Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 22.01.2017, 00:12   #211
amel
Аватар для amel
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Сообщение от Freezman Посмотреть сообщение
Ребят кто сталкивался с такой проблемой , флешки постоянно вылетают что навигатора что с музыкой . При каждом включение не видит флешки приходится перевставлять флешку потом только видно становится через время
Было такое, виновата комплектная флешка. Через некоторое время у меня она сдохла. С новой, такой проблемы ни разу не было.
@lyaxndr, да, провод ILL
Добавлено через 7 минут
@lyaxndr, блин, перепутал, мтс-volume... точно
Старый 22.01.2017, 15:44   #212
Freezman
А может быть это связано с тем что я пользуюсь флешкой 32 гб 10 класс большая очень скорость передачи и еще там очень много папок но флешку видит через раз может слишком нагрузил много информации.
И еще как сделать так что бы ничего в автозапуске небыло
Freezman вне форума   Вверх Ответить с цитированием
Старый 22.01.2017, 23:42   #213
lyaxndr
попробуйте разные флешки
lyaxndr вне форума   Вверх Ответить с цитированием
Старый 25.01.2017, 13:25   #214
Macarr0n
Аватар для Macarr0n
Для удобства перепрошивки подключал к блоку питания ПК сразу после покупки, всё прошло почти сразу успешно. Решил поставить кастомную прошивку, в процессе установки застряла на одном месте и магнитола выключилась, при второй попытке ситуация повторилась. После этого штатная новая прошивка со второго раза установилась из Recovery. Может питания не хватает? Б.П. ведь импульсный, а голова изначально рассчитана на питание от аккумулятора автомобиля.
В общем подключить к блоку питания от ПК для проверки работоспособности устройства можно, для прошивки не рекомендую.
Схема подключения:
Взять питание удобно с разъёма типа Molex (мама), в колодку клеммы вставляются как родные, нужны два жёлтых (+12) и один чёрный (gnd), у меня заработало именно со вторым чёрным, как изобразил на схеме, с первым не включалась. Питание на ACC берём с другого разъёма.
Macarr0n вне форума   Вверх Ответить с цитированием
Старый 31.01.2017, 17:48   #215
pinzet
Аватар для pinzet
Авто: C-Crosser 2.4 CVT
Сообщение от zzXL Посмотреть сообщение
У меня это проявляется при следующих условиях:
В заводских настройках выбран canbus: #57 MITSUBISHI OUTLANDER 2014
В поле усилитель: "С усилителем" или "Авто определение усилителя".
Ставишь режим "Без усилителя", либо сбрасываешь Canbus в None и все становится так как было.
Машина с рокфордом.
Спасибо, помогло кjгда скинул can-bus.
pinzet вне форума   Вверх Ответить с цитированием
Старый 02.02.2017, 22:14   #216
MaxonP
Поставил девайс, но есть проблема. Если при уже загруженным и работающем устройстве завести двигатель, то полностью пропадает звук. В момент завода экран не мигает не тухнет, а звук выключается и все. Приложения все работают, не висят, но молча. Нужно выключать и включать устройство, тогда появляется. Может есть какие то мысли по этому поводу.
П.с. Устройство январь 2017. Прошивка 1.99а1. Машина с рокфором. Звук отдельно на задние колонки не выводится в регулировках. Играют только в паре с передними. Притухание экрана при включении фар есть.
MaxonP вне форума   Вверх Ответить с цитированием
Старый 07.02.2017, 23:17   #217
Macarr0n
Аватар для Macarr0n
При инсталляции той самой платы, а именно кнопки «аварийки» стоит запастись тремя болтиками меньшего диаметра, судя по отзывам подходят болты от системного блока, все это потому, что китайцы не правильно подогнали диаметр отверстия для крепления.
Что-то я и такие и сякие болты от системника пробую, все еле лезут. А кто чем прикручивал кнопку аварийки? Боюсь, что лопнет втулка с резьбой на морде.
Старый 08.02.2017, 16:26   #218
pinzet
Аватар для pinzet
от компа
Старый 08.02.2017, 17:10   #219
Levashov
я обычные саморезы вкрутил с прес шайбой, на какие к жигулям подкрылки прикручивают))
Levashov вне форума   Вверх Ответить с цитированием
Старый 09.02.2017, 19:36   #220
amel
Аватар для amel
Понравилась эта кастомная прошивка http://4pda.ru/forum/index.php?showt...#entry57458278 основана на нашем последнем декабрьском стоке, без лишних приложений и сервисов от гугл. Советую.
Старый 09.02.2017, 23:13   #221
Levashov
да фих знает меня сток устрайвает)) один фик все проги рубятся на корню при вкл аппарата
Старый 10.02.2017, 11:38   #222
pinzet
Аватар для pinzet
Сообщение от Levashov Посмотреть сообщение
Почему? Усилитель затыкается во время работы стартера- это нормально! ГУ не вырубается, ничего не скидывает.
Добавлено через 12 минут
@amel, Андрей, интернет на ГУ как раздаешь? Я борюсь со своим модемом E-3372 , он частенько выгружается и потом яндекс навигатор на видит сеть. Вообще пока занят этим вопросом. И наверно сегодня попробую новую прошивку от sva4pda? может там модем корректней заработает.
Старый 10.02.2017, 21:31   #223
amel
Аватар для amel
@pinzet, раздаю точкой доступа либо с телефона, когда один еду, либо с планшета, который ребенок сзади смотрит)) с модемами решил не заморачиваться.
Старый 13.02.2017, 12:13   #224
Антон42
Добрый день!
Подскажите пожалуйста. Радио настроил, все ловит, но после ночи, завожу машину, голова включается, но радио не работает! Новый поиск станций не помогает. Только перезагрузка головы. Может что-нибудь где то поднастроить надо?
Антон42 вне форума   Вверх Ответить с цитированием
Старый 13.02.2017, 12:58   #225
Мстиславский
ребята ВОПРОС не по теме но мне срочно.если кто может помоч -отпишитесь! А вопрос такой-ранее перестала камера отоброжаеться на магнитолу.юзал по форуму но ничего не нашел.вооружившись тестором и отверткой разобрал пол салона пока не дошел до штатной магнитолы и учуял запох гари.магнитолу с умелицем разобрали и он установил что згорела хрень понижающая ток на камеру до 6 в.Проблема в том что оналогов ее не найдем да не знанм как она действует.может у кого есть схема платы или ссылка !
Мстиславский вне форума   Вверх Ответить с цитированием
Текущее время: 23:04. Часовой пояс GMT +3.
