Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 24.12.2013, 16:56   #286
Zux
Временно никто
Авто: Lancer GT 2.4
По умолчанию Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
Антифриз проверяется легко и дешево и без холодильника:
http://jonnesway.su/product_10333.html
Номер для заказа AR030002, есть например в емексе.
Zux вне форума   Вверх Ответить с цитированием
Старый 24.12.2013, 18:30   #287
Alexxander
Аватар для Alexxander
Сообщение от Zux Посмотреть сообщение
Судя по рисунку - эта хреновина измеряет только плотность)))))))))))))
Но ЭТОГО мало для оценки качества бу антифриза.
Старый 24.12.2013, 18:41   #288
Zux
Временно никто
Авто: Lancer GT 2.4
Проверяет:
1. Температуру замерзания и кипения
2. Визуально (видно антифриз)
Какие вам еще нужны эксперименты? Холодильник она полностью заменяет.
Старый 25.12.2013, 17:23   #289
Alexxander
Проверяет:
ЕЩЕ раз про 0н0насы))))) Вот та ХЕРНЯ со стрелочкой может измерять только плотность и точка. Если есть сомнения, то читайте физику средней школы, какой класс не помню. Температура замерзания и закипания жидкостей и растворов зависит от нескольких физических и химических факторов, попробуйте это понять.
Старый 25.12.2013, 17:49   #290
Zux
Временно никто
Авто: Lancer GT 2.4
Да вы прям Америку открыли, товарисч . На практике этого устройства вполне хватает, если измерения делаются при примерно одинаковых условиях. И эта штука только для этиленгликолевых смесей, если начать заниматься буквоедством. Просто проще этот прибор использовать, чем тащить что-то к продуктам в морозилку. Вы думаете официальные дилеры чем-то принципиально другим пользуются?
Последний раз редактировалось Zux; 25.12.2013 в 18:08.
Старый 25.12.2013, 18:58   #291
Alexxander
На практике не надо тупить и эксплуатировать антифриз больше срока (пробега) указанного производителем, пользуясь всякой херней))))))) На свежем антифризе ваша цацка наверно что-то в состоянии +- правильно показать. А вот на разложившемся не уверен, продукты распада будут плотность давать, а вот будут ли удерживать молекулы воды от кристаллизации не известно. Это же относится и антикоррозионным свойствам. А в общем каждый борется со скукой по своему)))
И еще, ваша цацка холодильник ни полностью ни частично заменить не может, холодильник может водку охладить, а цацка нет)))))))
Добавлено через 17 минут
Ниже ссылочка на статью по антифризам. Так, для интереса)))
http://www.abok.ru/for_spec/articles.php?nid=5318
посмотрите табличку по коррозийности, там есть ответ на утверждение, если не замерзает, то это хороший антифриз))))))))))))
Добавлено через 31 минуту
Резюме
Если все правда и антифриз качественный, то наверно можно на нем кататься лет 10))))))))))
Добавлено через 32 минуты
Выдержка из статьи ""Современные пакеты присадок способны эффективно защищать металлы теплообменных систем от коррозии и сохранять эти свойства в течение 10 и более лет.""
Последний раз редактировалось Alexxander; 25.12.2013 в 19:18.
Старый 24.01.2014, 23:15   #292
lepeha
а кто что про это сказать может Антифриз "PSA 4007 C-CROSSER", 5л цена от 820р.
lepeha вне форума   Вверх Ответить с цитированием
Старый 25.01.2014, 14:03   #293
amel
Аватар для amel
Сообщение от lepeha Посмотреть сообщение
Без part numbera непонятно. Хороший антифриз за адекватные деньги Ravenol 4014835713550
Старый 25.01.2014, 15:11   #294
Leo-sun
Аватар для Leo-sun
Только нет его сейчас в наличии ни на екзисте, ни на емексе.
Старый 25.01.2014, 22:33   #295
amel
Аватар для amel
Сообщение от Leo-sun Посмотреть сообщение
Покупал полгода назад, странно что пропал
http://msk.pulscen.ru/products/40148...ta_5l_11468779
не реклама
Последний раз редактировалось amel; 25.01.2014 в 22:38.
Старый 25.01.2014, 22:45   #296
lepeha
9979.A6 - "PSA 4007 C-CROSSER", 5л
Старый 04.02.2014, 11:38   #297
V_Kostya
Аватар для V_Kostya
При замене ГРМ и помпы заменил антифриз.
Обратно залили 6,5 л. вот такого:
V_Kostya вне форума   Вверх Ответить с цитированием
Старый 17.02.2014, 10:54   #298
Klasik
Аватар для Klasik
Авто: XL 3.0 S01
Комрады, не подскажете, где можно найти оригинальный антифриз: MZ381033, MZ381032 или 0103024? Известные интернет-магазины не могут поставить.
Klasik вне форума   Вверх Ответить с цитированием
Старый 17.02.2014, 11:30   #299
AndreyDAR
Аватар для AndreyDAR
Авто: Outlander XL 3.0 Max
Klasik, известен ли тебе autodoc или нет, но в нем все есть!
Старый 17.02.2014, 11:45   #300
Klasik
Аватар для Klasik
Авто: XL 3.0 S01
Сообщение от AndreyDAR Посмотреть сообщение
Звонил им, привезти не смогут.
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 16:48. Часовой пояс GMT +3.
