Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 24.03.2016, 21:26   #436
b707
По умолчанию Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
Сообщение от Жорик Вартанов Посмотреть сообщение
получается что смогли слить всего 5.5 литров, а 1.5 литра старого антифриза так и осталось в системе. Это нормально ?
Это нормально. Вообще не понимаю, к чему многие стремятся слить все до капли - все антифризы на основе этиленгликоля, рекомендованные для ХЛ - совместимы между собой. Поэтому нет ничего страшного, если в системе останется часть старой жидкости.
b707 вне форума   Вверх Ответить с цитированием
Старый 24.03.2016, 23:26   #437
maxdemio
может пока все откручивали-мотор остыл и термостат перекрыл большой круг...
maxdemio вне форума   Вверх Ответить с цитированием
Старый 25.03.2016, 20:50   #438
Жорик Вартанов
Аватар для Жорик Вартанов
Сообщение от maxdemio Посмотреть сообщение
перед тем как сливать антифриз, машина минимум 2 часа была в боксе - пока менял масло, фильтра, свечи и минут 30 эту пробку на блоке мастер пытался открутить.
Жорик Вартанов вне форума   Вверх Ответить с цитированием
Старый 26.03.2016, 03:33   #439
maxdemio
Ну вот и понятна причина почему не весь антифриз слился...
Старый 08.04.2016, 23:11   #440
Kalalay
Аватар для Kalalay
Сообщение от b707 Посмотреть сообщение
А если с радиатора и расширительного бачка только слил около 4л. и залил нового ? Потом планирую еще так же сделать ,через пол годика
Kalalay вне форума   Вверх Ответить с цитированием
Старый 03.06.2016, 20:09   #441
Serg33rus
Аватар для Serg33rus
Авто: Outlander XL 2.4 MT
Собралься менять антифриз.На глаза попалься HEPU P999-005 по адекватной цене.Подскажите можно его залить?
Serg33rus вне форума   Вверх Ответить с цитированием
Старый 05.06.2016, 21:23   #442
Shiza
Авто: XL 2,4 со всеми пирогами
@Serg33rus, лично не заливал. НО фирма заслуживает уважения и доверия.
Shiza вне форума   Вверх Ответить с цитированием
Старый 17.06.2016, 22:30   #443
Serg33rus
Подскажите какой шестигранник нужен для слива жидкости дв 2.4
Добавлено через 16 часов 21 минуту
Сообщение от Serg33rus Посмотреть сообщение
Сам отвечаю.Шестигранник на 8
Старый 30.06.2016, 19:57   #444
stinger777
Аватар для stinger777
Делал ТО-120 000. Меняли антифриз - сливали в 3 местах:
3. И пробка на блоке - к которой очень неудобно подбираться.
P.s out xl 2.4
На фото эта пробка имеется ввиду?
stinger777 вне форума   Вверх Ответить с цитированием
Старый 04.08.2016, 13:25   #445
FeltseR
Аватар для FeltseR
3 года назад заливал Mobil Concentrate Anteefreeze extra со сливом из блока. В этот раз залил PC2CG TCL концентрат зеленый из автодока по 1067 р за 2 литра. Осталось около пол-литра. Уровень в расширительном бачке на горячую должен быть не выше отметки max.
FeltseR вне форума   Вверх Ответить с цитированием
Старый 12.08.2016, 18:16   #446
offskid
Авто: Outlander XL 3.0, Honda Civic 5D 1.8
Сообщение от FeltseR Посмотреть сообщение
Получается уровень на холодную должен быть почти на минимуме? после прогрева почти на максимуме?
У меня на холодную по середине гдето, после прогрева выше максимума.
Чем черевато?
offskid вне форума   Вверх Ответить с цитированием
Старый 12.08.2016, 18:41   #447
-КОТ-
Авто: XL 3.0 Glance Edition
Сообщение от offskid Посмотреть сообщение
Чем черевато?
Ничем, уровень ОЖ проверяется на холодную. После прогрева может быть выше метки макс, запас в бачке есть.
Старый 07.09.2016, 06:15   #448
Paziy
Авто: Outlander XL 3.0 2007
Ребят, хочу врезать фильтр в систему охлаждения, подскажите в какой шланг правильнее это сделать?
Paziy вне форума   Вверх Ответить с цитированием
Старый 07.09.2016, 07:33   #449
YesYes
Аватар для YesYes
Счастье
Сообщение от Paziy Посмотреть сообщение
Чисто теоретически: Тот который холоднее и тот что до помпы.
А что именно за фильтр (ссылк. ?) и какова конечная цель.
Старый 07.09.2016, 08:35   #450
Paziy
Ссылка
Конечная цель: т.к. хз что было залито до меня планирую перед зимой почистить систему охлаждения, долгоиграющей промывкой, потом все это слить промыть окончательно и залить новую качественную жижу. Да и потом лишним мне кажется не будет
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 08:02. Часовой пояс GMT +3.
