Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 16.05.2018, 10:36   #571
miracle
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Ребят, уж очень много всего понаписано, кто нибудь может ответить - можно ли завести родную камеру заднего вида на ауте xl 2007 рокфорд + усилитель? Если да, как это сделать? голова v600, фишку с проводами камеры определил, как переключить на новую голову не догнал))
miracle вне форума   Вверх Ответить с цитированием
Старый 16.05.2018, 17:22   #572
Potable
Аватар для Potable
@miracle, если не ошибаюсь, в родной камере питание 6 вольт, нужен преобразователь напряжения. Видео цеплять на "Back".
Старый 17.05.2018, 10:56   #573
miracle
понял, спасибо, буду разбираться дальше значит
Старый 17.05.2018, 11:08   #574
Aleks89
Найдите в проводе сам сигнальный провод и подключить тюльпан к голове.питание как я понимаю на камеру при вкл заднего хода илет.больше не чего не нужно,при условии что голова переходить в режим видео при вкл заднего хода
Отправлено с моего SM-J730FM через Tapatalk
Aleks89 вне форума   Вверх Ответить с цитированием
Старый 17.05.2018, 11:54   #575
miracle
Сообщение от Aleks89 Посмотреть сообщение
Найдите в проводе сам сигнальный провод и подключить тюльпан к голове.питание как я понимаю на камеру при вкл заднего хода идет.больше не чего не нужно,при условии что голова переходить в режим видео при вкл заднего хода
Вы считаете, что камера запитана уже? Просто я нашел фишку с камерой когда штатную магнитолу отключал - там на фишке 3 провода, т.е там нет питания камеры? А так да, новая магнитола распознает задний ход, но нет, естественно, изображения - но это же не значит что камера запитана, верно?
Кстати Aleks89 это не вам прислал китаец магнитолу на андроиде 6.0, когда заказывали на 8.0 ? У меня просто тоже самое он сделал)))
Старый 17.05.2018, 11:59   #576
Aleks89
Нет у меня 7 андроид.надо снять обшивку заднюю и прозвонить питание камеры или просто посмотреть.она должна быть запитана на задних ход. как вариант просто подключить к башке и посмотреть будет сигнал или нет
Старый 17.05.2018, 12:07   #577
miracle
Ну в общем идеи все понятны, плохо если камера действительно на 6 вольт...спасибо за ответы
Старый 26.06.2018, 10:22   #578
Aleks89
Продам свою головную систему если интересно в личку.фото есть в ветке
Старый 26.06.2018, 11:13   #579
Potable
Аватар для Potable
Отоно как.... а на что меняем ?
Старый 26.06.2018, 11:17   #580
Aleks89
Машину продал))купил кугу
Старый 26.06.2018, 11:35   #581
Potable
Аватар для Potable
Подрпвляю! Что из запчастей ещё осталось?
Старый 26.06.2018, 11:46   #582
Aleks89
Спасибо.Грм комплект,фара правая с трещинной и Гу. комплек зима 18
Старый 26.06.2018, 12:08   #583
Potable
Аватар для Potable
@Aleks89, по грм можно в личку?
Старый 26.06.2018, 12:09   #584
Aleks89
Конечно если нужно
Старый 01.08.2018, 17:07   #585
tvik
Аватар для tvik
Авто: Стремительный домкрат
Приобрел HA2034-V840
Не видит USB штатный в подлокотнике
tvik вне форума   Вверх Ответить с цитированием
Текущее время: 10:16. Часовой пояс GMT +3.
