Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 06.09.2017, 08:24   #421
BRICK71
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Код рамки плиз.
BRICK71 вне форума   Вверх Ответить с цитированием
Старый 06.09.2017, 09:03   #422
AS21
Аватар для AS21
Авто: ASX 1.6 2WD MT
Сообщение от val078 Посмотреть сообщение
гамно эти магнитолы,пользую две штуки,пятый и шестой андроиды,
Не согласен, да, какчаество сборки бывает не предсказуемое, но и цена ведь не такая, как пионер!!!
А насчет отваливаний, если не железо виновато - идите на 4 pda, там куча правильных уже прошивок на любой вкус, и все они работают без отваливаинй
AS21 вне форума   Вверх Ответить с цитированием
Старый 06.09.2017, 22:56   #423
val078
Блин пионер за 20 можно найти шикарный, а тут это гумно от дядюшки ляо..кода от рамки нет, просто вводите переходная рамка для аутлендер на али
val078 вне форума   Вверх Ответить с цитированием
Старый 07.09.2017, 16:27   #424
Potable
Аватар для Potable
Мда, гамно эти магнитолы,пользую две штуки,пятый и шестой андроиды,постоянные глюки,отваливания,перезагрузки,лучше двухдиновый пионер и переходную рамку,совет для тех,кто ещё не купил
На шестом андройде, с апреля. Вообще без проблем, на стоке (даже шиться не собираюсь, незачем). Рекомендую. Единственный некритичный для меня недочет: после сна/просыпания бывает не заводится блютуз, лечится перезагрузкой. Это всё.
Добавлено через 21 час 10 минут
Ан нет, ещё косяк вспомнил: баланс перед/зад не работает.
Старый 21.09.2017, 10:59   #425
crackerJack
Доброго дня всем,
Ну что же, отпишусь и я по этой балалайке. Брал на али вот эту HA2034-S710. Радио модуль 7850. Взял по отзывам как наиболее устойчивую в плане глюков и т.д. Версия Андроида 7.1.2.
Ставил в Кроссер, музыка без Рокфорда.
По установке
1) Ставил без CAN, т.к. без Рокфорда. Ничего не фонит, посторонних шумов нет. Штатные колонки рвет на части буквально. Слушаю на 10 из 30 максимум. Звук отличный.
2) Кнопки завелись без CAN, первые три дня работали нормально, потом периодически стали отваливаться. Такое ощущение, что Андроид просто рубит приложение "Кнопки" в сон, то все сразу, то частично. Звук чаще всего регулируется, а переключение станций - нет, только после 5-10 нажатий появляется отклик.
По ощущениям.
1) Прием радио изначально показался плохим. В настройках сменил Европу на Россию - стало вообще замечательно. На даче в 65км от МКАД прием супер уверенный. Хотя появился лишний диапазон от 66Мгц до 80+.
2) BT и Samsung S8 завелись отлично, AD2P работает, но с сильной задержкой звука. Раздражает немного.
3) Громкая связь мрак и ужас. Сначала поставил без внешнего микрофона. Приходилось орать прямо в дырочки на панели, чтобы меня хорошо слышали. Поставил 100 рублевое чудо из комплекта, вывел на рулевую колонку. Судя по сразу появившемуся запаху пластика, чудо сгорело мгновенно. Надо искать другой внешний микрофон. Но что странно, меня по прежнему слышат через внешние дырочки на панели, ГУ видимо не понимает, что подключен внешний микрофон.
В остальном доволен. Получил USB, BT_Audio и навигацию, то, что хотел. Собрано качественно. Не лагает, работает очень быстро, звук не пропадает. Т.е. косяка, по сути, два - отваливающиеся кнопки руля, периодически (не могу проследить закономерность), и микрофон.
Брал за 17К. Да, можно было взять версию постарше на PX5, но на 4pda жалуются на глюкавость платформы, в игрушки мне на ней не играть, а для навигации, радио и USB с ДВД этого достаточно.
