Старый 16.05.2024, 06:53   #1
mix66
По умолчанию Помощь знатоков
Всем добра.Загорелась гирлянда.Неисправность тормозной системы,чек тоже горит.Что за хрень?С чего начать?
mix66 вне форума   Вверх Ответить с цитированием
Старый 16.05.2024, 08:00   #2
По умолчанию Re: Помощь знатоков
@mix66, Начинать надо с диагностики.
Старый 16.05.2024, 09:11   #3
mix66
Как то так
Старый 16.05.2024, 09:35   #4
@mix66, Проверяйте датчики ABS и заодно разъём на блоке ABS.
Старый 16.05.2024, 13:45   #5
DMS_OUT
Авто: 4B10&4B11
!не отображает вставленные ссылки!
С2200
OPERATION
ASC-ECU controls ASC by calculating the data sent from the wheel speed sensor, the steering wheel sensor, and the G and yaw rate sensor.
DIAGNOSIS CODE SET CONDITIONS
This diagnosis code is stored when ASC-ECU has malfunction.
PROBABLE CAUSES
ASC-ECU malfunction
С1200
OPERATION
ASC-ECU contains the power supply circuit (+BV terminal) for the solenoid valve. The solenoid valve is energised by the valve relay, which is incorporated in ASC-ECU.
The valve relay, which is incorporated in ASC-ECU, is always energising the solenoid valve unless the initial check is in progress when the ignition switch is turned on, and the recurrent system check is in progress.
ASC-ECU activates the solenoid valve by turning on its driving transistor.
DIAGNOSIS CODE SET CONDITIONSThese diagnosis codes will be stored under the cases below:
The solenoid valve is not energised even after ASC-ECU has turned on the driving transistor (Open circuit is present in the power supply circuit to the ASC-ECU solenoid valve, or the valve relay has failed).
After ASC-ECU has turned off the driving transistor, the solenoid valve still remains energised (short in the solenoid valve circuit).
When a solenoid valve failure is detected
PROBABLE CAUSES
ASC-ECU malfunction
Старый 16.05.2024, 13:54   #6
DMS_OUT
Авто: 4B10&4B11
по 1200 далее проверка есть, ищите в руководстве...
Текущее время: 18:41. Часовой пояс GMT +3.
