Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 25.11.2012, 11:41   #181
***ШТИРЛИЦ***
Аватар для ***ШТИРЛИЦ***
По умолчанию Re: Замена антифриза
SpyFox, ну я аналогично буду менять, также в три этапа.
П.С. Вчера заехал к официалам полюбопытсвовать, что они мне залили на ТО-30. Сказали Mobil Extra, а это по сути обычный силикатосодержащий G11.
А сейчас вообще льют какой то японский антифриз Extra из бочек (обычный сине-зеленый G11).
П.С.С. А если уж речь зашла об антифризах, которые подпадают под наши допуски (без фосфатов/нитритов/силикатов), то это все антифризы с обозначением G12+
---------- Добавлено в 11:49 ---------- Предыдущее сообщение было написано в 11:41 ----------
Наткнулся на форум химиков http://www.chemport.ru/forum/viewtopic.php?f=29&t=83937 , там можно кое что интересное подчерпнуть про антифризы.
Старый 27.11.2012, 23:35   #182
Tired
Поменял антифриз, что был с завода залит, на MOTUL Inugel Optima,систему промывал дистилатом до чистой воды. Заливаю Motul (морковный цвет), а он становится через минут 5 салатового цвета....=( Есть идеи??? Буду признателен за помощь!
Tired вне форума   Вверх Ответить с цитированием
Старый 27.11.2012, 23:49   #183
pilot31
Сообщение от Tired Посмотреть сообщение
Значит не все слилось (в малом круге контура осталось, несмотря на то, что в большом все промыто) и произошло смешение о чем я и говорил несколькими постами ранее, по мне лучше всего эту процедуру проводить на аппарате тогда есть гарантия все слить, сам так буду делать, когда привезут родной антифриз.
pilot31 вне форума   Вверх Ответить с цитированием
Старый 28.11.2012, 00:13   #184
Tired
Сообщение от pilot31 Посмотреть сообщение
Возможно, хотя объем слитого антифриза был около 9,5 литров...Да и дистилатом потом промывал несколько раз и гонял систему с дистилатом...
Старый 28.11.2012, 00:36   #185
***ШТИРЛИЦ***
'Паленый' не мог попасться?
Старый 28.11.2012, 02:08   #186
Tired
не думаю, так как это 2 заход по смене=))и каждый раз одно и тоже...антифриз брал у официального представителя...
Старый 02.12.2012, 17:36   #187
***ШТИРЛИЦ***
В общем не стал ломать голову, залил то, что было залито официалами на ТО - Mobil Extra (только тогда он был зеленый, сейчас синий, но смешивается абсолютно нормально, проверил в домашних условиях)))
Менял в два этапа, заливая по три литра. Сливал только из радиатора.
Старый 03.12.2012, 14:08   #188
Tired
Ну и у меня тоже победа, Motul все такой же как морковка=)) В общем надо было сразу промывать долго и нудно...
Старый 03.12.2012, 15:21   #189
***ШТИРЛИЦ***
Кстати, когда брал Мобил, рядом стоял Кастрол. У него был 'наш допуск'!
Старый 23.12.2012, 12:01   #190
Out44
Аватар для Out44
А к какой спецификации относится наш антифриз DIA QUEEN SUPER LONG LIFE COOLANT: силикатосодержащий, карбоксилатный? G11? G12 или G12+, ++ и т.д.?
Out44 вне форума   Вверх Ответить с цитированием
Старый 23.12.2012, 16:26   #191
pilot31
Сообщение от Out44 Посмотреть сообщение
Аналог G12+ (у японцев не делают антифриз по спецификации WV, у них свой стандарт к антифризам jis k2234) на основе моноэтиленгликоля, зеленого цвета: http://s017.radikal.ru/i430/1212/e0/0ae91f5c9d23.jpg
Старый 23.12.2012, 17:49   #192
Out44
Аватар для Out44
А это готовый или концентрат? Хочу заменить, так сколько заказывать литров этой жижи?
Старый 23.12.2012, 18:00   #193
pilot31
Это концентрат. Для полной замены 4л концентрата. Смешивать с дистиллированной водой в соотношении 50/50.
Старый 24.12.2012, 00:09   #194
TaxAdviser
рекомендуется менять антифризв такой последовательности:
1) слить старый
2) залить воду для промывки и после промывки слить по возможности максимум воды
3) залить 4 литра антифриза (не разбавляя его водой),
4) долить воды до полного заполнения системы.
Смысл: после промывки в системе остается вода, если вы заливаете готовый 50\50, то в итоге получите смесь с большим содержанием воды чем нужно. Если же в систему, в которой осталась вода, вы добавляете точно 4 литра концентрата и потом дольете воды, то получите на 8 литрах ровно 50%\50%...
Старый 24.12.2012, 10:24   #195
***ШТИРЛИЦ***
Только если менять так как указано в мануале, сливая только из радиатора, то 4 литра концентрата туда не вольешь, а максимум три, плюс еще надо как то это дело разбивать! Уж лучше разбавленный три раза слить/залить...
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 09:29. Часовой пояс GMT +3.
