Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1.warning When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap. 2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>. 3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3> 4.Remove the radiator condenser tank and drain the coolant. 5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area. 6.Connect the cooling water line hose. <4B1> 7.Connect the water feed hose B. <6B3> 8.Securely tighten the radiator drain plug. 9.Reinstall the radiator condenser tank. 10.caution Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
Quantity:
7.5 L <4B1>
9.5 L <6B3>
(including 0.65 L in the radiator condenser tank)
note For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely. 12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line. 13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks. 15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port. 16.Tighten the radiator cap securely. 17.caution Do not overfill the radiator condenser tank.
Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
Всем привет!
Абсолютно не могу добыть MZ 101006 Антифриз-концентрат "SUPER LONG LIFE COOLANT", 2л: сроки сумасшедшие, цена неадекватная, поставщики красные - заказывать смысла нет.
По поводу замены радиатора надо как минимум долить, а лучше поменять антифриз.
Мобиловский сравним по качество/составу присадок, или есть более подходящий?
Сообщение от Leo-sun
Равенол чем не устраивает? Номер для заказа есть в этой теме.
Если про этот Ravenol 4014835713550, то его хрен найдёшь. В своё время менял именно на такой. По деньгам совсем недорого стоил, аналог оригинала. А так советую Mobil или Nissan KE90299944 (5 л - 1250 р.)
Добавлено через 35 минут
Про Равенол я махнул, у него новый артикул -4014835755857.
Добрый день, подскажите пожалуйста: есть два Аута XL - один 2008, другой 2011 года выпуска, оба трехлитровые. Можно ли залить в оба этих автомобиля Mobil Antifreeze Advanced красного цвета? Будет ли это наилучшим по качеству выбором?
CyberStorm, очень странно, потому что в моей книжке по эксплуатации автомобиля написано, что нужно использовать антифриз "DIA QUEEN SUPER LONG LIFE COOLANT PREMIUM или аналогичный (аналог должен представлять собой высококачественную охлаждающую жидкость на основе этиленгликоля, не содержащую силикатов, аминов, нитратов и боратов и произведенную с использованием долговечной гибридной органическо-кислотной технологии".
CyberStorm, MZ311986 - это Long Life Coolant, который не подходит в автомобили 2011 года выпуска и младше - для них нужен Super Long Life Coolant Premium (MZ320130), который сейчас невозможно заказать
Как вариант японский антифриз TCL есть как концентраттак и готовый. Соответствует требованию митсу Super LLC. На 4 года или 80 т.км пробега. Брал в автодоке, там есть еще и концентрат. В ексист только готовый.
