Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 22.04.2017, 12:09   #316
Alur54
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Сообщение от ДмитрийГлаз Посмотреть сообщение
Два USB. Подключал жеский к ним от ноутбука на 320гиг. Читает без проблем
надо брать
Alur54 вне форума   Вверх Ответить с цитированием
Старый 22.04.2017, 17:08   #317
Potable
Аватар для Potable
@Alur54, у меня три юсб.
Старый 22.04.2017, 22:26   #318
Pistolero
Прошивался на HA_dmcu_2-22. магнитола стала через раз зависать на запуске. Откатился до прошивки MCU+2.16 и андроид 07.12.2016. работает более менее стабильно. Прошивался кто нибудь на dmcu_ha_2.44? И на и андроид new4_ rk3188_5.1(20170307)(01)? Что можете сказать о стабильности?
Pistolero вне форума   Вверх Ответить с цитированием
Старый 22.04.2017, 23:05   #319
lyaxndr
Сегодня, наконец, решил проблему с притуханием экрана при включенном ближнем свете(у меня включен постоянно евросвет, соответственно, ближний горит всегда, и экран все время находился в притушенном состоянии).
До этого пользовался прогой MTC volume 2.6, но она не очень удобна.
Если кому нужно, могу поделиться как решить эту проблему
lyaxndr вне форума   Вверх Ответить с цитированием
Старый 23.04.2017, 08:19   #320
Levashov
Сообщение от Pistolero Посмотреть сообщение
Я прошился работает стабильно, раньше флешки подвисали сейчас пока не замечено!
Добавлено через 41 секунду
Сообщение от lyaxndr Посмотреть сообщение
давай расскажи
Levashov вне форума   Вверх Ответить с цитированием
Старый 23.04.2017, 13:31   #321
lyaxndr
Все очень просто, ГУ узнает про ночной режим через провод IL. Он розового цвета, выходит из основного разъема ГУ.
По умолчанию он соединен с проводом, идущим из машины , на котором появляется 12В при включении ближнего света.
Я отказался от идеи подключения умного автоматического режима переключения противотуманки(взамен ДХО)-ближний свет и по моей просьбе уважаемый Дмитрий(Ежик Пых) вернул евросвет.
Соответственно, экран ГУ находился все время в ночном режиме.
Режем этот розовый провод(он в фишке ГУ - №4).
Изолируем конец, который идет дальше в торпеду, а тот, который шел в ГУ соединяем с оранжевым проводом(с серебристыми полосками), идущем к разъему нижней панели под ГУ(где аварийка, подушки).
На этом проводе появляется 12В при включении подсветки кнопок-крутилок на торпеде. Что нам и нужно.
Я нарастил розовый провод и подпаялся к оранжевому, не разрезая его.
Все заработало как надо.
До этого пользовал MTC Tool прогу, но она затемняет экран только по GPS времени, соответственно, туннели-грозовые черные тучи она не видит.
Фото выкладываю
Старый 23.04.2017, 14:38   #322
Владислав123
Сообщение от Владислав123 Посмотреть сообщение
рокфорда не было. Звук у магнитолы намного лучше, чем был штатный. Подключал по канбасу (написано на нём Паджеро блин). Кнопки на руле обучились по счёту раз. Монитор - это я имел вводу свою голову теперь (для регистратора в зеркале она внешний монитор).
Самое интересное раздал интернет со своего Huewai 4х. А голова подключилась и пароль не спросила. Странно, я делал соединение защищённым и на работе просто так ко мне никто не подключится.
Браузер работает шустро. Мне понравилось).
Успел соединение сделать с телефоном. Соединился как с родным (звук в машине приличный при разговоре. Вывел внешний микрофон . Закрепил возле руля. Завтра фотку прикреплю как всё выглядит.
Владислав123 вне форума   Вверх Ответить с цитированием
Старый 23.04.2017, 15:33   #323
lyaxndr
у меня еще периодически виснет это ГУ и иногда просто не реагирует на кнопки на руле ((( как буд-то забывает их
Старый 24.04.2017, 10:10   #324
anhoro
Добрый день всем!
Не подскажете с решением проблемы подключения камеры заднего вида?
Получил недавно это ГУ. Установил. Все вроде работает (из основного функционала), Bluetooth пока не коннектил, т.к. жду еще ELM модуль. Читал, что его первым нужно коннектить, а не телефон. Тогда и будет счастье. Прошивку не обновлял, стоковая стоит. Вернусь к вопросу про камеру. До этого у меня стояло салонное зеркало с камерой заднего вида. CAN-адаптер стоит, работает нормально. Выход камеры - 4-пиновый круглый разъем. С этим ГУ шел кабель RCA-RCA. В голову я его подключил, протянул к камере. Разрезал провода от камеры, чтобы соединить напрямую (красный, черный, желтый, зеленый). На мультиметре батарейка загнулась, поэтому воспользоваться им вчера не смог. В общем, видео так и не увидел. Черный провод от камеры соединял с оплеткой кабеля с RCA. Основную жилу от RCA соединял с другими проводами от камеры (по очереди). Надеюсь, ничего не спалил. На ГУ при включении заднего хода выводится черный экран с восклицательным знаком (при AV-In тоже самое). Сама камера запитана, подсветка горит. У кого-то была похожая ситуация? Что можно сделать?
anhoro вне форума   Вверх Ответить с цитированием
Старый 24.04.2017, 13:08   #325
Potable
Аватар для Potable
@anhoro, проверить по раздельности работоспособность камеры и ГУ в части видеовхода с камеры.
Старый 24.04.2017, 15:23   #326
anhoro
Спасибо. Камера была рабочая (до установки ГУ, т.к. зеркало работало). А вот видеовход ГУ нужно подумать, как проверить, откуда видео через RCA завести.
Старый 25.04.2017, 07:54   #327
errrr
Можно ли научить стоковый плеер нормальной навигации по папкам?
Все в нем устраивает, кроме выбора альбома - они все единым списком идут,
а когда их более сотни на флешке - замучаешься искать нужный...
Или только сторонние плееры помогут?
errrr вне форума   Вверх Ответить с цитированием
Старый 25.04.2017, 22:56   #328
Нецид
Аватар для Нецид
Сделал на этом ГУ прямое управление звуком. В принципе результатом доволен. В авто из штатной акустики остались только динамики Rockford. Подумываю заменить и их, но мучают сомнения. Вопрос: это обычные динамики или мидбасовые тоже присутствуют? Хочется НЧ побольше и по качественнее, но боюсь, как говорится, поменять "шило на мыло". И еще вопрос: у динамиков размер ведь 16см? Реально ли на их место установить динамики большего размера, например, 16,5 см?
Последний раз редактировалось Нецид; 25.04.2017 в 23:12.
Нецид вне форума   Вверх Ответить с цитированием
Старый 27.04.2017, 11:32   #329
Potable
Аватар для Potable
При установке ГУ штатный блюпуп можно демонтировать?
Старый 27.04.2017, 11:37   #330
Levashov
Сообщение от Нецид Посмотреть сообщение
16.5 это стандарт динамиков и все они считаются мидбасами, сочный басс можете получить методом прослушивания что понравиться то и взять.
Ps если будете менять динамики я готов купить рокфорды по разумной цене
Текущее время: 23:51. Часовой пояс GMT +3.
