Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 13.03.2018, 08:08   #556
alexandr_yaya
Авто: Outlander XL JFG 2.0 CVT 4WD
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Сообщение от Aleks89 Посмотреть сообщение
Есть , брал там же выше посмотри фото есть все устраивает))
Спасибо!
Буду ждать. побаиваюсь немного, так как в отзывах на али есть комментарии по браку и выходу из строя экрана.
alexandr_yaya вне форума   Вверх Ответить с цитированием
Старый 13.03.2018, 08:09   #557
Aleks89
Сообщение от alexandr_yaya Посмотреть сообщение
Спасибо!
Мафон зиму переживает прекрасно в минус 40 не много подмерзает экран но быстро отходит, ставьте смело
Aleks89 вне форума   Вверх Ответить с цитированием
Старый 13.03.2018, 22:27   #558
Genry58
Собратья, помогите подобрать мафон на андройде в пределах 25.000, чтобы дружил с управлением с руля и рокфордом. Всем заранее огромное спасибо. Я новичок, читал темы, только так и не понял какой вариант лучше. Outlander xl 2007.
Genry58 вне форума   Вверх Ответить с цитированием
Старый 15.03.2018, 15:21   #559
Kelleset
Подскажите, где найти подробное описание по установке новой головы. С видео или фото. Купил свежую голову на 8 андроиде, модель HA2039-V840-8. Вчера пришла, сижу, разбираюсь. В коробке положили can bus, нужен ли он для моей машины ваще? И в подарок obd2, тот же вопрос.
кому интерессно: https://ru.aliexpress.com/item/Dasai...311.0.0.5y0AGd
обошлась в 24 р со скидками.
Kelleset вне форума   Вверх Ответить с цитированием
Старый 17.03.2018, 19:22   #560
Potable
Аватар для Potable
@Kelleset, да там как бэ по другому не собрать. Все пин-то-пин.
Старый 18.03.2018, 06:32   #561
Potable
Аватар для Potable
НА-2034 V600 с каном, поставил рлкфорд, полный комплект. Выбираю в настройках любой кан, даже отсутствие кана - играет, кнопки все работают и ничего не меняется. Вопрос: нахрена нужен кан?
Старый 18.03.2018, 17:17   #562
Potable
Аватар для Potable
Дополню. В настройках ставлю "с усилителем", перестает регулироваться право/лево и зад перед. Без усилителя право/лево регулируется, зад/перед работает некорректно. Из этого я делаю вывод, что кан-адаптер не работает. Прошу проверить настройки, кому не трудно.
Старый 19.03.2018, 13:47   #563
sergei7213
Здравствуйте уважаемые форумчане! Извиняюсь что может попал не в ту тему, но прошу вашей помощи. У меня заблокировалось ГУ ММЕ 31761, как теперь ее разблокировать? Прошу, помогите!
sergei7213 вне форума   Вверх Ответить с цитированием
Старый 26.03.2018, 15:32   #564
Kelleset
Установил это чудо китайской мысли. По первым ощущениям хороший аппарат. Но.. Пропала индикация температуры в салоне (на нижней панельке), и не выставить силу вентилятора по той же причине. Хотя все вставлял пин-ту-пин. Кнопки на руле настраиваются из меню. Может там же и это настраивается? Кто в курсе? или ссылку на ветку, плз.
По звуку, особой разницы между штатной, которая шла в комплектации и новой не увидел, хотя пишут , что крутой аудиочип и т.д. Динамики одни и те же, звучание то же.(медведь по ушам не ходил, поэтому разбираюсь в звучаниях). Наверное динамики тоже придется менять.
Старый 26.03.2018, 16:43   #565
Aleks89
Сообщение от Kelleset Посмотреть сообщение
У вас 3 аут по индикации не подскажу, а звучание у меня лучше чем на штатной,Но имеется шумка дверей.Попробуйте связатся с продавцом может чего подскажет.
Старый 26.03.2018, 16:45   #566
Aleks89
Есть у меня подозрение что у кого нет саба, кан только для того что бы автоматом гасла подсветка, так как все остальное кнопки и камера идет без кан
Старый 26.03.2018, 16:47   #567
Aleks89
Кстате не у кого отвала флешки не наблюдается, когда мафон после просмотра видео включается сам, при автозапуске.А то периодически отваливается пробовал переключать на дпугой usb не помогает
Да и кстате, все трески у меня ушли после установки доп камеры, старую вернул на зеркало
Старый 26.03.2018, 18:01   #568
Potable
Аватар для Potable
Не понял связи с сабом... скорее тогда уже с усилителем. У Вас рокфорд стоит?
Флешка не отваливается, блюпуп -бывает.
@Kelleset, поздравления с приобретением. По III ауту я тож не подскажу. Я, сменив динамики, был разочарован. Напод пишет, что полный "ВАУ...". Хз... https://out-club.ru/board/showpost.p...&postcount=409
Старый 26.03.2018, 18:21   #569
Aleks89
Саба и усилка у меня нет
Старый 14.04.2018, 20:39   #570
AstAl
Приехал аппарат с маркировкой HA2034 v840-8. С ним возникает следующая проблема - при переключении передач (в любом направлении) выключается ГУ. Есть у кого опыт как эту беду забороть?
AstAl вне форума   Вверх Ответить с цитированием
Текущее время: 01:52. Часовой пояс GMT +3.
