да, встроенный микрофон хорош!
Старый 10.11.2016, 11:35   #119
mmcrvr
Аватар для mmcrvr
Сообщение от sergeysgs Посмотреть сообщение
Да ничего сложного, копируешь файл на карточку, заходишь в рекавери (долгое нажатие на кнопку "Включения", потом короткое) и жмешь прошить. Потом вайп, и все пашет. В архиве с прошивкой есть инструкция. Кстати в прошивке лончер неплохой, мне понравился больше чем Car Launcher.
Старый 10.11.2016, 22:35   #120
Нецид
Аватар для Нецид
Все равно как-то боязно Дело в том, что на авто я сейчас езжу в среднем 30 минут в сутки, остальное время машина на приколе...
Все-таки я решился оставить постоянно подключенный obd адаптер в авто. Тьфу-тьфу аккумулятор не сажает. Но вот сегодня во время езды машина начала тупить( спидометр перестал работать и авто очень натужно стало реагировать на газ). Я тут же выдернул адаптер и все стало нормально...У кого-нибудь было что-то похожее?
Текущее время: 14:13. Часовой пояс GMT +3.
