Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 07.05.2017, 07:49   #361
Potable
Аватар для Potable
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Сообщение от KoS Посмотреть сообщение
Да кстати на 13 пин уже после кан бокса ни чего не приходит. В выключенном состоянии там 0.06в, а во включенном 0.10 в. Как то может это влиять не знаю
Не понял. Это управляющий сигнал от ГУ, и именно ГУ выставляет на нем +12 когда не спит. Далее в кан-бокс (как Вы его называете), далее - вкл усил. Попробуйте вместо AMP использовать (временно для проверки) ACC или даже BAT.
Старый 07.05.2017, 12:07   #362
KoS
Аватар для KoS
Ясно. Но из штатной проводки авто, на этом пине постоянно есть +12В, даже на полностью выключенном авто, с извлеченном ключом. Вобщем я сдался. Буду так пользоваться.
KoS вне форума   Вверх Ответить с цитированием
Старый 08.05.2017, 10:47   #363
ДмитрийГлаз
Аватар для ДмитрийГлаз
@KoS, У меня до этого стояла на Андроид 2.3(жутко тормозная магнитола). С ней проблем при запуске никогда не было. Звук всегда продолжает играть. Может это нюанс именно нашей магнитолы. При старте падает напряжение и она перестаёт подавать сигнал на усилок. (кстати заметил какие то свисты и трески из динамиков при этом). В общем помогает выключать звук(mute) при запуске машины с включенной музыкой.
Старый 08.05.2017, 18:30   #364
KoS
Аватар для KoS
А мне mute не помогает.
Старый 08.05.2017, 19:46   #365
Potable
Аватар для Potable
@KoS,. Может это нюанс именно нашей магнитолы.
Говорю же, у меня не этого ньюанса, рокфорда тож нет
Старый 10.05.2017, 10:52   #366
AstAl
Подскажите, у меня аутлендер 2008 до рестайла, система рокфорд, управление на англ.языке.
Планирую заказать и поставить HA2034, нужен ли дополнительный модуль для управления сабом или все есть в базовой комплектации?
И можно ли вывести USB-слот в подлокотник с этой ГУ и что для этого нужно дополнительно?
AstAl вне форума   Вверх Ответить с цитированием
Старый 10.05.2017, 11:01   #367
amel
Аватар для amel
Сообщение от AstAl Посмотреть сообщение
В комплекте с ГУ два вида разъемов, под Рокфорд и обычный, без него, докупать ничего не нужно.
Вывести USB можно куда угодно, понадобится только докупить удлинитель, либо нарастить кабель.
Старый 10.05.2017, 17:39   #368
Нецид
Аватар для Нецид
Сообщение от amel Посмотреть сообщение
У меня установлен не штатный 4-х канальный усилитель. Подключено фронт+тыл. Когда я решил поставить вместо штатного саба активный сабвуфер, я попросил установщика подключить его к ГУ напрямую. На это мне было сказано, что это невозможно и его нужно подключать к задним динамикам, что ГУ не поддерживает линейные выходы! Я как человек очень мало понимающий в этих вопросах с ним согласился. Сделал причем он все это через усилитель, подключив тюльпаны через разветлитель. Во всех ньюнсах установки я разобрался только потом. Теперь у меня вопрос: получается установщик просто не захотел тянуть провод к ГУ, ведь к усилителю было подключить проще или у меня отсутствует нужный из двух видов разъемов комплекта, которые продавались с ГУ? Если вдруг второе, то можно ли купить такой разъем у нас в магазинах?
P.S. Когда мне устанавливали это ГУ, то штатный усилитель уже тогда отсутствовал. Стоял 2-х канальный, к которому был подключен штатный саб, а динамики Рокфорд были подключены к ГУ без усилителя. Теперь загадка: можно ли по этому определить какой разъем(под Рокфорд или обычный) использовал установщик?. Ведь для подключения саба напрямую к ГУ нужен обычный разъем? Кстати, под понятием "обычный" подразумеваются тюльпаны?
Последний раз редактировалось Нецид; 10.05.2017 в 17:53.
Нецид вне форума   Вверх Ответить с цитированием
Старый 10.05.2017, 18:32   #369
Potable
Аватар для Potable
@Нецид, у меня так же нештатный 4-х канальный. К нему подключены перед и саб. Зад подключен прямо к ГУ. В ГУ есть и линейные выходы и выходы со встроенного усилителя. В Вашем случае, с активным САБом, еще проще, нужно протянуть кабель от ГУ (в ГУ втыкается тюльпан) до САБа. Все должно заработать как надо.
Если кан-бас установле, то использован комплент для рокфорда. Я себе установил косу с канбасом, дабы и камера включалась и подсветка когда это необходимо + кнопки на руле без проблем подцепились
Последний раз редактировалось Potable; 10.05.2017 в 18:38.
Старый 10.05.2017, 19:30   #370
Нецид
Аватар для Нецид
Кан-бас установлен, но через него вроде бы только камера ЗХ работает. В этом случае саб возможно подключить прямо к ГУ, даже если использован комплект для рокфорда?
Старый 10.05.2017, 20:59   #371
Potable
Аватар для Potable
Сообщение от Нецид Посмотреть сообщение
Я конечно Вашу схему не собирал, но в ГУ есть линейный выход на САБ, к нему и попробуйте подцепить, должно работать. И не важно вобщем-то с канбасом или нет коса, линейные выходы - это отельный разъем с тюльпанами
Старый 28.05.2017, 21:31   #372
Bizario
Всем привет!
Помогите, может, кто сталкивался с такой проблемой с микрофоном..
Месяц назад купил себе магнитолу HA2034-V600, подключил внешний микрофон. Всё работало, всё нравилось.
Но на днях перестал работать микрофон... когда по телефону звоню, меня не слышат, и когда просто голосовым поиском пользуюсь, тоже ноль реакции.
Первым делом, подумал, что накернился внешний микрофон, попробовал его отключить и воспользоваться встроенным микрофоном, но увы, та же история.
Проверил этот внешний микрофон на компьютере - работает.
Не пойму в чём проблема, почему устройство перестало воспринимать оба микрофона?
Bizario вне форума   Вверх Ответить с цитированием
Старый 29.05.2017, 08:38   #373
Potable
Аватар для Potable
Сообщение от Bizario Посмотреть сообщение
У меня отвалился раз внутренний микрофон (внешний не ставил), помогла перезагрузка.
Блютус оегулярно отваливается, лечу так же
Старый 29.05.2017, 09:37   #374
Bizario
Перезагрузка каким способом? просто выключить / включить?
Пробовал.. не помогло ((
Старый 29.05.2017, 12:16   #375
AS21
Аватар для AS21
Авто: ASX 1.6 2WD MT
А не пробовали прошивка новую поставить?
AS21 вне форума   Вверх Ответить с цитированием
Текущее время: 06:06. Часовой пояс GMT +3.
