Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 16.03.2015, 20:35   #361
Corsa1r
По умолчанию Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
Сообщение от TaxAdviser Посмотреть сообщение
кран на радиаторе справа. Потом через пробку "наддували" сжатым воздухом. Заливал присадку ликвиМоли для промывки. ездил с ней час. Потом промывал два раза водой. После промывки залил сначала концентрат (половина от 9.5 литров общего объема системы). Потом долил воды. гарантировано получаем 50/50 концентрацию (после двух промывок вода всё одно остается в системе).
значит на блоке кран не откручивали?
Corsa1r вне форума   Вверх Ответить с цитированием
Старый 16.03.2015, 23:34   #362
TaxAdviser
Сообщение от Corsa1r Посмотреть сообщение
нет. не смогли открутить. правда к такому варианту я был сразу готов, поэтому и "наддували" через пробку чтобы выгнать старый антифриз, а потом и промывочную воду из системы.
TaxAdviser вне форума   Вверх Ответить с цитированием
Старый 17.03.2015, 13:59   #363
Corsa1r
интересно, а на 2.4 этот краник на блоке есть?
Старый 20.03.2015, 02:23   #364
divers143364
Аватар для divers143364
Авто: OUTLANDER XL 2.4 MIVEC CVT+(дима ежик)
есть,но не краник а пробка,с задней стороны двигла и удобней отворачивать на подъемнике.
divers143364 вне форума   Вверх Ответить с цитированием
Старый 20.03.2015, 06:06   #365
Roman46
Сообщение от divers143364 Посмотреть сообщение
А где поточнее (если можно фото). Менял антифриз на прошлой замене масла, так эту пробку всем гаражным кооперативом искали на 2.4. Так и не нашли.
Roman46 вне форума   Вверх Ответить с цитированием
Старый 22.03.2015, 01:52   #366
divers143364
Сообщение от Roman46 Посмотреть сообщение
А где поточнее (если можно фото). Менял антифриз на прошлой замене масла, так эту пробку всем гаражным кооперативввом искали на 2.4. Так и не нашли.
вот
Старый 23.03.2015, 10:29   #367
Roman46
вот
Спасибо! А мы внизу обыскали все...
Старый 26.03.2015, 17:43   #368
andob
Аватар для andob
Авто: Outlander XL JFG 2.4 MT
Сообщение от DrSleep Посмотреть сообщение
Не "потому что алюминиевые", а потому что состав сплава изменили с 2011 модельного года. В алюминиевые блоки по 2010 модельный год разрешено.
Мне кажется ключевая фраза:"срок службы жидкости: 4 года"
А у аута с 2011 года по регламенту смена ОЖ через 8 лет или 120 000 км., что наступит раньше.
При использовании этого антифриза не получится выдержать установленные тех.картой сроки и придется менять через 4 г. или 60 т. км.
Последний раз редактировалось andob; 26.03.2015 в 17:57.
andob вне форума   Вверх Ответить с цитированием
Старый 26.03.2015, 17:55   #369
DrSleep
Аватар для DrSleep
Сообщение от andob Посмотреть сообщение
Это у меня была "оговорка" ))
Четырьмя постами ниже #355 я "исправился" ))
DrSleep вне форума   Вверх Ответить с цитированием
Старый 14.05.2015, 23:28   #370
Kalalay
Аватар для Kalalay
Много предложений в этой ветке по антифризу ,сижу думаю,какой всё же заказать.Примерно 5 литров концентрата нужно для замены или 10 литров готового,всё верно? Хочу делать с промывкой.
Kalalay вне форума   Вверх Ответить с цитированием
Старый 15.05.2015, 09:04   #371
FeltseR
Аватар для FeltseR
Сообщение от Kalalay Посмотреть сообщение
Верно. Я делал со сливом из блока без промывки:
-слилось с радиатора 3,5 л, с блока тоже примерно 3,5 л;
-Заливал 3,5 л антифриза Mobil 1 Concentrate синий G11 + 3,5 л дистилата. Прогревать до срабатывания вентилятора в процессе заливки не нужно, антифриз сам идет в блок. Нужно прожимать нижний шланг от радиатора к блоку в процессе заливки антифриза - это избавит от воздушных пробок в системе;
-после заливки прогреть двигатель до срабатывания вентилятора, чтобы смешался антифриз из блока с антифризом из радиатора.
FeltseR вне форума   Вверх Ответить с цитированием
Старый 17.05.2015, 09:30   #372
Kalalay
Аватар для Kalalay
Сообщение от FeltseR Посмотреть сообщение
У меня залит зелёный.Тогда лучше этот подойдет или без разницы? 151158 концентрат,сине-зелёный 5 литров
Последний раз редактировалось Kalalay; 17.05.2015 в 09:51.
Старый 17.05.2015, 11:20   #373
FeltseR
Аватар для FeltseR
Этот подойдет, имеет синий цвет. Такой же заливал, с завода был залит зеленый антифриз. Официалы льют также его. Промывать систему можно дистилатом, если антифриз с блока сливать не планируете. 3 пятилитровые баклашки нужны. То что останется - на доливку.
Дистилат 5 л
Последний раз редактировалось FeltseR; 17.05.2015 в 11:26.
Старый 17.05.2015, 13:44   #374
amel
Аватар для amel
С дистиллированной водой аккуратнее, нельзя на ней помпе работать, накроется без смазки антифризом.
Старый 01.06.2015, 22:28   #375
hdcaesar
Всем привет. Объясните почему на ситроеновском форуме при замене ОЖ снимают патрубок а не через краник сливают. как лучше ?
hdcaesar вне форума   Вверх Ответить с цитированием
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 22:28. Часовой пояс GMT +3.
