Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 29.11.2017, 11:29   #526
Potable
Аватар для Potable
По умолчанию Re: 2DIN головное устройство HA2034 на Android
@Aleks89, кан в комплекте = ничего не надо. Но на камеру второй пин в 20-ти пиновом разхеме ВАСК
Старый 29.11.2017, 11:39   #527
AS21
Аватар для AS21
Авто: ASX 1.6 2WD MT
Вот, ЗХ - берет по сигналу +12v , а не по кан
AS21 вне форума   Вверх Ответить с цитированием
Старый 29.11.2017, 12:05   #528
Potable
Аватар для Potable
Сообщение от AS21 Посмотреть сообщение
Ааааааа.
@Aleks89, Александр, посмотрите плз нуда у Вас идет проводуля со второго пина
Старый 29.11.2017, 12:52   #529
Aleks89
Ааааааа.
[emoji3][emoji3][emoji3]
Вечером фото постараюсь сделать куда там что идет
Если провод back то он вроде и был отдельно вне фишки
Последний раз редактировалось Aleks89; 29.11.2017 в 12:59.
Aleks89 вне форума   Вверх Ответить с цитированием
Старый 29.11.2017, 18:45   #530
Aleks89
Сообщение от Aleks89 Посмотреть сообщение
Revers идет в обход кан, напрямую в колодку
Старый 29.11.2017, 18:56   #531
Aleks89
Кей 1 ,5 пин по кнопкам тоже идет в обход can в колодку
Старый 03.12.2017, 11:54   #532
JDI22
Авто: Citroen C-Crosser
Просмотрел раздел мультимедиа и не нашел варианта использования планшета в роли ГУ, (например, совместно со штатной магнитолой). Если этот вопрос уже обсуждался, подскажите ссылку.
JDI22 вне форума   Вверх Ответить с цитированием
Старый 03.12.2017, 18:22   #533
Aleks89
В общем поставил все работает камера, кнопки, но напрягает треск в динамиках при первом переключении передач через R, потом нормально у кого такое есть?, как бы сделать задержку ?установил car launcher все удобно в одном месте, встроенный микрофон слабоват буду думать.
Старый 04.12.2017, 09:23   #534
Potable
Аватар для Potable
@Aleks89, попробуйте емкость по питанию поставить. У меня треска через R нет, зато в паузах звук двигателя просдушивается и ксенон фон в динамиках добавляет, тоже емкость для начала хочу поставить, в идеале - конечно фильтр по питанию. Еще бы понять, какое питание с шумами (на красном или желтом проводе)
Старый 04.12.2017, 09:27   #535
Aleks89
Треск как я понял идет от антенны сиги, утром отключил его потыркал передачи, тишина.Вставляю разьем антенны треск 1 сек, потом тишина
Старый 07.12.2017, 09:12   #536
Aleks89
Треск почти полностью убрал, но камеру заказал новую , та что шла с зеркалом видно только край бампера, буду ставить еще одну , эту верну на зеркало.
Старый 11.12.2017, 08:06   #537
Aleks89
А вы черный провод на косе цепляли на массу?
Если нет то фоны могут буть по этому
Старый 11.12.2017, 08:57   #538
Potable
Аватар для Potable
@Aleks89, да, черный на массу - это первым делом подключил
Старый 11.12.2017, 13:32   #539
Potable
Аватар для Potable
Обнаружил интересный момент. Одновременно работает и ОБД и хендз фри. Т.е. и торк показывает и разговаривать можно. Неожиданная мелочь, а приятно.
Старый 11.12.2017, 15:57   #540
AS21
Аватар для AS21
По ту до 27 одновременно подключенных БТ устройств
В отличии от WiFi - один (или роутер надо)
USB - по количеству самих входов
Текущее время: 08:11. Часовой пояс GMT +3.
