Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 12.05.2008, 22:25   #76
VAA
Аватар для VAA
Авто: Ford Kuga
По умолчанию Ответ: Уходит Антифриз.
Сообщение от Relax Посмотреть сообщение
Я как оказалось наврал по поводу цвета . Залит был зеленый, но Экстра синий. Бачок охлаждения заметно потемнел. Лучше позвонить туда, где покупали авто и спросить, что лить.
Днем зашел к дилеру "Редеги-на-садовом". Антифриза у них в наличии не было, но сказали, что рекомендован Mobil Extra G-11 синий.
Купил, долил. Посмотрим, что дальше будет с уровнем.
VAA вне форума   Вверх Ответить с цитированием
Старый 12.05.2008, 22:46   #77
kolonin_sergey
Аватар для kolonin_sergey
Да вроде с нуля зеленый был,я сегодня зеленый купил и долил.
Старый 13.05.2008, 10:26   #78
A.SH.
Авто: Lancer X
В прошлом году на долив покупал Mobil Extra G-11 , но он был зеленым.
A.SH. вне форума   Вверх Ответить с цитированием
Старый 13.05.2008, 16:05   #79
Relax
Аватар для Relax
Ну значит цвет точно пофиг, у меня тоже Mobil Extra G-11, но синий
Relax вне форума   Вверх Ответить с цитированием
Старый 13.05.2008, 16:41   #80
Shpunt
Аватар для Shpunt
Авто: CX-5 Sport
щас залит синий
Старый 13.05.2008, 20:21   #81
A.SH.
Авто: Lancer X
Ключевой признак - на банке должна быть указана
спецификация VW G11.
Красный G12 не лить!
Старый 19.05.2008, 17:51   #82
Stets
Аватар для Stets
Авто: Nissan Murano II
Вылезла эта же проблема, не помню сколько было когда забирал из салона, но позавчера обнаружил что чут ьниже минимума, купил Mobil Extra G-11, залил, ждемссс...
Stets вне форума   Вверх Ответить с цитированием
Старый 20.05.2008, 14:16   #83
antwerp
А у меня все-равно продолжает немного уходить. На 1500 залил до нормы (середина между min и max), сейчас 4500, а антифриз почти на минимуме. К чему бы это?
antwerp вне форума   Вверх Ответить с цитированием
Старый 20.05.2008, 19:42   #84
Stets
Аватар для Stets
Сообщение от antwerp Посмотреть сообщение
Скорее всего к внеплановой поездке в сервис...
Старый 20.05.2008, 22:16   #85
IgSo
Аватар для IgSo
Авто: DODGE RAM 1500
Рано долил
Старый 20.05.2008, 23:38   #86
DSW
Аватар для DSW
Авто: Out XL 3.0 black
Смотри утром, на холдном Авто. Ни хрена НИЧЕГО НЕ УТЕКАЕТ!
Старый 21.08.2010, 19:23   #87
Elenochkka
Аватар для Elenochkka
По умолчанию Re: Уходит Антифриз.
Подскажите пожалуйста как избавиться от воздушной пробки? И куда вообще заливать антифриз? В расширительный бачок или в радиатор? Спасибо.
Elenochkka вне форума   Вверх Ответить с цитированием
Старый 24.08.2010, 22:41   #88
Штурмбаннфюрер
Аватар для Штурмбаннфюрер
Авто: Outlander 2.4 MIVEC
Сообщение от Elenochkka Посмотреть сообщение
попробуй встать в горку и погазовать,
либо открой крышку радиатора и "пожамкай" шланги.
___________________________________________________
на холодном двигателе открой крышку радиатора и посмотри где жидкость, если под горлышко, то доливай только в бачок,
если там мало то лей туда в первую очередь, а потом уже в расш.бачок.
Штурмбаннфюрер вне форума   Вверх Ответить с цитированием
Старый 20.09.2010, 18:03   #89
Евгений!!!
По умолчанию Re: замена антифриза
Нагреть до открытия термостата и сливать через краник радиатора,
Евгений!!! вне форума   Вверх Ответить с цитированием
Старый 20.09.2010, 19:22   #90
сергеев.а
Авто: Pajero IV 3.0 AT
Сообщение от Евгений!!! Посмотреть сообщение
где там краник?видал на схеме хомут нижний снимают.
сергеев.а вне форума   Вверх Ответить с цитированием
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 19:48. Часовой пояс GMT +3.
