Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 07.06.2017, 15:06   #391
Nicolo
Авто: Outlander GT 2019
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Спасибо!
Еще вопрос: если в комплекте 2034 не идет Навител (вообще нет носителей с навигацией) как проще всего установить в нее Навител? Какой носитель купить?
Nicolo на форуме   Вверх Ответить с цитированием
Старый 07.06.2017, 16:56   #392
Falcon62
Аватар для Falcon62
Сообщение от Nicolo Посмотреть сообщение
Так вроде флешки еще никто не отменял. Или я не понял вопроса?
Falcon62 вне форума   Вверх Ответить с цитированием
Старый 07.06.2017, 17:57   #393
Nicolo
В 2034 вставляется флэш или SD-карта?
У меня USB-порта в авто нет.
Старый 07.06.2017, 18:55   #394
AS21
Аватар для AS21
Авто: ASX 1.6 2WD MT
Как правило:
- SD карта для навигации
- два-три USB порта
Надо смотреть описание конкретной модели
AS21 вне форума   Вверх Ответить с цитированием
Старый 07.06.2017, 20:39   #395
Falcon62
Аватар для Falcon62
флэш или SD-карта?
Как правильно подсказывают выше, обычно, есть и то и другое.
Старый 07.06.2017, 21:17   #396
Nicolo
Но я выше на картинке не вижу входа для Флэш...или я не прав?
Конкретная модель: 2034 андроид 5.1.1 2016 года:
https://ru.aliexpress.com/item/8-Qua...608.0.0.8eB4TN
Старый 07.06.2017, 23:02   #397
Нецид
Аватар для Нецид
На самом ГУ нет. От магнитолы идет шнур с 2-3 usb входами на конце, который выводится обычно в бардачок.
Нецид вне форума   Вверх Ответить с цитированием
Старый 07.06.2017, 23:04   #398
AS21
Аватар для AS21
3 - USB
1 - SD 8 Gb: Navi
Спосите у продавца
Старый 08.06.2017, 01:31   #399
AntonB
А кто какой микрофон ставил взамен штатного, который идет с магнитолой?
AntonB вне форума   Вверх Ответить с цитированием
Старый 08.06.2017, 09:33   #400
Falcon62
Аватар для Falcon62
Посмотрите лучше https://ru.aliexpress.com/store/prod...612.0.0.W3K0Bi или https://ru.aliexpress.com/store/prod...612.0.0.2WycTe. Все поинтереснее будет, хотя и дороже.
Старый 08.06.2017, 09:35   #401
AS21
Аватар для AS21
Сообщение от Falcon62 Посмотреть сообщение
Посмотрите лучше
Тогда уж лучше ищите на 7-м андроиде RX-3 + 2 Gb
Старый 08.06.2017, 10:36   #402
Alur54
Сообщение от AS21 Посмотреть сообщение
а они есть? пример хотя бы в студию )
Alur54 вне форума   Вверх Ответить с цитированием
Старый 08.06.2017, 10:39   #403
AS21
Аватар для AS21
Да, уже в продаже
Правда на мой ASX - пока нет, по-этому и не ищу
Скоро мой коллега в Москве ее получит из Китая
Смотрите на 4pda
Старый 08.06.2017, 11:21   #404
ДмитрийГлаз
Аватар для ДмитрийГлаз
Они на 6 андроиде ещё сырые, куда там 7.!? Виджеты так и не смог поставить(кроме яндекс пробок и штатных Виджетов ничего больше не отображается) и это только один из примеров глюков. (ещё звук пропадает при заводе, язык на английский сбрасывается в системе при стоянке несколько дней) , мелочи но все же. А так да 8 ядерная 32 гиг и 2 гиг оперативки огонь магнитола.
Последний раз редактировалось ДмитрийГлаз; 08.06.2017 в 11:26.
Старый 08.06.2017, 11:28   #405
AS21
Аватар для AS21
Я про перспективу по железу
Если брать сейчас, то уже ЭТУ
А глюки у Китайцев всегда будут
Даже на 5.1 - до сих пор вылизывают
На то и 4pda
Текущее время: 17:06. Часовой пояс GMT +3.
