Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 02.04.2017, 17:48   #286
VISk
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Возможно ли редактировать линии парковки на изображении камеры заднего вида ?
Я так понимаю, что в прошивке есть графический файлик изображения этих линий, который накладывается на изображение. Так вот можно ли его подредактировать, ни кто не пробовал ?
VISk вне форума   Вверх Ответить с цитированием
Старый 02.04.2017, 19:35   #287
AS21
Аватар для AS21
Авто: ASX 1.6 2WD MT
Сообщение от VISk Посмотреть сообщение
Да? Поищите методику на 4pda
http://4pda.ru/forum/index.php?showt...ntry60022006Я там в двух местах видел. Вроде надо править приложение backview.apk
AS21 вне форума   Вверх Ответить с цитированием
Старый 03.04.2017, 19:23   #288
Potable
Аватар для Potable
Блин, это что, рецепт апгрейда?
https://youtu.be/8smMyEOMYU8
Старый 03.04.2017, 19:30   #289
amel
Аватар для amel
Да, можно заказать плату (китайцы неохотно продают отдельно).
Старый 03.04.2017, 23:29   #290
val078
интересно скока стоит плата
val078 вне форума   Вверх Ответить с цитированием
Старый 04.04.2017, 07:04   #291
Nikdas
Они бы еще 10" прикрутили к этому устройству с 2Гб памяти и цены бы им не было
Старый 06.04.2017, 16:25   #292
Levashov
у кого на руле кнопки громкой связи есть подскажите их можно задействовать в магнитоле?
Levashov вне форума   Вверх Ответить с цитированием
Старый 06.04.2017, 16:30   #293
Potable
Аватар для Potable
Сообщение от Levashov Посмотреть сообщение
Ну вот же на предыдущей странице..https://out-club.ru/board/showpost.p...&postcount=278
Старый 11.04.2017, 12:14   #294
igorkud90
Сообщение от mitsubi Посмотреть сообщение
Для Рокфордовского усилителя нужен либо китайский канбус, либо универсальный адаптер
А не могли бы вы указать ссылки на канбус который нужно приобрести, и на универсальный адаптер?
Хочу приобрести данную магнитолу, хочу купить все сопутствующие товары, чтобы к моменту подключения все было на руках.
Спасибо
igorkud90 вне форума   Вверх Ответить с цитированием
Старый 11.04.2017, 12:21   #295
val078
Сообщение от igorkud90 Посмотреть сообщение
Спасибо
только мито-02,с него все колонки и саб регулируются,но!!цена 5500,и кнопки на руле не работают,нужно два кан баса ставить,один на кнопки родной, мито на музыку
Старый 11.04.2017, 18:53   #296
Shaurma54
Аватар для Shaurma54
Здравствуйте, приобрел HA3024 с али, подключил вроде все норм, но нет =(
При заведенном двигателе фонит, видимо с генератора, чем больше скорость тем Выше фон в динамиках. Подскажите в чем может быть проблема? Для чего черный проводок с наклемником не подписанный? Подключал сам, с CAN адаптером. без рокфорда. Если было - сорри, поиск курил - ни чего не нашел.
Подскажите куда смотреть?
Shaurma54 вне форума   Вверх Ответить с цитированием
Старый 11.04.2017, 20:45   #297
ДмитрийГлаз
Аватар для ДмитрийГлаз
@Shaurma54, там в комплекте было два шлейфа. Один под рокфордом с кан.Другой под без рокфорда.Попробуй другой шлейф. Чёрный провод скорее всего заземление. Я его не стал никуда подключать.
Старый 12.04.2017, 11:29   #298
Shaurma54
Сообщение от ДмитрийГлаз Посмотреть сообщение
Не помогло(
Старый 12.04.2017, 15:01   #299
Potable
Аватар для Potable
@Shaurma54, на 4pda емкость по питанию меняют. Можно попробовать снаружи конденсатор на 6800 - 10000мкФ х 25В подцепить, если поможет, вскрывать и менять.
Старый 13.04.2017, 08:32   #300
pinzet
Аватар для pinzet
Авто: C-Crosser 2.4 CVT
@igorkud90, если денег не жалко, то адаптер ctsmt002.2. Он у меня стоит с рокфордом. Кнопки и саб управляются!
На форуме отчёт делал по нему.
Текущее время: 00:23. Часовой пояс GMT +3.
