Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 24.01.2012, 00:56   #121
FLUTCH
Аватар для FLUTCH
Авто: Outlander XXL 2.4 MIVEC,Santa Fe 2.2D TM
По умолчанию Re: Уходит Антифриз.
Или может долить изабить
FLUTCH вне форума   Вверх Ответить с цитированием
Старый 24.01.2012, 13:25   #122
Gooody77
Аватар для Gooody77
тоже уходит антифриз, но как-то странно, раз в 2 недели заливаю ровно грамм 200, какие советы будут, искать место утечки или просто доливать и не париться?
Gooody77 вне форума   Вверх Ответить с цитированием
Старый 24.01.2012, 13:47   #123
mrDrager
Аватар для mrDrager
Сообщение от Gooody77 Посмотреть сообщение
это много
я бы искал утечку 100%
mrDrager вне форума   Вверх Ответить с цитированием
Старый 24.01.2012, 21:15   #124
FLUTCH
Аватар для FLUTCH
Да,тут что-то не то....ищи проблему,так быть не должно полюбому...
---------- Добавлено в 20:15 ---------- Предыдущее сообщение было написано в 20:15 ----------
Долил воды буду наблюдать...
Старый 24.01.2012, 21:20   #125
Евгений Хмеленко
Аватар для Евгений Хмеленко
Авто: ASX 1.8 2WD CVT
У меня тоже уходит... Доливаю... А сколько „много” и сколько мало? За 14000 пробега долил грамм 200. Хотя опять же. 200 грамм залили до поездки на 2000 км. После поездки уровень опять ушел.
Евгений Хмеленко вне форума   Вверх Ответить с цитированием
Старый 27.01.2012, 10:45   #126
***ШТИРЛИЦ***
Аватар для ***ШТИРЛИЦ***
Послелний раз менял антифриз на ТО-30 т.км. С тех пор, а это 25 т.км, уровень лишь упал ниже отметки мин. на полтора сантиметра, т.е. практически на дне!
Старый 09.04.2012, 19:46   #127
Mmotosan
Авто: XL 3.0
уходит антифриз
очень нужен код "прокладки антифризной заглушки сзади блок" и самой заглушки 3.0 авт 2008
vin Jmbxlcw6w8z000671
спасибо!
Mmotosan вне форума   Вверх Ответить с цитированием
Старый 16.04.2012, 16:23   #128
Dead_Fox
Аватар для Dead_Fox
Авто: XL V6
По умолчанию Re: Замена антифриза
Автомобиль Mitsubishi outlander xl v6 3.0 2008 г.в.
вот сливная пробка из радиатора, находится справа внизу
и сливная пробка из блока справа от масляного фильтра
Dead_Fox вне форума   Вверх Ответить с цитированием
Старый 16.04.2012, 16:39   #129
Dmetriy74
Аватар для Dmetriy74
Авто: Outlander XL 3.0 MIVEC S64
Сообщение от polimet Посмотреть сообщение
Вчера самостоятельно менял антифриз на Ауте ХL 3.0. Делал следующее. Снял защиту и пластиковый низ бампера. Справа внизу на радиаторе краник. Выкрутил наполовину, антифриз сливается тонкой струйкой через опору радиатора строго вниз (грамотно сделано). Вылилось примерно 4 литра (всего в системе 9,5 л). Далее находим пробку на блоке. С фонариком. Становимся снизу перед масляным фильтром. Пробка слива (болт на 14) на 20 см левее масляного фильтра (чтобы было удобнее я снял масляный фильтр). Ключ надо длиной см 25, чтобы сдернуть болт с места, далее лучше скручивать рукой.
Ну так сколько т.о. ОЖ добыли?
Dmetriy74 вне форума   Вверх Ответить с цитированием
Старый 16.04.2012, 18:50   #130
Mi-XL
Подскажите есть ли на 2,4 литровом, пробка слива на блоке?
Mi-XL вне форума   Вверх Ответить с цитированием
Старый 07.05.2012, 11:45   #131
Artursan
Из книжки по ремонтуРуководство по ремонту XL - говорят что сливать нужно на холодном двигателе и причем только через краник радиатора. Народ выше пишет что на горячем и еще сливаем через пробку на блоке двигателя...
Кто прав , кто не прав ? вот собственно в чем вопрос.
---------- Добавлено в 09:17 ---------- Предыдущее сообщение было написано Вчера в 10:45 ----------
Вопрос однако не такой уж и простой - мои мысли такие:
чтобы слилось больше через радиатор нужно прогреть двигатель до открытия термостата, тогда часть антифриза из блока сольется тоже.
можно открутить пробку на блоке и сливать через нее и радиатор - тогда можно на холодную .
Но вот вопрос - если мы слили жидкость из блока - термостат закроется при остывании и тогда как налить антифриз в блок ? заливаем то через радиатор а он пока термостат не сработал - отключен от блока двигателя - т.е. в блок антифриз не зальется получается ?
Ахтунг какой то ...
Artursan вне форума   Вверх Ответить с цитированием
Старый 08.05.2012, 15:41   #132
Timka
Аватар для Timka
Авто: Финик QX50
А термостат в верхней трубке или в нижней?
Старый 09.05.2012, 15:23   #133
Artursan
скорее всего в нижней ибо нижняя становится горячей только после сильного прогрева
---------- Добавлено в 14:26 ---------- Предыдущее сообщение было написано в 14:23 ----------
вообщем докладываю -
из радиатора на холодную слилось около 3 литров - я подумал маловато будет и открутил сливной болт на блоке - там еще около 3 литров.
Залилось 6л .
Старый 24.05.2012, 12:17   #134
_GeoloG_
Out XL 2.4. Машине 4 года, пробег 67.000.
Рано менять?
_GeoloG_ вне форума   Вверх Ответить с цитированием
Старый 25.05.2012, 09:20   #135
Dead_Fox
Аватар для Dead_Fox
Авто: XL V6
Сообщение от _GeoloG_ Посмотреть сообщение
Рано менять?
с "Нашими" условиями эксплуатации чем чаще тем лучше! 1 раз в 2 года )))
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 16:01. Часовой пояс GMT +3.
