Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 17.12.2016, 18:22   #151
VISk
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Я тоже взял НА2034. С кан-декодером разобрался ! Да этот 4-х ядерный мультимедиа навигационный комплекс (по сути просто неплохой планшет оптимизированный под авто) поддерживает наверное все известные шины автомобилей. В режиме заводских настроек выбирается один из 100 заложенных вариантов кан-шины (наша Mitsubish Pajero #57). А далее обучаем кнопки на руле, нажимая поочередо и присваивая любую из предлагаемых функций. Даже на одну кнопку можно заложить две функции для короткого и долгого нажатия.
Сабвуфер запел, в эквалайзере появился отдельный движок громкости для него, задние колонки тоже. Все вроде норм. На днях хочу подключить переднюю и заднюю камеру. Навител обновил на русский с новыми картами.
Из косяков появился только один - иногда радио начинает самопроизвольно сканировать весь диапазон по кругу, останавливаясь на выбранной радиостанции, играет 10сек. и снова начинает сканировать. Пока не разобрался, лечится временным отключение от аккумулятора.
VISk вне форума   Вверх Ответить с цитированием
Старый 17.12.2016, 18:31   #152
AS21
Аватар для AS21
Авто: ASX 1.6 2WD MT
Сообщение от VISk Посмотреть сообщение
Дай плз. ссылку на характеристики
Очень интересует кан-декодер:
1) кан он полключается? Есть распиновка? Ссылка на его характеристики, плз.!
2) работает или нет с нашим ETACS (т.е. настройка системы комфорта работает тлт нет? Или кан только саббубфера?
AS21 вне форума   Вверх Ответить с цитированием
Старый 17.12.2016, 18:52   #153
ZMS
Аватар для ZMS
@VISk, косяки думаю лечатся с помощью TA-off, AF-off
Старый 17.12.2016, 19:04   #154
VISk
Я так понял, что кан-бас и нужен чтобы команды ЕТАКс перехватывать. Поэтому он универсальный для множества автомобилей. Я эти же головы видел практически для всех моделей авто, просто меняют рамку и крепления.
Да неверно я случайно включаю эти режимы, просто не замечал. А что это за ТА и АF ?
Старый 17.12.2016, 19:15   #155
ZMS
Аватар для ZMS
https://ru.m.wikipedia.org/wiki/Radio_Data_System
скорей всего AF виноват.
Старый 17.12.2016, 19:38   #156
AS21
Аватар для AS21
Не совсем так.
Дай плз. конкретный ответ:
- ты подключал его к ETACS или только думаешь так?
Китайцы в большинстве случаев используют кан как подключинение усилка рокфорд, на некоторых авто для управления кнопками на руле и ТОЛЬКО!!!
Это немного разные вещи
Единственный случай я близкого к нашему кан по функционалу и "читал" про подключение в фольсвагену, сам в живую не видел.
Старый 17.12.2016, 23:44   #157
amel
Аватар для amel
@VISk, я что то не видел в заводских настройках CAN для Паджеро. Там есть только для третьего Аута. Да и чудеса вы какие то пишите. Саб Рокфорда не регулируется. ГУ никаким боком не видит ETACS.
Про сканирование станций радио ZMS правильно ответил, AF включено по умолчанию, просто выключите.
Старый 18.12.2016, 00:45   #158
AS21
Аватар для AS21
Сообщение от amel Посмотреть сообщение
Даже это уже неплохо
Разница между кан для ASX 2012 и третьего Аута - только в скорости, команды одинаковые, Это уже проверено через КанФильтр и W12
Не выложите ли эти настройки.
У меня RK3188 HA, но я там такого не видел
И про кан бокс плз. подробнее, если можно, куда подключается: Rx Tx или есть свой отдельный вход
Вобщем нужно больше инфы, чтобы понять - это очередная пустышка, или действительно реальная вещь
Интересено также понять, кто скорость задает: по идее канбокс.
Если так, то можно вообще микруху перепаять в нем и подключать на любые митсу, у которых есть кан
Старый 18.12.2016, 21:51   #159
amel
Аватар для amel
Сообщение от AS21 Посмотреть сообщение
В заводских настройках просто есть выбор марок машин, №57 - Outlander III (думаю планировали вывести данные по климату и дверям, но пока не работает). Ставьте последнюю прошивку MCU и Android, и все появится. Но толку от этого никакого.
С ГУ было два переходника на штатную фишку, один с CAN Decoder, другой без. Я думаю вы в курсе какие пины на штатной голове Rx и Tx. Вот они же и используются.
Прошивок на CAN Decoder не найти, но китайцы часто обновляют версии декодеров, что меняют неизвестно. Дело шляпа.
@AS21, А что бы вы хотели делать по шине?
