Старый 28.06.2016, 11:38   #1
chindiasov
Аватар для chindiasov
FAQ по теме!
Характеристики:
CPU Processor: RK3188 / Memory: 16GB / RAM Space: SAMSUNG DDR3, 1GB / Screen resolution: 1024*600
Полные Характеристики
— CPU Processor: RK3188 1.6GHz Cortex A9 Quad-Core
— RAM Space: SAMSUNG DDR3, 1GB
— Memory: 16GB
— Sound Chip: TDA 7851L
— Radio Chip: ST 7786
— Built-in 86 Kinds of Car Opening Logos Optional
— You can also choose your own image from your USB. (Password: 126)
— Dynamic Background Pictures Selectable. Customers can also set their favorite pictures as background.
— LED Button Colors for you to select (Red, Green, Blue, Pink, Apple Green, Sky Blue, Yellow, White, Color).
Further more, you can DIY any color to match your mode of the day.
— Steering Wheel Control Function
— Menu Languages: English/Spanish/French/German/Portuguese/Italian/Russian/Turkish/Norwegian/Japanese etc
— Built-In Amplifier FR/FL/RR/RL 4-Channel Audio Output , 1-Subwoofer Output
— 4x50W Surround Stereo
— Sound Equalizer: FLAT VOICE CUSTOM ROCK POP JAZZ CLASSIC
— Auto-Memory Function
— Power Supply: DC 12V
— Max Working Current: 15A
Screen:
— Screen : High Definition Digital Capacitive Screen
— Resolution: 1024*600
— Full Touch Screen Function
— Image Brightness Adjustable
Bluetooth:
— Connect Code: 0000 Name:car-kit
— Built-In Microphone in the control panel, and with external microphone ready.
— Support Bluetooth MP3 player function (Attention: This function can only be realized when the mobile phone supports Bluetooth Audio Output).
— Support Bluetooth Phone Book Function. You can quickly search for contacts manually, and it supports displaying caller name.
— Support Bluetooth version 2.0 or above phone connection, such as Apple,Samsung, HTC, Sony, etc.
USB
— Built-In USB Port
— USB Port: Can support soft drive such as USB flash drive, or MP3 player with maximum32G compatibility, Can’t support portable hard drive.
— Compatible Formats:
— Video Formats: Support MPEG-1/2/4,H264,RMVB,DivX…all Android videos, network mediaplaying, 1080P video decoding.
— Audio Formats: Support MP3,WMA,WAV,AC3,OGG,FLAC etc,and network audio playing.
— Picture Formats: Support JPEG, BMP, PNG,TIFF etc.
Radio:
— Built-In Radio Tuner (30 Preset Stations)
— FM(3*6)87.5-108MHz(Europe), Increment 0.05MHz
— AM(2*6)522-1620KHz, Increment: 9 KHz
— Built-In RDS Radio Receiver Function
— Radio Regions: China,Europe,Orit,Russia,America1,America2,Japan,Aust
Много полезной информации можно найти на форуме 4ПДА — Головные устройства Microntek MTCD (RockChip RK3188) Android 5.1.1
Покупка магнитолы: Aliexpress. Продавец/производитель - Car Android DVD Factory, MTKNAVI Store
Сейчас пытаюсь для клубней выбить скидку на покупку магнитолы, если есть кто то готов купить себе, то отпишите в ЛС.
Последний раз редактировалось chindiasov; 28.11.2016 в 21:00.
Старый 07.10.2017, 13:39   #436
zhaleksey
Авто: Outlander III 2.0 CVT chip by Ёжик Пых
По умолчанию Re: 2DIN головное устройство HA2034 на Android
если выключить и включить зажигание в течении 1-2 минут, то все работает, если выключаешь зажигание на 3 и более минут, то после включения зажигания - не включается, полноценное включение только после сброса фишки и подсоединения ее заново, что не есть хорошо.
питание приходит как на магнитолу, так и на can
пробовал включать без карты sd, не помогает
менял can не помогает
в чем может быть еще проблема? (возможно ли такое из за прошивки или неправильных системных настроек особенно по can?
zhaleksey вне форума   Вверх Ответить с цитированием
Старый 07.10.2017, 18:09   #437
Potable
Аватар для Potable
@zhaleksey, желтый с красным меняли? Что изменилось? Из-за кастомной п прошивки тож может.
Старый 09.10.2017, 10:09   #438
egor_sh
Аватар для egor_sh
Авто: Outlander XL 2.2 Diesel
Сообщение от ДмитрийГлаз Посмотреть сообщение
Поставил себе НА2034-v600. Немного помаялся с подключением камеры з.х. Не знал куда красный провод к магнитоле подцепить, но разобрался.
