Старый 27.05.2008, 21:46   #1
Takuto
Аватар для Takuto
Авто: ММС
По умолчанию Airtrek TURBO. Тюнинг АКПП.
Решил вывесить инфу с дружественного форума
http://forums.evolutionm.net/showthread.php?t=294314 вот вам и айр с 420 силами на борту на каждый день со СТОКОВОЙ акпп, изменено давление и прошивка..... кстати он мечтает о сталле 4000 оборотов
You have to drain ATF fluild and undo the black valve cover. Once you do that it will look like the picture. The adjusting knob is hard to miss.
The end clutches are similar to the F4. I got my end clutches redone with kevlar.
They werent worn at all and proberly didnt need to be changed.
Once the line pressure is increased, you should have much quicker shifts and that feeling of slippage in higher gears goes away.
That feeling is mostly to do with the damper clutch settings. The duty cycles were programmed for stock power/turbo, so when this changes the response feels different.
Mostly the damper clucthes were used to adjust comfort and speed of shift changes and transition from converter to lockup. Ive found that increasing the line pressure restores the feel and increases the activation speeds.
We will find out alot more about the ultimate power handling ability of the gearbox when we start hitting over 30 psi on the GT35R.
Considering that the actual power holding parts of the gearbox is near identical to the auto DSM guys- I think it will hold up fine. Considering the DSM guys are running 9s with only uprated valve bodies(for higher line pressure and gear changing speed) and 4K torque convertors I hope that we will be fine.
I will turn to Nitrous before increasing the stall- because the car is a road car which could go fast in a drag.
Перевод топика:
"Необходимо слить ATF и снять черную крышку блока клапанов (гидромозга). Как только вы это сделали, увидите то, что на картинке. Регулировочный винт сложно не заметить.
Задние фрикционы аналогичны таким же от F4. Я их переделал на кевларовые (судя по всему речь идет о пластинах). На самом деле они были практически неизношенные и менять их необходимости не было.
С увеличением линейного давления, переключения должны чувствительно ускориться и должно пропасть ощущение проскальзывания на высших передачах.
Это ощущение в основном связано с настройками муфты блокировки гидротрансформатора. Циклы открытия клапана, управляющего данной муфтой, были запрограммированы для стоковых мощности/наддува, так что при увеличении линейного давления ощущения меняются.
В основном муфта блокировки гидротрансформатора используется для регулировки комфорта и скорости переключений, а также момента перехода с проскальзывания ГТ на блокировку. Я обнаружил, что увеличение линейного давления восстанавливает ощущения и увеличивает скорость активации.
Мы узнаем еще больше о способностях АКПП по перевариванию мощности, когда начнем дуть больше 2х атмосфер на GT35R
Учитывая, что детали КПП, непосредственно ответственные за передачу мощности, практически идентичны тем, что используются у DSM, я думаю, она будет держать отлично. Принимая во внимание, что ДСМщики выезжают из десятки лишь со слегка доработанными гидромозгами (для увеличения линейного давления и скорости переключения) и гидротрансформаторами со столлом на 4000об/мин, я надеюсь, что у нас все получится.
До того, как играться со столлом, я планирую воткнуть Нитрос - поскольку машина в основном используется для каждодневной езды и только иногда для дрэга."
Takuto вне форума   Вверх Ответить с цитированием
Тюнинг Airtrek Turbo R в Красноярске strang_7060 Airtrek Turbo!!! 56 17.05.2009 23:34
Какое железо можно установить от стандартного Эво? vpall Airtrek Turbo!!! 11 10.01.2009 17:41
Текущее время: 08:19. Часовой пояс GMT +3.
