Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 28.03.2017, 14:25   #271
val078
Сообщение от Macarr0n Посмотреть сообщение
На день рожденья Али будет "скидка" , даже чуть больше, чем я брал в ноябре, отследив изменение цены на товар. С доставкой получается 17 тыс.
Неверно,если с мобильного али брать,то 15800
val078 вне форума   Вверх Ответить с цитированием
Старый 28.03.2017, 17:36   #272
Potable
Аватар для Potable
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Её и жду...сподвигла к покупке
Старый 28.03.2017, 18:25   #273
Levashov
а никто случайно не делал BackUp заводских настроеек??
Levashov вне форума   Вверх Ответить с цитированием
Старый 28.03.2017, 21:04   #274
amel
Аватар для amel
Сообщение от Levashov Посмотреть сообщение
Это не андроивдская часть, бекап не получится сделать
Старый 29.03.2017, 07:36   #275
Levashov
чеж я не заскринил при покупке((
Старый 29.03.2017, 13:49   #276
mitsubi
Авто: L200 2.5 DiD AT
для сохранения ВСЕХ заводских настроек нужно в этих Заводских настройках в Андроиде нажать кнопку EXPORT и их можно сохранить на флешке или карточке в файл (d)mcu.cfg и потом можно их обратно загрузить в магнитолу из режима восстановления
mitsubi вне форума   Вверх Ответить с цитированием
Старый 29.03.2017, 14:48   #277
Potable
Аватар для Potable
А блютузные кнопки на руле прошиваются или их можно выкидывать?
Старый 29.03.2017, 15:08   #278
ДмитрийГлаз
Аватар для ДмитрийГлаз
У меня прошивается так же как и обычные(громкость,стрим и моде) Можно на них хоть громкость запрограмировать.
Старый 30.03.2017, 05:25   #279
Levashov
Сообщение от mitsubi Посмотреть сообщение
а есть у кого этот файл?
Старый 30.03.2017, 19:02   #280
Potable
Аватар для Potable
Коллеги, можно ещё пару вопросов...
1. При подключении НА2034 усилитель (тот который под креслом валяецо) выкидывать? У меня вместо РОкфорда другой вкорячен. Если выкидывать, то сабвуфер как?
2. Обычная аналоговая камера заднего вида в видеовход цепляется? Как ГУ понимает, что нужно этот видеовход включать при включении задней, с САN берет команду? И потом, переключение с паркинга на драйв и обратно всегда через заднюю, это камера всегда будет "возбуждаться", пытаясь что-нить показать?
3. TPMS "по тихому" всегда запущен и, если что, выскакивает с писком-свистом? Или забыл запустить/выгрузил и всё, контроля нет?
4. Интернет лучше смартфоном по Вай-Фаю на ГУ раздавать или отдельный модем в ГУ по ЮСБ воткнуть? А нужен он вообще (и для чего постоянно, ну закачал карты, установил программы, что ещё...)?
5. ТВ у всех на скорости не работает или можно вылечить, например, путем замены антенны, добавки усилителя тв сигнала и т.п.?
Старый 30.03.2017, 19:19   #281
S.Vladimirych
Авто: В поиске
Добрый времени суток!
Подскажите как данное устройство дружит с Iphone6? Работает ли громкая связь, воспроизведение музыки по BT? Можно ли подзарядить?
Присматриваюсь к HA2034 -v600.
Спасибо.
S.Vladimirych вне форума   Вверх Ответить с цитированием
Старый 31.03.2017, 01:35   #282
mitsubi
если усилитель поддерживает внешнее управление, то магнитола имеет сигнал для его вкл-выкл. Для Рокфордовского усилителя нужен либо китайский канбус, либо универсальный адаптер (оба варианта не полностью реализуют все варианты управления усилителем)
у магнитолы есть вход, на который можно подать сигнал, информирующий о включенной задней передаче, например, с селектора, либо можно купить китайский канбус и тогда он возьмет этот сигнал из КАН-шины
нужен именно автомобильный вариант тюнера для скорости 120..180 км/ч либо с 2-мя, либо с 4-мя разнесенными активными антеннами
могу снять со своей, но у меня HA2138
Старый 31.03.2017, 14:20   #283
Potable
Аватар для Potable
Сообщение от S.Vladimirych Посмотреть сообщение
Спасибо.
Наверное лучше этот вопрос задать на прямую проду с Али
Старый 31.03.2017, 14:28   #284
ДмитрийГлаз
Спасибо.
В этой магнитоле есть программа Easy Con. Там помимо сопряжения с Андроид есть и Ios. Через неё наверняка все будет работать.(то что вы делаете на экране смартфона, повторяется и на магнитоле, навигация, музыка, фильмы и т.д.) Точнее не скажу, у меня нет айфона.
Старый 31.03.2017, 19:24   #285
Levashov
дайте кто нить ссыль на андройд февральский
Текущее время: 11:55. Часовой пояс GMT +3.
