Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 13.12.2017, 16:31   #541
Aleks89
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Обнаружил интересный момент. Одновременно работает и ОБД и хендз фри. Т.е. и торк показывает и разговаривать можно. Неожиданная мелочь, а приятно.
А уменя вот часы и гу не фига однлвременно не работают, нужен и там и там один протокол
Aleks89 вне форума   Вверх Ответить с цитированием
Старый 13.12.2017, 16:58   #542
Potable
Аватар для Potable
Сообщение от Aleks89 Посмотреть сообщение
Не пойму о чем речь?
Старый 13.12.2017, 17:06   #543
Aleks89
Часы постоянно сопряжены с телефоном по протоколу, соответственно пока их не отключишь гу не цепляется к телефону
Старый 16.01.2018, 16:42   #544
Macarr0n
Аватар для Macarr0n
Сообщение от Macarr0n Посмотреть сообщение
А у меня сдох экран
Экран поменял, пришлось припаивать подстроечный резистор к видеоплате, т.к. с новой матрицей были мерцания серого цвета. А ещё корпус экрана немного тоньше старого, пришлось подкладывать прокладку, чтобы при нажатии на тач экран не болтался.
Всё удовольствие 3 тыс. руб. плюс знакомый с паяльником SMD компонентов...да...
Macarr0n вне форума   Вверх Ответить с цитированием
Старый 20.01.2018, 18:34   #545
vavans
Привет ребята,
имею устройство
Автомобиль 2 DIN Android GPS для Mitsubishi Outlander авто радио навигация головное устройство мультимедиа IPS Экран 2 ГБ + 32 ГБ 64bit PX5 8-core
https://ru.aliexpress.com/item/2-din...780412312.html
Испытываю плавающие проблемы с включением устройства, у zhaleksey тоже наблюдается подобное. У кого-то еще было такое, как решали?
vavans вне форума   Вверх Ответить с цитированием
Старый 21.01.2018, 16:46   #546
Potable
Аватар для Potable
@vavans, моя включается безотказно. Попробуйте прошить до крайней заводской прошивки(взять у китайц или на 4 пда)
Старый 29.01.2018, 09:53   #547
Junior
Добрый день!
Поделитесь, пожалуйста, опытом использования TPMS от Dasaita, которые дружат с ГУ от Dasaita же, а именно:
1. Можно ли купить комплект с одним контроллером (внутренний модуль) и 8 датчиков (которые внутри колеса монтируются);
2. Как второй комплект датчиков к контроллеру подключать? Каждый раз при смене колес с зимы на лето и обратно? Или один раз подключил, и контроллер все 8 датчиков помнит?
Заранее спасибо!
Junior вне форума   Вверх Ответить с цитированием
Старый 29.01.2018, 11:38   #548
Aleks89
Сообщение от Junior Посмотреть сообщение
Добрый день!
Заранее спасибо!
Опыта использования нет. Но как я понял прописываются по новой каждый датчик спусканием и накачиванием.Себе не рискнул пока купить такой комплект.
Старый 30.01.2018, 09:26   #549
Potable
Аватар для Potable
@Junior, можно взять один блок и 8 внутренних датчиков, но не каждый продавец идет на это, нужно уточнять. Алгоритм такой: пищешь проду, что нужно один юнит и восемь интернал сенсорс, если соглашается, делаешь покупку стандартного набора блок +4 датчика, но не оплачиваешь, прод увеличивает цену, затем платишь.
Старый 30.01.2018, 18:07   #550
Aleks89
Поправлю , прод вышлет новую ссылку в которой будет 8 датчиков и блок.Мне так делали некоторые продавцы
Старый 03.02.2018, 18:34   #551
Potable
Аватар для Potable
@Junior, И ещё. Себе планирую сделать так https://www.drive2.ru/l/472709736668...age=0#comments.
Плюсы: дешевле, проще менять комплект зима/лето, проще установка, сменные батареи датчиков, высокая пионерозащищенность. Из минусов - нужно сделать аккуратно, чтобы не травило, на 16' диски близко к тормозным колодкам и нужно тщательно подобрать вентили и их место установки.
Короче, если аккуратно сделать - одни плюсы.))))
Старый 04.03.2018, 10:59   #552
Roman538
Авто: Outlander XL JFG 3.0 AT
ВСЕМ ПРИВЕТ !
купил себе устройство - Dasaita Android 6.0 Octa Core Car DVD Player for Mitsubishi Outlander 2007 with 2GB Stereo Auto Radio Audio Head unit Support 4G
покупал 2 устройства сразу, с целью удешевления первого.
так вот, ВТОРОЕ УСТРОЙСТВО ПРОДАЁТСЯ !
вот ссылка на производителя: http://www.hot-audio.com/product/Das...ort_4G-84.html
покупал там, не на АлиЭкспрессе.
СТОИМОСТЬ: 345 У.Е. ПРИМЕРНО 19 700 уже в России. в г. Иркутске.
первое поставил себе, работает хорошо, все функции, в т.ч. Рокфорд и кнопки на руле.
могу выслать доп фото и видео.
сейчас размещаю пару ознакомительных фото.
есть описание в моём объявлении на Авито вот ссылка https://www.avito.ru/irkutsk/zapchas...007_1716512489
кому интересно - пишите в личку, отвечу на все вопросы.
Roman538 вне форума   Вверх Ответить с цитированием
Старый 04.03.2018, 11:17   #553
Roman538
ещё хочу добавить : ГУ отлично вписалось в интерьер, пластик почти не отличается от родного.
модель называется HA2034-V600
операционка Андройд 6.0
всё очень достойно и качественно. хороший тачскрин, в т.ч. в морозы.
пользовался в -30. никаких проблем.
вот ещё несколько фото:
Старый 12.03.2018, 14:35   #554
alexandr_yaya
Авто: Outlander XL JFG 2.0 CVT 4WD
Приветствую всех.
Смотрю, основная масса ставит dasaita V600. Себе заказал S720. Сначала заказал потом задумался.) Есть у кого опыт использования? https://ru.aliexpress.com/item/10-2-...532660513.html
alexandr_yaya вне форума   Вверх Ответить с цитированием
Старый 12.03.2018, 14:51   #555
Aleks89
Сообщение от alexandr_yaya Посмотреть сообщение
Приветствую всех.
Есть , брал там же выше посмотри фото есть все устраивает))
Текущее время: 21:01. Часовой пояс GMT +3.