Последний раз редактировалось crackerJack; 21.09.2017 в 11:00. Причина: Дополнил
crackerJack вне форума   Вверх Ответить с цитированием
Старый 21.09.2017, 12:57   #426
Potable
Аватар для Potable
@crackerJack, ну вот есть же у нас в маш не микрофон от штатного блюпупа. Может его попробовать приерутить?
Старый 21.09.2017, 14:11   #427
crackerJack
А вот тут можно поподробнее, у меня никакого штатного блютус не было. Кроссер версии конфорт, без кнопок управления телефоном на руле.
Последний раз редактировалось crackerJack; 21.09.2017 в 14:12. Причина: дополнил
Старый 21.09.2017, 14:58   #428
Potable
Аватар для Potable
Сообщение от crackerJack Посмотреть сообщение
Пардон, не знал, что блютуз не везде установлен ((. У меня микровон в плафоне передних пассажиров. То же звук встроенного не устраивает, меня плохо слышат, приходится орать в самые дЫрочки ГУ. Вот и подумалось...
Старый 24.09.2017, 20:20   #429
val078
Ага,размечтались,просто так родной микрофон работать с мафонами из китая не будет.. !!!Оффтоп,там паяить немерено надо
Старый 25.09.2017, 09:44   #430
Potable
Аватар для Potable
Дык оно можнО и попаять )))) знать ба ещё чяво.
Старый 27.09.2017, 20:46   #431
Potable
Аватар для Potable
@val078, может поделитесь информацией, как подключить штатный микрофон и что нужно паять, если владеете ей (информацией)?
Старый 27.09.2017, 22:30   #432
xxxstationxxx
Аватар для xxxstationxxx
Поставил вчера Hotaudio HA2034 на Android 5.1.1. Из косяков - не работают кнопки на руле по CAN, но это легко решаемо, нужно соединить напрямую сигнальный провод от кнопок к KEY1 или KEY2 напрямую, в обход CAN. Рокфорд работает, звук хороший, за это больше всего боялся. Wifi встроенный, свистков не нужно. Камера заднего вида включается тоже по CAN. Пока конечно рано советовать ее, поезжу недельку, напишу отзыв, но пока все нравится, особенно экран, скорость работы, тач, полноценный хаб на 4 USB.
Покупал тут http://ru.aliexpress.com/item/8-Quad...8.0.108.xC8pLb
Доставка 6 дней! Курьер доставил домой.
Также заказал регистратор со встроенным Wifi http://ru.aliexpress.com/item/TCOL-N...08.0.56.xC8pLb
Пока не приехал.
Фото под спойлером
Небольшое видео, программ еще не ставил, все как из коробки https://youtu.be/Q6zqMk9_6pA]
я такую уже полгода юзаю...полет нормальный
xxxstationxxx вне форума   Вверх Ответить с цитированием
Старый 01.10.2017, 01:26   #433
val078
Штатный микрофон идёт с усилением,в китаёзах без.,вот и думайте,1.покупать микрофон от камеры видеонаблюдения с усилением 2.читать форум, кто-то перепаивал,но это надо соображать,я не..
Старый 02.10.2017, 16:17   #434
zhaleksey
Авто: Outlander III 2.0 CVT chip by Ёжик Пых
пришла новая голова HA2034-V600 с CAN, все работает, выключаешь зажигание и после включения зажигания - не включается (хотя питание приходит и на желтый и на красный провод), полноценное включение только после сброса фишки и подсоединения ее заново, что не есть хорошо.
авто out xl + rockford (старый магнитофон ставлю все работает безупречно)
подскажите, в чем может быть проблема?
zhaleksey вне форума   Вверх Ответить с цитированием
Старый 03.10.2017, 06:45   #435
Potable
Аватар для Potable
Сообщение от zhaleksey Посмотреть сообщение
Проверить на стенде, проверить не перепутаны ли желтый с красным.
Текущее время: 21:04. Часовой пояс GMT +3.
