Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 29.05.2017, 12:52   #376
Bizario
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Да.. прошил вчера свежей прошивкой - не помогло ((
Bizario вне форума   Вверх Ответить с цитированием
Старый 29.05.2017, 20:50   #377
val078
Сообщение от Bizario Посмотреть сообщение
Такая же ситуация,удаление внутреннего микрофона., перемычка.,замена внешнего микрофона на нормальный,в комлекте идёт самый дишманский за 120 р.,заказать нормальный будет стоить 550-700
val078 вне форума   Вверх Ответить с цитированием
Старый 30.05.2017, 09:06   #378
Bizario
Дело в том, что я этот стандартный дишманский микрофон проверил на компе - и он работает.
а вот ГУ его почему-то не воспринимает, так же как и внутренний.
соответственно замена внешнего, как я понимаю, тоже не поможет..
мне кажется это именно какой-то программный сбой..
или я хз вообще что происходит...
Старый 30.05.2017, 20:54   #379
val078
надо всё попробовать, может что-то поможет
Старый 31.05.2017, 04:13   #380
Potable
Аватар для Potable
Кроме программного сбоя может выйти из строя аппаратная часть
Старый 31.05.2017, 09:20   #381
Bizario
в общем перепробовал всё, что можно..
* перезагрузка
* полный сброс настроек
* перепрошивка аппарата на заводскую и кастомную
* замена внешнего микрофона
... ничего не помогло ((
т.е. всё-таки наверное что-то внутри вышло из строя ((
подозрительно, что не работают оба микрофона..
я понимаю, если бы сломался внутренний и работал внешний или наоборот.
Вообще эти микрофоны как-то связаны между собой? Есть ли какая-нибудь плата или что-то типа того, которая отвечает за оба микрофона?
Старый 31.05.2017, 15:56   #382
val078
* перезагрузка
пробуй перемычку припаять, фото здесь или на пда выкладывали уже,не ты первый с такой проблемой,я кстати так и не решил,тоже оба микрофона не работают,и изначально по встроенному было очень плохо слышно меня,как только попробывал воткнуть внешний,сразу перестали работать оба,танцы с бубном не помогли
Старый 31.05.2017, 16:13   #383
val078
Сообщение от val078 Посмотреть сообщение
http://4pda.ru/forum/index.php?showtopic=734564&view=findpost&p=61173072
Старый 02.06.2017, 09:30   #384
Bizario
По ссылке прохожу.. ничего по теме не нахожу..
нашёл фото перемычки только в одном сообщении на 4pda
http://4pda.ru/forum/index.php?showtopic=760827&st=780
(сообщение 789)
разобрал ГУ, но такой перемычки, как на фото, у меня нет...
В общем склоняюсь уже к тому, что забью на этот долбаный микрофон, ибо устал с ним бороться.. ((
Старый 02.06.2017, 17:17   #385
val078
(сообщение 789)
на пда в поиске в разделе обсуждения магнитол на базе процессора рокчип... забыл номер вводишь слово микрофон, полно вариантов решения проблемы
Старый 06.06.2017, 08:57   #386
Nicolo
Авто: Outlander GT 2019
Добрый день!
Выбираю между данной магнитолой (2034) и Kaier S180 -
http://mstar.su/produc…i-outlander-android-4/
Подскажите, что лучше по функционалу?
Нужно:
1. Быстрая работа навигации (навител или др.)
2. Подключение штатной камеры
3. Качественный прием радио (люблю послушать в дороге).
Старый 06.06.2017, 11:38   #387
mitsubi
Авто: L200 2.5 DiD AT
Сообщение от Nicolo Посмотреть сообщение
Нужно:
1) обратите внимание, что навигация Garmin на версии Андроида выше 5.1 не работает;
2) штатную камеру на всех магнитолах прийдется запитывать от дополнительного источника напряжением +6.5вольт;
3) из китайских магнитол, которые мне попадались, только производства Klyde из коробки обеспечивали прием радио вдали от передатчиков вне города
mitsubi вне форума   Вверх Ответить с цитированием
Старый 06.06.2017, 12:48   #388
AS21
Аватар для AS21
Авто: ASX 1.6 2WD MT
Сообщение от mitsubi Посмотреть сообщение
Согласен полностью, только добавлю:
- по питанию камеры: проблема не только в подаче питания, но и его отклоючении, после выключения ЗХ. т.е не просто понижение v, но и еще какое-то реле на сигнал ЗХ, или на лампочку ЗХ с понижением наппряжения
Если у Вас митсу с кан шиной нормальной (не L200) - то самое лучшее решение и по питанию и по реле: блок управления камерами от DELICA D5. Хотя и не самый дешевый вариант.
- кроме Гармин, есть Навител. Пользуюсь. Все устраивает и отлично работает
AS21 вне форума   Вверх Ответить с цитированием
Старый 06.06.2017, 14:55   #389
Nicolo
Спасибо.
А из этих двух что брать?
2034
Kaier S180
Старый 07.06.2017, 13:50   #390
Falcon62
Аватар для Falcon62
2034
Kaier S180
2034-v600
Falcon62 вне форума   Вверх Ответить с цитированием
Текущее время: 03:26. Часовой пояс GMT +3.
