Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 04.09.2018, 17:38   #601
miba
Авто: Outlander III 2,4
По умолчанию Re: 2DIN головное устройство HA2034 на Android
Мужики, поставил Dasaita 8" вместо штатной, подключил к штатной камере заднего вида... Камера работает, а направляющие разметки пропали. Нужно самому делать рут, рисовать разметку, и закидывать в определённую папку?
Или есть способ попроще?
miba вне форума   Вверх Ответить с цитированием
Старый 05.09.2018, 09:50   #602
VISk
В меню настройки, помоему в разделе "безопасность" или "дополнительно" есть опция типа "показывать разметку", "зеркальный вид" и т.п. Так вот проверьте, что разметка включена.
VISk вне форума   Вверх Ответить с цитированием
Старый 06.09.2018, 08:07   #603
miba
Спасибо, помогло. Теперь проблема в том, что штатная камера не показывает картинку, как раньше. И направляющие не соответствуют действительности.
Может есть у кого готовый файлик разметки для штатной камеры заднего вида под андройд?
Старый 19.09.2018, 11:00   #604
VISk
Если и менять файлик, то уж лучше самому сделать именно под камеру. Это не сложно. Так как даже штатные камеры могут несильно, но отличаться по углу наклона и обзора. У меня есть файл, но камера не штатная - разметку сделал по следам от мокрых шин https://out-club.ru/board/imagehosti...978c5f74dc.png Методика описана на 24 стр.
Старый 26.10.2018, 08:58   #605
VISk
Блин, пробовал разные прошивки и теперь не работает эквалайзер. Т.е. программка запускается, движочки шевелятся, предустановки переключаются , но на звук ни как не влияет. Мож кто сталкивался, чаго можно сделать ?
Старый 26.10.2018, 09:33   #606
Potable
Аватар для Potable
Сообщение от VISk Посмотреть сообщение
Настройки сбились. КАН, наличие усилителя. В меню заводских... Это как вариант. Ну и шиться надо с вайпом, или как там он называется.
Старый 14.11.2018, 11:51   #607
VISk
Шился с вайпом, с полной очисткой. Кан и усилитель пробовал отключать, включать - безрезультатно. Да и эквалайзер у цифровых устройств чисто программная фишка, тут внешнее оборудование не играет роли. Родная прошивка была 1.93а, может у кого сохранилась стоковая dmcu для НА?
Старый 14.11.2018, 11:58   #608
VISk
Уже не знаю на что грешить. Можно ли как то посмотреть тип DMCU, ? Вдруг я прошил не той ревизией ? Смотрел раньше на картинке с QR кодом была версия HA а теперь вообще нет буквенных обозначений. Мож перепутал и вместо НА прошил для НН....
Как теперь узнать какой именно контроллер стоит ?
Старый 16.11.2018, 16:34   #609
Potable
Аватар для Potable
Вот прод мне ссыль кидал:
dear ,
thanks for your message .
please update the firmware first :
mcu: https://www.sendspace.com/pro/dl/v9tz9p
update:https://www.sendspace.com/pro/dl/l444pm
У меня на РХ5 v600
Старый 01.12.2018, 18:36   #610
Potable
Аватар для Potable
На автопргреве двигателя советую выключать ГУ. Зависла при автощапуске в мороз ночью, прогрелась, а ГУ продолжала по тихому сосать акб. Вовремя заметил, перегрузил и вырубил. Да и лишний потребитель ни к чему. Выключаем ГУ, выключаем
Старый 30.05.2019, 13:01   #611
VISk
Так я и не победил свою проблему с эквалайзером. Пришел к тому , что дело не в прошивке, щас стоит от Малайск. Перепробовал уже штук 8 прошивок для mcu. Возможно как то кан-адаптер влияет. Понять бы логику работы. Родной чейнжер Фосгейт переключает предустановленные режимы нормально. А эта HA только на Load реагирует - начинает бубнить, а эквалайзер хоть закрутись. Вроде фигня и юзать можно, но иногда очень не хватает...
Старый 01.09.2019, 11:48   #612
val078
Кан бус
val078 вне форума   Вверх Ответить с цитированием
Старый 02.09.2019, 06:09   #613
Potable
Аватар для Potable
@VISk, такая же картина. Убрал в заводских наличие КАНа, эквалайзер работает. Но не правильно это. Скорее всего сама ГУ корректирует выдаваемые частоты, без участия возможностей усилителя. И регулировка саба ни при каких условиях не фунциклирует. Смирился пока.
Старый 02.09.2019, 06:35   #614
Potable
Аватар для Potable
Сообщение от val078 Посмотреть сообщение
Кан бус
КАН БАС - это шина. КАН-адаптер - та "байда", которая позволяет (должна) общаться ГУ с усилителем ко КАН БАС. Не понятна суть вашего сообщения....
Старый 03.11.2019, 05:40   #615
tvik
Аватар для tvik
Авто: Стремительный домкрат
Подскажите как редактировать последовательность кнопки MODE на руле....
т.е. убрать отображение цифрового тв так как нет тюнера
tvik вне форума   Вверх Ответить с цитированием
Текущее время: 07:31. Часовой пояс GMT +3.
