22.04.2015, 23:08
#1
Re: OBD-2 (OBD-II), ELM 327
Сообщение от
salexey
А когда начинает считать счётчик? От 90 градусов?
Нет, данные они должны быть всегда. А вот изменения накапливаются начиная с 90 градусов.
У Вас температуру CVT нормально показывает?
22.04.2015, 23:14
#2
Yuriy_SPb , температуру показывает. Сегодня с 15 до 80 прогоелась за час.
Вот что в файле
"2013MY CVT temp","CVT temp","2103","(0.000000002344*(N^5))+(-0.000001387*(N^4))+(0.0003193*(N^3))+(-0.03501*(N^2))+(2.302*N)+(-36.6)","-50","250","°C","7E1"
"2013MY CVT oil degradation","CVT oil deg","2110","AC*256+AD","0","220000","count","7E1
"2013MY CVT Primary Speed","CVT Pr.Speed","2103","(A-2)*32","0","8160","rpm","7E1"
"2013MY CVT Secondary Speed","CVT Sec.Speed","2103","(B-2)*64","0","16320","rpm","7E1"
"2013MY CVT Real Speed Ratio","CVT Speed Ratio","2103","E/100","0.39","2.34","int","7E1"
"2013MY LU solenoid monitor current","LU mon.curr","2105","G*0.256+H*0.001","0","0.7","A ","7E1"
"2013MY CVT Selector P","CVT P","2107","{A:4}","0","1","off/on","7E1"
"2013MY CVT Selector R","CVT R","2107","{A:5}","0","1","off/on","7E1"
"2013MY CVT Selector N","CVT N","2107","{A:6}","0","1","off/on","7E1"
"2013MY CVT Selector D","CVT D","2107","{A:7}","0","1","off/on","7E1"
"2013MY CVT Selector L","CVT L","2107","{A:2}","0","1","off/on","7E1"
"2013MY CVT Selector Ds","CVT Ds","2106","{B:3}","0","1","off/on","7E1"
"2013MY CVT Gear Number","CVT Gear","2106","C+1","1","6","int","7E1"
"2013MY Датчик скорости ПЛ колеса","Скор ПЛ кол","2101","A*2.56+B*0.01","0","655.35","км/час ","784"
"2013MY Датчик скорости ПП колеса","Скор ПП кол","2101","C*2.56+D*0.01","0","655.35","км/час ","784"
"2013MY Датчик скорости ЗЛ колеса","Скор ЗЛ кол","2101","E*2.56+F*0.01","0","655.35","км/час ","784"
"2013MY Датчик скорости ЗП колеса","Скор ЗП кол","2101","G*2.56+H*0.01","0","655.35","км/час ","784"
Из этого всего не показывает только деградацию масла и скорости 2х задних колёс. И передних с перерывом.
Последний раз редактировалось Yuriy_SPb; 31.08.2016 в 23:18 .
Причина: Спойлер
22.04.2015, 23:21
#3
Сообщение от
salexey
Пропущена последняя кавычка, если все так
Сообщение от
salexey
Скорее всего не успевает
Это у Вас на одном экране все, или в лог пишите?
Последний раз редактировалось Yuriy_SPb; 22.04.2015 в 23:31 .
22.04.2015, 23:40
#4
А температурные режимы раздатки разве не нужны?
Добавлено через 5 минут
Сообщение от
salexey
Со скоростями надо еще разобраться. По мануалу для ABS, в таблице приведены скорости, который сохраняются в момент возникновения ошибки. Возможно мы смотрим какие-то другие параметры. Такой же набор скоростей есть в блоках AWD и ASC.
23.04.2015, 09:59
#5
вот еще несколько пидов:
"ABS actuator signal","ABS signal","2107","{C:0}","0","1","off/on","7E1"
"TCL actuator signal","TCL signal","2107","{C:4}","0","1","off/on","7E1"
"ASC actuator signal","ASC signal","2107","{C:6}","0","1","off/on","7E1"
23.04.2015, 10:19
#6
блок AWC, попробуйте должно показывать пробег:
Код:
"Mileage counter","Mileage","2130","C*6553.6+D*25.6","0","500000","km","7B6"
Последний раз редактировалось v888v; 28.04.2015 в 09:52 .
23.04.2015, 10:37
#7
Сообщение от
cintakc
"Mileage counter","Mileage","2130","C*6553.6+D*25.6","0","5 00000","km","7B6"
Что то не работает. Ошибка наверно ,"5 00000",
пробел убрал - датчик появился
Добавлено через 1 час 22 минуты
У меня вот вопрос - а у всех так долго прогревается коробка? У меня за 30 минут езды по умеренным пробкам - до 45 -50 градусов дошло всего. Рабочая температура я так понял это 65 ?
Последний раз редактировалось salexey; 23.04.2015 в 10:56 .
23.04.2015, 12:18
#8
Сообщение от
salexey
да, естественно ошибка, пробел проскочил,
а показания то соответствуют
наверное ошибка форума , пишу правильно 500000, а когда вхожу в предварительный просмотр, то появляется пробел
максимально возможные показания по формуле 1677696 км
Последний раз редактировалось cintakc; 23.04.2015 в 12:27 .
23.04.2015, 17:26
#9
Авто: Out III 3.0
Сообщение от
cintakc
Показания 0.
Сообщение от
salexey
так понял это 65
80-90.У меня быстрее греется-стоит термостат.
С температурой
CVT ,так и нет предельной ясности.
В субботу
kidanov ,едет с MUT,кнопку свою катать.
У него установлен,мультитроникс,попросить его,чтобы сверил.
23.04.2015, 17:39
#10
Сообщение от
Ан-дрей
В субботу kidanov ,едет с MUT,кнопку свою катать.
Одна беда, одновременно все подключить проблематично.
23.04.2015, 19:58
#11
Сообщение от
Ан-дрей
С температурой CVT,так и нет предельной ясности.
С этим, как раз, уже все ясно
Есть count's, а если нужны градусы, то выбирай формулу любой длины, какая нравится
Сообщение от
cintakc
на счет отсутствия показаний ... то здесь скорее всего виноват адаптер ELM327
Видимо с AWC так оно и есть, на старте получаем один правильный ответ (если повезет), а дальше ELM присылает всякий бред. Надо думать ...
23.04.2015, 09:21
#12
Сообщение от
Yuriy_SPb
Да вроде нормально показывает. По формуле
Сообщение от
v888v
есть сомнения
Вот по этой формуле может быть ошибка?
"2013MY CVT oil degradation","CVT oil deg","2110","AC*256+AD","0","220000","count","7E1"
Кстати 1 раз скакнуло значение на какое то немыслимое. Но увидел краем глаза и не запомнил...
23.04.2015, 10:00
#13
Сообщение от
salexey
"2013MY CVT oil degradation","CVT oil deg","2110","AC*256+AD","0","220000","count","7E1 "
Для меня ориентир:
Сообщение от
globus2003
Сообщение от
v888v
Точно???
Абсолютно!
4405 мут против 4405 торк.
В данном случае у меня предложение ко всем участникам тестов одно чтоб не запутаться:
В основном, с этой же темы узнали про такие возможности.
Давайте будем вежливы - взяли инфу для теста с темы, выкладывайте результаты и строчку по которой тестили. Так все и помогут друг другу.
Сообщение от
Михалч
на пробег 7700.
что уже с радиатором такой пробег??
23.04.2015, 10:25
#14
Авто: Toyota RAV4
Сообщение от
v888v
без.
Я опять что-то напутал?
Текущее время: 16:36 . Часовой пояс GMT +3.
