Вернуться   OUT-CLUB.RU > Технический раздел > English pages
Старый 02.05.2010, 22:18   #1
Oskar
По умолчанию cnopm modyc
Privet, i'm writing in english. I found in our forum in Germany pictures, where was shown the "Sport Modus" DS, for Automatic-2.4 Outlander XL and an ALARM-Modus.
What du you knwo about this options???
You can see the photos here
greetings from Germany
Oskar
Oskar вне форума   Вверх Ответить с цитированием
Старый 02.05.2010, 22:29   #2
По умолчанию Re: cnopm modyc
Hello, Oskar.
We know all about "Sport-mode" and alarm option.
You can attempt to translate via google these threads: https://www.out-club.ru/board/showthread.php?t=17428 (Sport mode)
and https://www.out-club.ru/board/showthread.php?t=20071 (alarm)
In two words: for activate sport mode you need an extra switch and the wire to CVT ECU. For activate alarm mode you need to program the option/variant coding list via MUT-III (MMC service computer)
Старый 03.05.2010, 00:41   #3
Oskar
Hello Sergy, cnacubo for you fast answer, i'm trying to translate all informations in the links....
Oskar
Старый 03.05.2010, 22:24   #4
Bitte schon, Oskar.
Please feel free when you asking us about something.
PS: why you bought Outlander instaed Tiguan? In Russia they prices are comparable but warranty 2 year (VW) vs 3 year (MMC).
PPS: I moved this thread with redirect to our "English pages"
Старый 11.08.2010, 20:25   #5
royber
Авто: Ultimate, Black & Chrom
Hello!
I have an Outlander XL importet from Russia.
I`ve translated the pages over the Ds Mode with Google. I`ve found all the parts in my car too.
I´ve some questions:
- Suports my 8631A076 CVT-ECU the Ds mode?
- Is it possible to use the ASC-switch 8610A003 to activate Ds mode?
- Is it possible to get such Connectors to create a removable system?
- Knows somebody the designation or the manufakturer of this conector?
Sorry, but the Google translation is sometimes verry bad.
Thank you for your support, it´s a great forum.
royber вне форума   Вверх Ответить с цитированием
Старый 11.08.2010, 21:19   #6
Hello, royber.
I will ask our smart guys about your qusetions and answer fast as possible.
Старый 12.08.2010, 02:51   #7
royber
Thank you for your fast support.
Do you know something about the Aircondition problem. If you set the AC to automatic after 20 minutes the teperatur will be different at your head and your feed. The problem is to less air at the roomsensor.
-No awnser from Mitsubishi, and this problem is the same at other modells too.
We have solve the problem with the temp.-sensor. We use smal computer fans to bring air to the sensor. So the AC will work fine.
Старый 12.08.2010, 12:10   #8
Hello royber.
Our guys answered about Ds:
1) YES, this CVT-ECU supports Ds mode
2) If you won't use ASC OFF switch in future, you can use it for Ds. But you should make an additional circuit because this knob don't have a fixed "ON" mode
circuit #1 - use relays:
(used 2 diodes type 1N4007, 1N4001 etc)
another circuit #2:
3-4) of course, you can use any hidden connectors. One of our smart guys modified 2WD/4WD/Lock switch:
https://www.out-club.ru/board/showthread.php?p=764659#post764659 and Ds mode is activate by pressing it down.
Also you can use standard knob like ASC OFF but with two fixed ON-ON position (switch) - no any circuits needed.
PS: please give us a links where you had modified cabin temperature sensor. I can't say that AC works bad, but we like to DIY. Did you hear about the HEAT that now in Russia about 2 months? Outlander's AC works fine in these very severe conditions.
Последний раз редактировалось Sergy; 12.08.2010 в 14:23.
Старый 16.08.2010, 00:00   #9
royber
Thanks a lot for your support!
Here is a link :http://www.outlander-forum.com/sogehts/lueftung-1.php
At the moment we know the problem and how to solve it, but the perfect repair tip is missing. At the moment we try to create a silent and easy to build set.
Please look at the other self-made stuff,too
Has the "8616A001 Switch, corner Sensor" a fixed ON-ON position?
At my CVT-ECU are no wires in the midle of the conector, so I need the Manufacturer and the name of this conector to order the pins.
Normaly Mitsubishi uses TYCO conectors, but I can`t find the right type. My dream is a removable system!
royber
Текущее время: 04:51. Часовой пояс GMT +3.
