Re: Проект от Johnson. Обсуждение. Помощь и советы коллективного разума! ;)
А, никто не помнит, случайно? Аарон из Зеландии. Он менять коллектор? Помню он писал про 600+ сил.
Нашел:
Intake Manifold: The stock ATR intake manifold has very long runners like the N/A manifold and is not very good for power. Changed it to a Evo 6 Intake manifold. Hard install only due to access- Had to run an aftermarket fuel rail as the accelerator cable rubbed against the stock fuel reg.
Have made 400KW at the wheels at 35psi on 50/50 meth water and have done 80,000km with the car modified from day one. And my current quickest 0-100kph is 2.6secs. This was at the drag strip with street tires and a VHT prepped track