Не подскажете, куда подключили в итоге?
Третий день сражаюсь с подключением камеры заднего вида.
У меня вариант без card bus шины. Среди проводов в разъеме нет ни одного, который был бы отмечен как reverse/parking.
Пробовал подключаться к коричневому, который помечен как BRAKE - не то.
Минус камеры кинул на массу, плюс питания и красный провод на тюльпане к светлому проводу фонаря заднего хода.
Сигнальный кабель протянул вдоль потолка к головному устройству.
На самом ГУ подключал к тюльпану CAM-VIN.
Пробовал руками включать av-in и заднюю - упорно показывает только warning на экране.
Проводку прозванивал - проблем нет.
Саму камеру подключал к tv - работает.
Камера NTSC. брал у того же продавца на ali, что и магнитолу.
egor_sh вне форума   Вверх Ответить с цитированием
Старый 09.10.2017, 10:46   #439
ДмитрийГлаз
Аватар для ДмитрийГлаз
Сообщение от egor_sh Посмотреть сообщение
Щас уже и не вспомню, скинь фото магнитолы ,где распиновка показана(таблица на верхней крышке магнитолы) и по ней попробую вспомнить.К какому то проводу я его на изоленте прикрутил и все работает.
Старый 09.10.2017, 11:59   #440
egor_sh
Аватар для egor_sh
Меня бы это очень выручило.
14-й коричневый провод отмечен на схеме как parking. Но по факту на нем наклейка Brake.
Есть ещё некий "back". может он?
Вторая картинка откровенно смущает. Нашел здесь на форуме.
Старый 09.10.2017, 12:50   #441
ДмитрийГлаз
именно на него я и кидал(back) пин 2(под 1 саn_rx) .На первой картинке Power Supply port.Я его чуть подзачистил и прикрутил красный.
Последний раз редактировалось ДмитрийГлаз; 09.10.2017 в 13:01.
Старый 09.10.2017, 19:41   #442
egor_sh
Аватар для egor_sh
Большое спасибо за помощь.
Попробовал сейчас подпаяться к нему. У меня он подписан как BALK (видимо, вместо BACK)
Увы, эффекта не дало.
Но. от отчаяния попробовал подключить саму камеру к разъему AUX Video IN вместо CAMERA VIN.
После этого картинка с камеры появилась если включить заднюю и вручную зайти в приложение AV-IN.
Вот теперь не пойму не вместо фронтальной ли я камеры её подключил.
При этом в инженерном меню фронтальная камера отключена.
И как все же заставить её включаться автоматически.
Сам сигнальный кабель прозвонил ещё раз - кабель цел и подключен к + фонаря заднего хода.
Может в прошивке дело? стоит оригинальная MTCD_HA_V1.99a_1 Nov 28 2016
Старый 09.10.2017, 21:13   #443
ДмитрийГлаз
@egor_sh, прошивка вряд-ли тут причем. Хотя у меня свежее была(2.36) с покупки.А щас обновил 2.52 или что то около того.
Старый 10.10.2017, 08:33   #444
AS21
Аватар для AS21
Авто: ASX 1.6 2WD MT
AV-in - именно так и работает, т.е. по запуску приложения
Если надо, чтобы срабатывал по ЗХ:
1) надо подать видео сигнал на back(view) в том же разъёме, где AV-in
2) надо запитать сам сигнал ЗХ (провод) - обычно обозначен как revers или back в основном разъёме
Если не лазили в заводских настройках - должно по сигналу ЗХ запуститься приложение backView.apk из андроид прошивки
Вот три условия: сигнал ЗХ, вход видео, приложение
Фронтальная камера совсем в другом разъёме и она будет включаться только, если поставить правильные флаги в заводских настройках. По умолчанию - она не работает
AS21 вне форума   Вверх Ответить с цитированием
Старый 10.10.2017, 10:26   #445
egor_sh
Аватар для egor_sh
Сообщение от AS21 Посмотреть сообщение
Немного запутался.
На фото(sorry за грязь на нем, это китаец с ali прислал во время переписки с ним) два желтых тюльпана:
CAM VIN (сюда пробовал, не показывает даже через AV-IN)
AUX Video IN (здесь показывает, но через запуск AV-IN приложения)
Так какой же из них для задней, а какой для фронтальной?
Попробую посмотреть есть ли у меня вообще backView.apk
Старый 10.10.2017, 11:18   #446
egor_sh
Аватар для egor_sh
Обновил MCU до MTCD_HA_V2.61_1 Sep 1 2017. Не помогло
Кстати, открыл список приложений в настройках android. в All не нашел backView.apk
Оно же должно там отображаться?
