Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 23.09.2016, 10:14   #46
pinzet
Аватар для pinzet
Авто: C-Crosser 2.4 CVT
По умолчанию Re: Общие вопросы по нештатной музыке на XL: отчеты, советы, обмен опытом...
В комплекте паджеровский. говорят работает! про кнопки https://out-club.ru/board/showpost.p...3&postcount=20 Я подключил по key1, но кнопка "положить трубку " не определяется.
Старый 23.09.2016, 10:36   #47
sergeysgs
Неожидал столь быстрой помощи! В выходные попробую!
Еще странно работает внешний модем. С симкой tele2 никак , а вот с Ётой всегда хорошо, при этом в настройках USB подключение все равно отсутствует! Может позже перепрошью. У Вас так же?
И да, стоит прикрутить на массу провод BRAKE?
sergeysgs вне форума   Вверх Ответить с цитированием
Старый 23.09.2016, 10:41   #48
pinzet
Аватар для pinzet
С модемом сам мучаюсь, никак не запущу E352 и E3372. OBD подключил,для этого обязательно в ГУ указать пароль от elm327 : 1234 или 0000 или 6789. . Если надо смотреть на ходу видео, то тормоз на массу, там как раз один тонкий черный провод массы в колодке есть.
все обсуждаем здесь.
Старый 23.09.2016, 11:04   #49
sergeysgs
Я думаю для интернета купить USB wifi РОУТЕР ТИПА HUAWEI E8372, E8378. Народ на других форумах пишет что идеальное решение.
Старый 25.09.2016, 16:35   #50
sergeysgs
Значит, поставил магнитолу. Когда извлёк старую на WinCE , по ощущениям на Android раза в два легче! В комплекте с новой магнитолой было два жгута проводов, я ставил тот который с CAN адаптером для Pajero. Заработали все кгопки на руле (даже громкость вниз) и камера заднего вида даже без прикручивания красного проводка (в старой магнитоле проводок тоже не цеплял) . Единственное что никак пока не пошло— регулировка подсветка кнопок и автоматическое притухание дисплея. Не знаю, может прошится свежей прошивкой? Навител из комплекта работает прекрасно, пробки кажет. Яндекс навигатор глючит . Пока как то так.
А, ну еще в маркете CarLauncher купил.
Старый 25.09.2016, 21:58   #51
sergeysgs
прошил на августовскую прошивку, автоподсветка дисплея и кнопок заработали и в настройках появилась также регулировка яркости. Но непонятно работает скрытая кнопочка RST- она ничего не сбрасывает, просто затеняет экран и все. это тока у меня?
Старый 26.09.2016, 07:59   #52
pinzet
Аватар для pinzet
RST- где эта кнопка? Если квадратик с крестиком , то это принудительное выключение экрана. Подсоединил паджеровский can, кнопки не заработали, регулировок баланса перед-тыл и саба нет.
Старый 26.09.2016, 10:52   #53
sergeysgs
Регулировки баланса и перед—зад у меня работают. Изначально в системных настройках стояла CAN шина с другого авто, попробуйте сменить. Я про кнопочку Reset спрашивал она справа под иголку. Толи Car Launcher завис, то ли Навител, но нажатие на Reset только усыпляло магнитолу, и ничего не меняло, пока не дождался пока Sleep Mode в 30 минут не закончится. Может я неправильно жму эту кнопку?
Старый 26.09.2016, 11:04   #54
pinzet
Аватар для pinzet
@sergeysgs, в can настройках только out III, его и выставлял. При попытке сдвинуть баланс к тылу, звук пропадает. И нет отдельной регулировки саба. Прошивка крайняя стоит.
Добавлено через 1 час 22 минуты
видео
Завел на экран HA2034 управление ТВ тюнером .
Снял мультиметром распиновку раъема,
подключил к тюнеру.
и подобрал протокол управления в заводских настройках ГУ.
Старый 26.09.2016, 15:18   #55
sergeysgs
И на еще, перезагрузить магнитолу можно удерживая долго кнопку регулировки громкости при включенных габаритах (проверил–работает) .
TVтюнер от штатной антенны показывает или надо свою?
Старый 28.09.2016, 12:17   #56
pinzet
Аватар для pinzet
Модем huawei e3372h после мучительной прошивки в Hilink ( faq на 4pda) заработал в связке с ГУ.
Старый 29.09.2016, 23:28   #57
sergeysgs
очень интересно, я не смог huawei e3372 прошитый в hilink связать с магнитолой. Понял, надо дальше копать!
Старый 01.10.2016, 22:16   #58
Treo_650
sergeysgs
pinzet
Ребят, а к смартфону как к точке доступа ГУ не пробовали подключить? Мне кажется плясок с бубном будет на порядок меньше.
Treo_650 вне форума   Вверх Ответить с цитированием
Старый 02.10.2016, 12:49   #59
pinzet
Аватар для pinzet
@Treo_650, Точка доступа организуется без проблем. Но! У меня Yota, а она раздает за дополнительные деньги и модем с картой билайн в моем случае интересней. Плюс к этому в нашей деревне кроме билайна связи нет, так что без вариантов.
Старый 05.10.2016, 09:25   #60
pinzet
Аватар для pinzet
Моя включает подсветку кнопок, но не может притушить экран в ночное время. Ответа тоже не нашел.
@sergeysgs, а проводок ILL подключен? Хм, хотя в can-bus его наверно нет.
Текущее время: 20:42. Часовой пояс GMT +3.
