Старый 08.06.2007, 08:59   #1
YesYes
Аватар для YesYes
Авто: XL 3.0 S11 black
Из сервис мануала:
14 -ENGINE COOLING > ON-VEHICLE SERVICE > ENGINE COOLANT CHANGE<4B1, 6B3>
Простенько и со вкусом: наддуть систему охлаждения через пробку на радиаторе и слить по максимуму.
ENGINE COOLANT REPLACEMENT <4B1, 6B3>
1. warning
When removing the radiator cap, use care to avoid contact with hot coolant or steam. Place a shop towel over the cap and turn the cap anti-clockwise a little to let the pressure escape through the vinyl tube. After relieving the steam pressure, remove the cap by slowly turning it anti-clockwise.
Drain the water from the radiator, heater core and engine after unplugging the radiator drain plug and removing the radiator cap.
2.Disconnect the cooling water line hose and drain the coolant in the water jacket <4B1>.
3.Disconnect the water feed hose B and drain the coolant in the water jacket. <6B3>
4.Remove the radiator condenser tank and drain the coolant.
5.Drain the coolant then clean the path of the coolant by injecting water into the radiator from the radiator cap area.
6.Connect the cooling water line hose. <4B1>
7.Connect the water feed hose B. <6B3>
8.Securely tighten the radiator drain plug.
9.Reinstall the radiator condenser tank.
10. caution
Do not use alcohol or methanol anti-freeze or any engine coolants mixed with alcohol or methanol anti-freeze. The use of an improper anti-freeze can cause corrosion of the aluminium components.
By referring to the section on coolant, select an appropriate concentration for safe operating temperature within the range of 30 to 60%. Use special tool LLC changer (MB991871) to refill the engine coolant up to the top of the radiator port. A convenient mixture is a 50% water and 50% antifreeze solution (freezing point: -31°C).
  • Recommended antifreeze: DIA QUEEN SUPER LONG LIFE COOLANT or equivalent
    Quantity:
    • 7.5 L <4B1>
      9.5 L <6B3>
    (including 0.65 L in the radiator condenser tank)
note
For how to use special tool (MB991871), refer to its manufacturer’s instructions.
11.Tighten the radiator cap securely.
12.Remove the radiator condenser tank cap, and add the engine coolant up to the "FULL" line.
13.Turn the A/C switch to OFF position to start the engine and warm up until the cooling fan operates.
note
This work is to open the thermostat fully.
14.Rev the engine several times and then stop it. Check that there are no coolant leaks.
15.Remove the radiator cap with the engine cool, and then refill the engine coolant up to the top of the radiator port.
16.Tighten the radiator cap securely.
17. caution
Do not overfill the radiator condenser tank.
Из умной книжки по ремонту (Руководство по ремонту XL ):
страница 119 и 120.
Стоит заглянуть в темы:
Вопрос про долив охлаждающей жидкости
Дело о перегреве и пробочке
Уходит Антифриз.
Охлаждающая жидкость — руководство по эксплуатации Outlander XL >>>
Что идет с завода Японии >>>
Что льют ОД >>>
О самостоятельной замене:
Отзыв от polimet >>>
Сливная пробка живое фото >>>
AC506619AG.jpg   AC606072AB.jpg   AC606073AD.jpg   Рисунок (119).jpg   Рисунок (120).jpg
Последний раз редактировалось Sergy; 14.07.2013 в 23:15.
Старый 14.04.2014, 12:05   #316
Klasik
Аватар для Klasik
Авто: XL 3.0 S01
По умолчанию Re: XL - Все вопросы про Антифриз (охлаждающую жидкость)
Сообщение от greenrocket Посмотреть сообщение
В Exist.ru сейчас есть 1793.11 за 4 литра
Звонил в офис продаж, спрашивал, могут ли привезти, ответ - нет.
