Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 02.06.2015, 07:08   #376
Колян 86
Аватар для Колян 86
Авто: Peugeot 4007 2.4 MT
По умолчанию Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
Сообщение от hdcaesar Посмотреть сообщение
при замене ОЖ снимают патрубок а не через краник сливают.
этот метод и есть с промывкой системы.. сам так менял на сервисе...
Старый 04.06.2015, 11:33   #377
Pyany
Всем привет!
Абсолютно не могу добыть MZ 101006 Антифриз-концентрат "SUPER LONG LIFE COOLANT", 2л: сроки сумасшедшие, цена неадекватная, поставщики красные - заказывать смысла нет.
По поводу замены радиатора надо как минимум долить, а лучше поменять антифриз.
Мобиловский сравним по качество/составу присадок, или есть более подходящий?
Pyany вне форума   Вверх Ответить с цитированием
Старый 05.06.2015, 17:35   #378
Leo-sun
Аватар для Leo-sun
Равенол чем не устраивает? Номер для заказа есть в этой теме.
Старый 05.06.2015, 22:53   #379
amel
Аватар для amel
Сообщение от Leo-sun Посмотреть сообщение
Если про этот Ravenol 4014835713550, то его хрен найдёшь. В своё время менял именно на такой. По деньгам совсем недорого стоил, аналог оригинала. А так советую Mobil или Nissan KE90299944 (5 л - 1250 р.)
Добавлено через 35 минут
Про Равенол я махнул, у него новый артикул -4014835755857.
Старый 06.06.2015, 16:00   #380
Pyany
Купил зеленый японский Акита, по 800 руб. за 4 литра. Нормальный?
Старый 06.06.2015, 18:03   #381
CyberStorm
Купил две банки концентрата MZ311986 по 1570 руб. заменил в пропорции 50/50 через аппарат у ОД, по цвету зеленый как и тот, что был залит
Сегодня глянул цену - выросла до 7 687 руб. в 4.8 раза... бред какой-то. Радует, что года на 3-4 хватит.
CyberStorm вне форума   Вверх Ответить с цитированием
Старый 11.06.2015, 17:34   #382
Dout
Сообщение от divers143364 Посмотреть сообщение
вот
скажите, на пробке звезда или шестигранник?
Добавлено через 1 час 55 минут
и как я понял пробок там четыре... по одной на каждой стороне блока
Последний раз редактировалось Dout; 11.06.2015 в 17:41.
Dout вне форума   Вверх Ответить с цитированием
Старый 17.08.2015, 21:17   #383
Vintic
Аватар для Vintic
Авто: Outlander XL JFG 3.0 AT
Добрый день, подскажите пожалуйста: есть два Аута XL - один 2008, другой 2011 года выпуска, оба трехлитровые. Можно ли залить в оба этих автомобиля Mobil Antifreeze Advanced красного цвета? Будет ли это наилучшим по качеству выбором?
Vintic вне форума   Вверх Ответить с цитированием
Старый 17.08.2015, 23:40   #384
CyberStorm
Vintic, в Outlander XL заливают зеленый антифриз, например Mobil 1 Extra. Красный и зеленый отличаются по составу присадок, могут быть проблемы.
Старый 18.08.2015, 09:44   #385
Vintic
Аватар для Vintic
CyberStorm, очень странно, потому что в моей книжке по эксплуатации автомобиля написано, что нужно использовать антифриз "DIA QUEEN SUPER LONG LIFE COOLANT PREMIUM или аналогичный (аналог должен представлять собой высококачественную охлаждающую жидкость на основе этиленгликоля, не содержащую силикатов, аминов, нитратов и боратов и произведенную с использованием долговечной гибридной органическо-кислотной технологии".
В антифризе Mobil Antifreeze Extra, судя по спецификации, возможно содержание силикатов: http://www.mobil.com/Russia-Russian/...eze_Extra.aspx
С другой стороны в Mobil Antifreeze Advanced в спецификации написано все слово в слово, как и в инструкции: http://www.mobil.com/Hungary-English..._Advanced.aspx
Старый 18.08.2015, 10:04   #386
madmax181
Вот эти статьи почитайте и все сразу станет ясно.
http://www.cool-stream.ru/pravda_ozh
Старый 18.08.2015, 10:33   #387
CyberStorm
Vintic, шоб не напрягаться лишний раз купите MZ311986 и будет вам счастье. Сам залил такой недавно.
До этого официалы заливали Mobil 1 Extra - 3 года машина проходила на нем без проблем.
Старый 18.08.2015, 12:03   #388
Vintic
Аватар для Vintic
CyberStorm, MZ311986 - это Long Life Coolant, который не подходит в автомобили 2011 года выпуска и младше - для них нужен Super Long Life Coolant Premium (MZ320130), который сейчас невозможно заказать
Старый 18.08.2015, 12:36   #389
Kemerunec
Как вариант японский антифриз TCL есть как концентраттак и готовый. Соответствует требованию митсу Super LLC. На 4 года или 80 т.км пробега. Брал в автодоке, там есть еще и концентрат. В ексист только готовый.
Kemerunec вне форума   Вверх Ответить с цитированием
Старый 18.08.2015, 12:38   #390
Kemerunec
Для SLLC выбираем с пометкой power
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 10:03. Часовой пояс GMT +3.
