Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 10.08.2012, 13:14   #151
pilot31
По умолчанию Re: Замена антифриза
Сообщение от su8 Посмотреть сообщение
Подскажите правильный код Dia queen super long life (концентрат) для смены на 2.4 л из нижних, а то путаница с последними двумя (один long life, другой super)
MZ381032
Mitsubishi DiaQueen Super Longlife Coolant (2 литра) — антифриз для автомобилей Мицубиши
MZ381033
Mitsubishi DiaQueen Super Longlife Coolant (4 литра) — антифриз для автомобилей Мицубиши
0103045
Mitsubishi Longlife Coolant (4 литра) — антифриз для автомобилей Мицубиши
MZ311986
Mitsubishi Longlife Coolant (4 литра) — антифриз готовый для автомобилей Мицубиши зеленого цвета
MZ311986
Mitsubishi DiaQueen Super Longlife Coolant (3,8 литра) — Концентрат антифриза для автомобилей Мицубиши
Для нас идеальный вариант DiaQueen Super Longlife Coolant MZ381032 и MZ381033 Made in Japan (именно такой с завода залит и рекомендован руководством по эксплуатации), но если заказывать через инет то идти будет недели 3-4 если не больше.
pilot31 вне форума   Вверх Ответить с цитированием
Старый 10.08.2012, 21:02   #152
tyler durden
Аватар для tyler durden
Авто: AUDI A6
Бери этот MZ311986 в экзисте есть, ну или зеленый mobil,вот только вопрос это концентрат или нет.А то канистрочка полторашку стоит((
tyler durden вне форума   Вверх Ответить с цитированием
Старый 13.09.2012, 14:08   #153
alecx
Авто: Outlander XL 2.4 MT
Я нечего так и не понел как правельно поменять ОЖ на XL 2.4 В инструкции написано на холодную и сливать через радиатор, но как сказано выше сольется не больше половина с бочком, поэтому тоже вопрос как правельно решить?
alecx вне форума   Вверх Ответить с цитированием
Старый 11.11.2012, 16:20   #154
Sergej150
какого цвета MZ381032
Mitsubishi DiaQueen Super Longlife Coolant (2 литра) — антифриз для автомобилей Мицубиши?
у меня пробег 50 т. жидкость в бочке синяя. Нужно долить...
Sergej150 вне форума   Вверх Ответить с цитированием
Старый 11.11.2012, 16:37   #155
divers143364
Аватар для divers143364
Сообщение от Sergej150 Посмотреть сообщение
официалы при смене и доливке используют МОБИЛ ЭКСТРА концентрат СИНИЙ . смело доливай его, хорошее качество и продается везде ,
при доливке не поленись и проверь уровень антифриза в радиаторе а не только в расширительном бачке (на холодную)
Старый 11.11.2012, 17:13   #156
Sergej150
Антифриз я еще не менял, значит у меня залит родной заводской? Так вот и хочется понять, что залито? У кого зеленый с завода, у кого синий, непонятно.
Mitsubishi DiaQueen Super Longlife Coolant все же какого цвета?
В руководстве по эксплуатации рекомендован именно он...
Старый 11.11.2012, 18:22   #157
Dmetriy74
Аватар для Dmetriy74
Авто: Outlander XL 3.0 MIVEC S64
зелёного
Dmetriy74 вне форума   Вверх Ответить с цитированием
Старый 11.11.2012, 18:37   #158
Sergej150
Так все же интересно почему с завода у кого синий у кого зеленый антифриз залит?
у меня синий, значит мобил мне в японии налили? Совневаюсь... машина японской сборки.
Те которые собраны в калуге может и ездят на синем мобиле...
У кого как?
Старый 11.11.2012, 19:48   #159
amel
Аватар для amel
У меня зеленый, ни разу не видел, чтобы синий был залит с завода. А кого, кроме вас, синий?
Старый 11.11.2012, 20:18   #160
Dmetriy74
У кого как?
Первый раз про синий вообще слышу. В радиатор заглядывали? А что в процессе эксплуатации доливали?
Старый 11.11.2012, 20:46   #161
Sergej150
в радиатор не смотрел. в бочке видно что синий. Доливали официалы, сам никогда.
---------- Добавлено в 20:52 ---------- Предыдущее сообщение было написано в 20:46 ----------
вот про синий
https://out-club.ru/board/showthread.php?t=11917&page=6
Старый 11.11.2012, 21:43   #162
Dmetriy74
вот про синий
Ну тогда Вам у ОД нужно выяснить, что там залито. Митсу рекомендует лонг лайф куин, а он зеленый. Синего цвета вообще-то тосол. Звоните ОД, в общем. Гляньте все же в радиатор, может бачок так цвет искажает.
Старый 11.11.2012, 23:45   #163
IgSo
Аватар для IgSo
Авто: DODGE RAM 1500
Сообщение от divers143364 Посмотреть сообщение
И не забывайте разбавлять
Старый 12.11.2012, 03:49   #164
divers143364
здесь на форуме писали что родной 30 градусный и если залить литр концентрата то будет только лучше .
Старый 12.11.2012, 21:25   #165
IgSo
Аватар для IgSo
Кто это проверял? Переконцентрация так же снижает темп.замерзания, как и обводнение Поэтому в качестве долива (не при уходе от технической неисправности, а именно естественная усушка) рекомендуется использовать только дисц. воду.
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 03:09. Часовой пояс GMT +3.