Klasik вне форума   Вверх Ответить с цитированием
Старый 03.05.2014, 11:48   #317
Wayfarer
Итак почитав еще раз тему и проштудировав оил клаб пришел к выводу что рекомендуемый многими Mobil Antifreeze Extra не желателен в наших двигателях из мобилов подходит лишь-Advanced. Тот же антифриз что я думаю залить похож на рекомендуемый нам Glysantin G30 а именно удовлетворяет нормам VW-TL 774 D,VW-TL 774 D/F. Теперь для меня отпали сомнения в поводу его заливки, только предварительно промою систему хорошенько водичкой и произведу замену 2 раза чтобы снизить возможное понижение плотности из-за оставшейся в системе воды. Для чего это уже говорил-он у меня дармовый и уже 16литров))
Wayfarer вне форума   Вверх Ответить с цитированием
Старый 06.05.2014, 13:43   #318
Ilyasuper@
При смене антифриза, залил себе Антифриз-концентрат "HJC Hybrid Japanese Coolant Concentrate" (http://www.ravenol.su/Product-Raveno...utz-konzentrat).
Три месяца полета - всё в идеале.
Ilyasuper@ вне форума   Вверх Ответить с цитированием
Старый 12.05.2014, 15:55   #319
Ivanskimvd
Самостоятельно менял антифриз. Приобрел Sakura зеленый. Слил только 3-3,5 л из радиатора. Залил столько же. В следующий раз, для качественной и полной замены лучше заеду на СТО с оборудованием для замены антифриза.
Ivanskimvd вне форума   Вверх Ответить с цитированием
Старый 23.05.2014, 19:17   #320
-Insider-
Аватар для -Insider-
Что то с антифризом беда, инет магазы не хотят везти, в обычных нет, а од впаривают синий супер лонг лайф MZ320130. Где взять зеленый родной?
-Insider- вне форума   Вверх Ответить с цитированием
Старый 23.05.2014, 21:31   #321
megaaxel
Аватар для megaaxel
синий или зеленый - какая разница?
Старый 26.05.2014, 09:57   #322
Колян89
http://avtomag2000.ru/files/pdf/Ispi...tosol_gost.pdf
информация про антифризы, опасные для использования
Колян89 вне форума   Вверх Ответить с цитированием
Старый 26.05.2014, 10:11   #323
135mt
Аватар для 135mt
Кто такой тосол покупает вообще?
135mt вне форума   Вверх Ответить с цитированием
Старый 29.05.2014, 10:01   #324
Klasik
Аватар для Klasik
Авто: XL 3.0 S01
Никто не знает антифриз MZ320130 http://www.motor-oils.ru/?show=item&id=3481 это аналог MZ381033, учитывая, что первый готовый, второй - концентрат и в названии первого отсутствует DiaQueen?
Старый 03.06.2014, 15:31   #325
Dimon_R
Подскажите пожалуйста, MZ 311986 - это концентрат или готовый к применению, не смог найти ответа. заранее спасибо.
Dimon_R вне форума   Вверх Ответить с цитированием
Старый 03.06.2014, 16:04   #326
-Insider-
Сообщение от Klasik Посмотреть сообщение
Ничего не разузнал про взаимозаменяемость?
Старый 04.06.2014, 10:00   #327
Klasik
Аватар для Klasik
Авто: XL 3.0 S01
Сообщение от -Insider- Посмотреть сообщение
Предполагаю, что один концентрат, другой готовый, вот и вся разница.
Старый 04.06.2014, 10:26   #328
-Insider-
Klasik, Тогда почему цвет у них разный?
Старый 04.06.2014, 10:35   #329
megaaxel
Аватар для megaaxel
чтобы отличать концентрат от разбавленного, к примеру.
сам по себе цвет состав не означает, это краситель.
Старый 02.07.2014, 14:32   #330
AlexeUSS
Сегодня с утра обнаружил антифриз на нижнем уровне, пробег 31500
Позвонил ОД, сказали льют готовый зеленого цвета Mitsubishi MZ320291.
AlexeUSS вне форума   Вверх Ответить с цитированием
антифриз, долив, жидкость, зеленая, красная, охлаждайка, охлаждающая, перегрев, пробка, синяя
А какой антифриз официалы льют в Ауты + Bahus Outlander - Эксплуатация и ремонт 36 18.02.2019 15:20
Антифриз менять не торопимся ! Jeka71 Outlander - Эксплуатация и ремонт 2 05.11.2007 18:13
Текущее время: 19:19. Часовой пояс GMT +3.