Старый 18.12.2016, 22:02   #160
AS21
Аватар для AS21
Все
Для страрта управлять комфортом ETACS, как в штатной + управление блоком камер
А можете выложить фото такого переходника для CAN Decoder?
И сам кан декодер - где можно посмотреть или приобрести?
Старый 18.12.2016, 23:25   #161
mitsubi
Авто: L200 2.5 DiD AT
интересует кан-декодер работает или нет с нашим ETACS (т.е. настройка системы комфорта работает илит нет?
нет настройки комфорта ЕТАКС
кан бокс подробнее куда подключается: Rx Tx или есть свой отдельный вход
есть отдельный вход, скорость порта 38400
если сравнивать с родной MMCS, то ближе к игрушке
Добавлено через 5 минут
скорость по последовательному порту я написал выше
Добавлено через 7 минут
паять ничего не нужно, если есть исходник прошивки его микроконтроллера stm8
mitsubi вне форума   Вверх Ответить с цитированием
Старый 19.12.2016, 09:58   #162
AS21
Аватар для AS21
Сообщение от mitsubi Посмотреть сообщение
Понятно, значит скорость в коде и канбокс
уже в который раз это читаю
У меня сложилось четкое представление:
- есть два вида микрух по скорости: до 250 и более
А ты утверждаешь, что любую из низ можно перепрограммировать на любой диапазон?
или есть универсальные от 0 до 1000?
т.е. - ОНО все-таки как-то именно по кан шине общается с ETACS?
и в коде есть пару правильных команд, но их просто мало?
и под это есть отдельный *.apk?
Старый 19.12.2016, 11:58   #163
mitsubi
все согласно 7-уровневой сетевой модели -- т.е. L1 = PHY, для которого используется соответствующий приемо-передатчик под витую пару с волновым сопротивлением 120 Ом. Однако, поскольку КАН-интерфейс довольно старый, то в далекие времена на заре его появления первые чипы приемо-передатчиков были с невысокой максимальной скоростью, например, 125 кБит/с или 250 кБит/с, но "шли годы" и производители научились выпускать более скоростные чипы, например, до 1МБит/сек у Микрочипа и т.п. Соответственно, некоторые старые низкоскоростные производятся до сих пор и продолжают использоваться из-за более низкой стоимости. А программирование фактической скорости производится ПО микроконтроллера stm8
ОНО "слушает" КАН-шину безотносительно ЕТАКС-а и передает "нужные известные" ЕМУ пакеты по следующей цепочке КАН-шина --> КАНбус-блок (stm8) --> UART (38400 бод) --> MCU (stm32) --> UART (1Мбод) --> CPU (RK3188 пока невыясненный apk) --> пользовательское приложение с картинками (MTCCanbus.apk)
Более полноценно работает только КАНбус для Фольсвагена и Пежо
Последний раз редактировалось mitsubi; 19.12.2016 в 12:05.
Старый 19.12.2016, 18:03   #164
VISk
Да, наверно было бы удобно прямо с экрана управлять и контролировать климатом. Но если подумать - зачем ? Ведь для этого уже есть крутилки, дотупные в любой момент и не нужно ни чего листать и искать приложения. Понимаю, что у любого процессорного устройства с неким универсальным интерфейсом возможностей очень много. Но встает вопрос целесообразности.
Ведь это ГУ прекрасно интегрировалось в систему автомобиля с сохранением всей функциональности родного ГУ и даже добавило кучу новых возможностей (навигацию, камеры, блютус (у меня не было), USB вход с поддержкой практически всех мультимедиа форматов и мн.др.) . А по своему аудио качеству оно (моё мнение) даже лучше чем родное ГУ. Например радио ловит очень хорошо, AUX-вход избавлен от посторонних шумов кан-шины, и т.п. Не пойму , чего же вы ещё хотите то, называя это пустышкой ?
Меня эту штуковина полностью устраивает и своих денег она точно стоит.
А насчет регулировок. То у меня в списке кан-шин №57 ММС Pagero и на самом КАН-декодере тоже самое написано.
Регулировка сабвуфера - самый правый движок в настройках эквалайзера, я сам его сначала за регулятор верхов принял, но над ним написано sub.
Добавлено через 38 минут
Кстати, там же на али попадался модуль канбас-декодера отдельно - около 2 т.р.
Добавлено через 1 час 26 минут
Я так понимаю, что для этих голов разные прошивки есть с разными функциями по натройке звука, например https://www.youtube.com/watch?v=m78NokG2RTk
Последний раз редактировалось VISk; 19.12.2016 в 18:19.
Старый 21.12.2016, 18:51   #165
amel
Аватар для amel
@VISk, можно пару скринов вашего устройства? Причем вообще тут Witson?
Текущее время: 06:39. Часовой пояс GMT +3.