Добавлено через 2 часа 47 минут
Обновил android до свежего.
Поведение изменилось. Теперь если включаю заднюю и запускаю AV-IN, пишет "Video disabled while driving for safety!"
получается, я все же на место фронтальный камеры подключился и надо перекидывать провод обратно с AUX Video IN на CAM VIN и смотреть дальше.
Если + с фонарей заднего хода подается на коннектор "Back" магнитолы, она должна принудительно вызывать MTCBackView с пустым экраном? или только если ещё и тюльпан с камеры в нужном месте есть?
У меня пока вообще не реагирует на включение задней.
Старый 10.10.2017, 19:04   #447
Potable
Аватар для Potable
У меня с КАНом, но если заднюю ключить и видео с камеры нет - пустой экран. По логике, да, видео на "кам вин" и "+" (хотя чем черт не шутит, вдруг "-" ) от фонарей или ещё чего, что перемыкается при включении ЗХ, подавать на ...back, rear, reverse (как только китайцы не могут назвать). Удачи!
кстати, могли и паркингом назвать или паркинг - это разрешающий сигнал для просмотра видео на парковке. хз с каном все вообще без проблем все заработало, может с прода стрести кан?
Последний раз редактировалось Potable; 10.10.2017 в 19:11.
Старый 10.10.2017, 19:14   #448
AS21
Аватар для AS21
1) у нас всего 6 аналоговых видео входов
Из них два камеры + один AUX (AV-IN)... DVD DVR...
2)паркинг: это ручник поднят, в заводских настройках флаг: просмотр видео в движении
Если флаг поставить - то с AUX - видео всегда будет, если флаг убрать, ручник снят - кина не будет, а будет жёлтый тругольник
3) Вам надо:
1. Проверить подключение сигнала ЗХ - провод в главном разъёме
2. Найти распиновку разъёма, где Ваш AUX - и там найти CAM-IN - это задняя
3. Проверить наличие приложения backView.apk
И будет Вам счастье
Если оставить камеру в AUX - то Вам придётся в ручную постоянно запускать и выключать приложение - video, чтобы видеть заднюю камеру
4. Чтобы проверить - работает или нет сигнал ЗХ: при включенном AUX и подключенной к нему задней камере - ВКЛ. ЗХ, - если работает - изображение пропадет
Если не пропадает: у Вас точно не подключен провод к магнитоле - сигнал ЗХ
Судя по тому, что Вы видите через AUX изображение с задней камеры, при ВКЛ. ЗХ... А иначе не было бы питания от задних фонарей на камеру, начните с провода: сигнал ЗХ на МАГНИТОЛУ!!!!
Последний раз редактировалось AS21; 10.10.2017 в 19:29.
Старый 11.10.2017, 19:29   #449
egor_sh
Аватар для egor_sh
Все. получилось.
Перепроверил наличие напряжения на trigger cable рядом с магнитолой - тут все ок было.
Перекроссировал провода до самой камеры на CAM-VIN.
Но картинки не было. С горя прошелся ещё раз по опциям в инженерном меню и переключил Prohibit reverse на Enable.
После этого внезапно все заработало ; )
Радости моей нет предела.
2ДмитрийГлаз, AS21, Potable будете в наших краях на кипре - с меня стакан красного. Большое спасибо за помощь.
Мои основные ошибки:
1) ошибочно принял провод, отмеченный как parking за управляющий. на самом деле нужен был back(в моем случае balk)
2) нужный коннектор для видеосигнала CAM-VIN, а не AUX Video IN. здесь я поторопился срезать тюльпаны. каждое переключение в итоге обернулось перепайкой
3) гофра до пятой двери снимается. я тащил провод не снимая и убил около 2х часов. надеюсь, ничего толком не успел повредить внутри
4) с самой верхней частью пластиковой обшивки пятой двери нужно было быть понежнее. минус одна защелка на ней
5) ну и этот дурацкий пункт в инженерном меню
Сам провод в итоге обмотал китайской тряпичной изолентой(а-ля антишум) и провел сбоку под крышей.
Последний раз редактировалось egor_sh; 11.10.2017 в 19:47.
Старый 11.10.2017, 19:51   #450
AS21
Аватар для AS21
По умолчанию - всегда Enable (это и есть сигнал ЗХ). Странно, что у Вас ОНО было выключено
Я таки был прав - не было сигнала ЗХ.
Текущее время: 13:33. Часовой пояс GMT +3.
